troubleshooting Question
Help with setting values to x, y when clicking on checkbox of combobox
Avatar of vcharles
vcharles asked on
.NET ProgrammingASP.NETVisual Basic.NET
17 Comments1 Solution419 ViewsLast Modified:
I am using the code below to set values to x an y variables depending on which
checkbox I select, but I'm getting the following error:
Object reference not set to an instance of an object.
on line: Dim val As String = chkSelect.Text
Code:
Protected Sub Button135_Click(sender As Object, e As EventArgs) Handles Button135.Click
        Dim str1 As String = Nothing
        Dim x, y As Integer
        Dim ctrl As Control = MultiView1.FindControl("C1SDeactivation")
        For i = 0 To C1SDeactivationA.Items.Count - 1
            Dim chkSelect As CheckBox = CType(ctrl.FindControl(i), CheckBox)
            If str1 = "De-Arming" Then
                x = 1
            Else
                x = 0
            End If
            If str1 = "Sterilized" Then
                y = 1
            Else
                y = 0
            End If
        Next
        MsgBox(x)
        MsgBox(y)
    End Sub
How do I fix this problem?
Victor
Cluskitt
Unlock 1 Answer and 17 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
