Images in a combo box does not appear; path problem in Java Programming Code
Below is my java code for images to appear within the combo box beside the text.  I put the images inside the same folder but regardless of where I put the image and play around with the path the images still doesn’t appear.  The errors in Eclipse Console – “Couldn't find file: images/Bird.gif” etc.  I would prefer a simpler and short java code with a solution to the path.  What am I doing wrong?  Please help me.
import java.awt.BorderLayout;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.Font;
import javax.swing.BorderFactory;
import javax.swing.Icon;
import javax.swing.ImageIcon;
import javax.swing.JComboBox;
import javax.swing.JComponent;
import javax.swing.JFrame;
import javax.swing.JLabel;
import javax.swing.JList;
import javax.swing.JPanel;
import javax.swing.ListCellRenderer;
 * CustomComboBoxDemo.java uses the following files:
 *   images/Bird.gif
 *   images/Cat.gif
 *   images/Dog.gif
 *   images/Rabbit.gif
 *   images/Pig.gif
public class CustomComboBoxDemo extends JPanel {
    ImageIcon[] images;
    String[] petStrings = {"Bird", "Cat", "Dog", "Rabbit", "Pig"};
    public CustomComboBoxDemo() {
        super(new BorderLayout());
        //Load the pet images and create an array of indexes.
        images = new ImageIcon[petStrings.length];	//array size
        Integer[] intArray = new Integer[petStrings.length];
        for (int i = 0; i < petStrings.length; i++) {
            intArray[i] = new Integer(i);
            images[i] = createImageIcon("images/" + petStrings[i] + ".gif");
            if (images[i] != null) {
                images[i].setDescription(petStrings[i]);
        //Create the combo box.
        JComboBox petList = new JComboBox(intArray);
        ComboBoxRenderer renderer= new ComboBoxRenderer();
        renderer.setPreferredSize(new Dimension(200, 130));
        petList.setRenderer(renderer);
        petList.setMaximumRowCount(3);
        //Lay out the demo.
        add(petList, BorderLayout.PAGE_START);
        setBorder(BorderFactory.createEmptyBorder(20,20,20,20));
    /** Returns an ImageIcon, or null if the path was invalid. */
    protected static ImageIcon createImageIcon(String path) {
    	java.net.URL imgURL = CustomComboBoxDemo.class.getResource(path);
        if (imgURL != null) {
            return new ImageIcon(imgURL);
        } else {
            System.err.println("Couldn't find file: " + path);
                return null;
     * Create the GUI and show it.  For thread safety,
     * this method should be invoked from the
     * event-dispatching thread.
    private static void createAndShowGUI() {
        //Make sure we have nice window decorations.
        JFrame.setDefaultLookAndFeelDecorated(true);
        //Create and set up the window.
        JFrame frame = new JFrame("CustomComboBoxDemo");
        frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        //Create and set up the content pane.
        JComponent newContentPane = new CustomComboBoxDemo();
        newContentPane.setOpaque(true); //content panes must be opaque
        frame.setContentPane(newContentPane);
        //Display the window.
        frame.pack();
        frame.setVisible(true);
    public static void main(String[] args) {
        //Schedule a job for the event-dispatching thread:
        //creating and showing this application's GUI.
        javax.swing.SwingUtilities.invokeLater(new Runnable() {
            public void run() {
                createAndShowGUI();
    class ComboBoxRenderer extends JLabel
                           implements ListCellRenderer {
        private Font uhOhFont;
        public ComboBoxRenderer() {
            setOpaque(true);
            setHorizontalAlignment(CENTER);
            setVerticalAlignment(CENTER);
         * This method finds the image and text corresponding
         * to the selected value and returns the label, set up
         * to display the text and image.
        public Component getListCellRendererComponent(
                                           JList list,
                                           Object value,
                                           int index,
                                           boolean isSelected,
                                           boolean cellHasFocus) {
            //Get the selected index. (The index param isn't
            //always valid, so just use the value.)
            int selectedIndex = ((Integer)value).intValue();
            if (isSelected) {
                setBackground(list.getSelectionBackground());
                setForeground(list.getSelectionForeground());
            } else {
                setBackground(list.getBackground());
                setForeground(list.getForeground());
            //Set the icon and text.  If icon was null, say so.
            ImageIcon icon = images[selectedIndex];
            String pet = petStrings[selectedIndex];
            setIcon(icon);
            if (icon != null) {
                setText(pet);
                setFont(list.getFont());
            } else {
                setUhOhText(pet + " (no image available)",
                            list.getFont());
            return this;
        //Set the font and text when no image was found.
        protected void setUhOhText(String uhOhText, Font normalFont) {
            if (uhOhFont == null) { //lazily create this font
                uhOhFont = normalFont.deriveFont(Font.ITALIC);
            setFont(uhOhFont);
            setText(uhOhText);
Watch Question
Awarded 2011
Awarded 2011
with this
path should be computed from the top of your classpath
say if you have you java classes in the folder:
project/classes
and
path is
resources/image1.png
then your file should be in
project/classes/resources/image1.png
Awarded 2011
Awarded 2011
So path  should not be sought from the top project fiolder, but rather from the top folder of your class hierarchy
or from the folder which appears in the classpath
Awarded 2011
Awarded 2011
so if your path  is like that:
java.net.URL imgURL = CustomComboBoxDemo.class.getResource("images/Dog.gif");
and your class
is in the
project/classes
folder,
in the folder
project/classes/images
Check. It should work - I used it many times this way
I dont fully follow.  How do I update my code according to your explanation
Awarded 2011
Awarded 2011
don't update your code, just craete folder images in the folder where you have your class sitting
and copy your gif files to that folder
Thank you very much.  I will try now and report back to you.  However, in the meantime, do you have a simple and shorter code for displaying images in a combobox without any path problems.
Awarded 2011
Awarded 2011
these are by no means path problems - this is very convenient way to do that - beacuse then you can package everything in the .jar
and distribute this jar together with the resources - images, sound files, etc.
And the same code will work everywhere
Awarded 2011
Awarded 2011
I'm sure you can say
 java.net.URL imgURL = new URL("file://c:/projects/myproject/Dog.gif")
but that would be much les convenient as it will break as soon as you move it to different folder
This guy is brilliant in java.  He read and understood the attached code and responded with a solution within 2 minutes.
Thanks for your solution it worked.  I graded you as A as you responeded in lightning speed with a solution within 2 minutes.  You really digested that Java code very fast.  Thanks again.
thanks very much
Awarded 2011
Awarded 2011
You are always welcome.
