Parsing address parts from one string in MS SQL
I have been attempting to adjust this code I found to meet my situation. I have an export table where the address was put into one field as opposed to four. The structure is
MyCity,MyState MyZipCode MyCountry -  there is only one comma and then 2 spaces
I was trying to use parsename and get it to convert the string to
MyCity.MyState.MyZipCode.MyCountry
I cannot get the script right because I can only get it to insert as period after MyCity and the value of ParseLen is always zero. Is it possible to adjust this code to accomplish what I need or is there another way?
select
replace(parsename(CitySTZip,ParseLen +1),',','') as Address1,
replace(parsename(CitySTZip,ParseLen ),',','') as Address2,
replace(parsename(CitySTZip,ParseLen -1),',','') as Address3,
replace(parsename(CitySTZip,ParseLen -2),',','') as Address4
from(
select case  ascii(right(rtrim(CitySTZip),1)) when 44 then
replace(replace(left(CitySTZip,(len(CitySTZip)-1)),',','.'),char(20),'.')
else
replace(replace(CitySTZip,',','.'),char(10),'.') end as CitySTZip,
len(replace(replace(CitySTZip,',','.'),char(20),'.')) - len(replace(replace(CitySTZip,',','.'),char(10),'')) -1
else
len(replace(replace(CitySTZip,',','.'),char(20),'.')) - len(replace(replace(CitySTZip,',','.'),char(10),'')) end as ParseLen
 from VendorsNTI) x
LVL 1
rwheeler23Asked:
SharathData EngineerCommented:
try like this.
select *,REPLACE(REPLACE(CitySTZip,' ','.'),',','.') NewAddressColumn from VendorsNTI
check this example
declare @table table (CitySTZip nvarchar(100))
insert @table values ('MyCity,MyState MyZipCode MyCountry')
select *,REPLACE(REPLACE(CitySTZip,' ','.'),',','.') NewCitySTZip from @table
/*CitySTZip	    MyCity,MyState MyZipCode MyCountry
NewCitySTZip	MyCity.MyState.MyZipCode.MyCountry
If you want the data in seperate strings, try like this.
select *,PARSENAME(REPLACE(REPLACE(CitySTZip,' ','.'),',','.'),1) Address1,
       PARSENAME(REPLACE(REPLACE(CitySTZip,' ','.'),',','.'),2) Address2,
       PARSENAME(REPLACE(REPLACE(CitySTZip,' ','.'),',','.'),3) Address3,
       PARSENAME(REPLACE(REPLACE(CitySTZip,' ','.'),',','.'),4) Address4
  from VendorsNTI
check this example.
  from @table
CitySTZip	Address1	Address2	Address3	Address4
MyCity,MyState MyZipCode MyCountry	MyCountry	MyZipCode	MyState	MyCity
Scott PletcherSenior DBACommented:
The City and State are easy, as long as you base it solely on the comma, and not spaces (e.g. "Salt Lake City, Utah").
    LEFT(CitySTZip, CHARINDEX(',', CitySTZip) - 1) AS City,
    LEFT(LTRIM(SUBSTRING(CitySTZip, CHARINDEX(',', CitySTZip) + 1, 1000)),
        CHARINDEX(' ', LTRIM(SUBSTRING(CitySTZip, CHARINDEX(',', CitySTZip) + 1, 1000)))) AS State,
The last two are a pain, because the country could also have extra space(s).
Will the zipcode always end in a digit?
Acronis True Image 2019 just released!
Create a reliable backup. Make sure you always have dependable copies of your data so you can restore your entire system or individual files.
rwheeler23Author Commented:
These addresses are for both USA and Canada. It appears Canada zipcode also always end in a digit. Now sometimes there is no zip code at all. We are only talking 2000 vendor addresses here so they will need to mop up those that do not convert correctly.
The city name may have spaces but the country is either USA, Canada or blank.
I had to add a check that any value was specified at all otherwise the script would error. The country is always last.
City, State  ZipCode  Country is the way most of these are presented.
select case when CHARINDEX(',', CitySTZip) > 0 then
		 LEFT(CitySTZip, CHARINDEX(',', CitySTZip) - 1)  else ' ' end AS City,
  from VendorsNTI
Did you try my query? Can you give some more examples where it is breaking?
The first does not do much of anything. The second replaces all commas and space with periods.
I have attached the import file so you can see the variations of addresses. I had used this text file and imported the data into SQL.
Vendors.txt
>> The second replaces all commas and space with periods. <<
Again, you cannot replace all spaces with periods and the parse on period -- because of city names like "Salt Lake City".
With those extras, the code will need to be more sophisticated.  You really need a table-value function and you can CROSS APPLY to it.
That is what I beginning to wonder. If they are willing to pay for it I will get to work on it. Thanks.
Thanlks for you help. Mopping up bad data is always an interesting experience.
Since the zip will always end in a digit, and no (?) cities that I knnow of have a digit in the name, you can find the zip by using PATINDEX('%[0-9]%', CitySTZip), and use that to help parse out the last two values.
That help but there are some Canadian addresses in there and those zip codes end in a letter. I was able to process about 90% without any user intervention.
Query Syntax
