Remove parts of string using C# or Regular Expression
rito1
rito1 asked
on
Hi All,
I have a string variable like so:
string strDesc = "<span title=More of something here>Something here</span>"
This variables content can differ but the structure stays the same i.e.
"<span title=*>*</span>"
Could anyone suggest how I could strip out the following elements from the string just leaving the contents of the span's title attribute..
remove - "<span title=" and ">*</span>"
Many thanks,
Rit
Watch Question
try the following code:
string strDesc = "<span title=More of something here>Something here</span>";
Regex regex = new Regex("<span title=");
strDesc = regex.Replace(strDesc, "");
regex = new Regex(">[^<]*</span>");
strDesc = regex.replace(strDesc, "");
Perfect, thank you very much indeed.
Rit
Most Valuable Expert 2011
Top Expert 2015
Try this:
using System.Text.RegularExpressions;
string result = Regex.Replace(input, "<span [^>]*?title=\"([^\"]+)[^>]*>(?:[^<]|<(?!/span>))*</span>", "$1");
Explore More ContentExplore courses, solutions, and other research materials related to this topic.
