How to do a SQL Restore using a script with the same quality of SQL Studio Restore
We use Microsoft SQL for our Restore and we use it direct, using the studio (right-cick database >> all tasks >> restore).
We have come with the task to Restore at random times multiple database.  We go about the standard SQL studio way, but we would like to know if there is a script we can use to Restore 5 databases at the same time.
rayluvs
rayluvs
  • 11
  • 5
  • 4
  • +1
4 Solutions
jkofteCommented:
this is the same question, so i will copy and paste the answer. you do not need to give points for this.
this script backs up all the databases on sql server. to select one and backup only that db, write your where condition to "/* ADD WHERE HERE */".
DECLARE @name VARCHAR(50) -- database name
DECLARE @path VARCHAR(256) -- path for backup files
DECLARE @fileName VARCHAR(256) -- filename for backup
DECLARE @fileDate VARCHAR(20) -- used for file name
SET @path = 'C:\Backup\'
SELECT @fileDate = CONVERT(VARCHAR(20),GETDATE(),112)
DECLARE db_cursor CURSOR FOR
SELECT name
FROM master.dbo.sysdatabases /* ADD WHERE HERE */
WHERE name NOT IN ('master','model','msdb','tempdb')
OPEN db_cursor
FETCH NEXT FROM db_cursor INTO @name
WHILE @@FETCH_STATUS = 0
BEGIN
       SET @fileName = @path + @name + '_' + @fileDate + '.BAK'
       BACKUP DATABASE @name TO DISK = @fileName
END
CLOSE db_cursor
DEALLOCATE db_cursor
rayluvsAuthor Commented:
we want a script to restore not backup; don't understand why refer to the backup script?
Raja Jegan RSQL Server DBA & ArchitectCommented:
Yes, you can do it via T-SQL.
Just create the 2 procedures mentioned in the below link to do Backup and Restore for multiple databases.
http://www.sqlmag.com/article/tsql3/use-t-sql-to-back-up-and-restore-sql-server-user-databases
In order to restore multiple databases, we need to make sure that all the database backups are shared in the same path..
Cloud Class® Course: C++ 11 Fundamentals
This course will introduce you to C++ 11 and teach you about syntax fundamentals.
Eugene ZCommented:
you can via SSMS "(right-cick database >> all tasks >> restore).
 generate restore script in the way -locations what do you need
for each of your 5 specific databases;
save each script
and create 5 (5 dbs ) sql agent jobs  with saved scripts:
or run all of them at same time ( as you asked) or 1 by one)
Thank you very much!!!! Worked Excellently!!
One last question.  Where should I place the database name when I want to restore to another database other the original db?
Ramante,
Kindly let me know whether you have tried Eugenez's approach or my approach so that I can clarify your doubts accordingly.
My approach mentioned above will check for database backup and restore if the database is available in the same name automatically..
Eugene ZCommented:
<One last question.  Where should I place the database name when I want to restore to another database other the original db? >
if it is from SSMS generated
do same for next db and check the mdf ldf files location (set with overwrite and you would nee to make sure to disconnect users
Sorry for the delay, lots of holidays here, but we're back.
We tried both option and both worked.  However, we would like to have the script run the restore on X number of DB; ion other words, multiple backup files.  The reason is we do backups of more than one DB and sometimes we would like to just run one script to restore all DBs.
On rrjegan17 option, we would like to control DB names and backup files name.
With EugeneZ option, we can workaround using specific locations and file names, but how can we run it with multiples restore? (see script attached)
Nevertheless, whichever can be run multiple restore in one script-run, is what we need.
RESTORE DATABASE [BPS] FROM  DISK = N'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\BPS'
  WITH  FILE = 1,  MOVE N'BPS' TO N'C:\DBname\BPS.mdf',  MOVE N'BPS_log' TO N'C:\DBnameLOGS\BPS_log.ldf',
  NOUNLOAD,  REPLACE,  STATS = 10
GO
Eugene ZCommented:
inlude several restore scripts in 1 script and run it from sql sagint job step
for example if you have 3 DBs to be restored BPS1 BPS2 BPS3
RESTORE DATABASE [BPS1] FROM  DISK = N'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\BPS'
  WITH  FILE = 1,  MOVE N'BPS' TO N'C:\DBname\BPS1.mdf',  MOVE N'BPS_log' TO N'C:\DBnameLOGS\BPS1_log.ldf',
GO
RESTORE DATABASE [BPS2] FROM  DISK = N'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\BPS'
  WITH  FILE = 1,  MOVE N'BPS' TO N'C:\DBname\BPS2.mdf',  MOVE N'BPS_log' TO N'C:\DBnameLOGS\BPS2_log.ldf',
GO
RESTORE DATABASE [BPS3] FROM  DISK = N'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\BPS'
  WITH  FILE = 1,  MOVE N'BPS' TO N'C:\DBname\BPS3.mdf',  MOVE N'BPS_log' TO N'C:\DBnameLOGS\BPS3_log.ldf',
GO
oh ok... we though that this type of script would work. We'll try.
Eugene ZCommented:
you can try to use some lookup table and do more complicated code
but Q why to make more complicated if you deal we 1-5 DBs
thus this simple approach could be the best for your quest
It worked just fine, just place one script after the other thanx.
Prior closing the question, we would like to know in rrjegan17 recommendation, if there is a way to restore X number of DB instead of all.
Yes, you can do it..
While creating the procedure sp_backup_databases, just replace the below condition with the dbid of databases of which you need to backup and restore.
select name from sysdatabases where dbid > 6
You mean in order to restore specific DB, we have to modify the Backup SP to only backup the DBs we need to restore?  Modify the backup script to maybe something like this:
select name from sysdatabases where dbid in (x,x,x,x)
Yes, you got it correctly..
ok
Eugene ZCommented:
restore "universal" script can be not "100%"
you need to know exact location of the DB files unless the backup was taken from db that has exact mdf. ldf files and locations : for example
  G:\Data\test.mdf
otherwice - you need to use some loopup tabe to check what withmove resore will be ..
you can try this solution :
http://social.msdn.microsoft.com/Forums/is/databasedesign/thread/a6ecf8e4-17ba-432a-ace5-ee6f7fa4097b
---again it is up to you
bulk restore is not so "popular" task-- > but can be done
understood.
Thanx
Join & Write a Comment
Cloud Class® Course: Microsoft Office 2010
This course will introduce you to the interfaces and features of Microsoft Office 2010 Word, Excel, PowerPoint, Outlook, and Access. You will learn about the features that are shared between all products in the Office suite, as well as the new features that are product specific.
  • 11
  • 5
  • 4
  • +1
