Optiplex 755 does not power down. . .amber power light
I am having a strange situation with a Dell Optiplex 755 machine.  This was sitting idle on a shelf for some time (it is part of our reserve loaner PC pool).  Today, I had a need for it.  When I took it off the shelf and plugged it in, it immediately began to churn up even though I did not hit the power button.  Stranger still, when I went to cold boot the PC (by holding the power button in for a few seconds) it would power down only to rev up again once I took my finger off of the button.  Howver, all I get with all this is an amber power light with no POST or loading of Windows that I can see.
The PC is out of warranty, so I cannot contact Dell as I would usually do.
I am thinking that this is either a bad motherboard, power supply, or both?  I would appreciate any additional troubleshooting steps in order to determine.
Thanks.
AfpSysGrp
AfpSysGrp
4 Solutions
Patmac951Commented:
The first thing I would try would be the power supply, if a new/good power supply does not work then it is most likely the motherboard.
Andrew Hancock (VMware vExpert / EE MVE^2)VMware and Virtualization ConsultantCommented:
I had a similar issue, power supply was working (ish) but could not supply enough Amps, on power-up and power cdrom, hard disks and motherboard.
replacement power supply, solved the issue for me.
coolfigerCommented:
i had this issue .. once it was the power  supply and the other time the board was damaged. look at the capacitors if they are swolen its no good !
nobusCommented:
most likely is the Power supply that is bad; and both issues can be caused by swollen, or leaking capacitors, as said; here an example :
you can also use the minimum setup to troubleshoot your problem :
http://www.experts-exchange.com/Hardware/Components/Motherboards/A_1945.html                  (Short-overview-of-how-to-troubleshoot-bad-hardware-when-a-pc-does-not-post)
in case the disk went  bad - this is a nice guide also
http://www.experts-exchange.com/Storage/Hard_Drives/A_3000-The-bad-hard-disk-problem.html
AfpSysGrpAuthor Commented:
Sorry I have not had a chance to get back to you all on this. . .i sort of got pushed to the back burner.
The capacitors on the motherboard look fine, so I will proceed with the assumption that it is the power supply and troubleshoot further when I get some time to do so.
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
