ouch_mybrain_
Card Edge Components for customised hot-swap Scenario.
Dear Experts,
Does anyone know of a reputable online retailer/wholesaler that sells card edge connectors, preferably selling male/female connectors that can have cables (data AND power) soldered to the pins, the end effect is to be able to create a motherboard/hdd attached to a metal plate that can be hot-swapped by pulling the plate out for ease of convenience? Imagine as if like a quick way to connect/disconnect to I/O devices and power sources.
