Need help with offset formaul using VBA assigned Ranges?
bearblack
bearblack asked
on
Public Paid_Day As Range, Paid_Day_Calc As Range
With Freight
        FreightR1 = .Cells(Rows.Count, 1).End(xlUp).Row
        .Columns("G").Insert
        .Cells(1, 7).Value = "Day"
      Set Paid_Day = .Range(.Cells(1, 7), .Cells(FreightR1, 7))
      Set Paid_Day_Calc = .Range(.Cells(2, 7), .Cells(FreightR1, 7))
         With Paid_Day_Calc
               .Value = Application.Day(.Offset(, -1))
         End With
    End With
My Day calculation is bringing up an object error, What am i doing wrong?
Watch Question
I do not think there is a .day worksheetfunction
bearblackGlobal Program Manager
There is in excel
Here is another one that I would like to use Value instead of formulaR1C1
Vendor, Paid_Day, and Freight_Cost are all defined ranges
I had to do this to make it work which defeats the purpose:
            Vendor.Name = "Vendor"
            Paid_Day.Name = "Paid_Day"
            Freight_Cost.Name = "Freight_Cost"
.Range(.Cells(SummaryR3 + 1, 2), .Cells(SummaryR4, SummaryC3))
                .FormulaR1C1 = "=sumproduct((Vendor=RC1)*(Paid_Day=R" & SummaryR3 & "C),Freight_Cost)"
This isn't quite like VB/C#/+, you can't call a variable Public or Private inside of a sub routine.  Those are module-level calls.  Just 'Dim' your variable.  Or, outside of your sub, make it public there.
Also, I wouldn't use 'Application.Day' functionality either.  You're getting an error from that as well.  You would need to use 'VBA.Day()' instead.  There is a worksheetfunction DAY().  All projects will, by default, reference the Office OM, so you could leave off the 'VBA.' portion, but I always leave it on, just in case, as I've had it do funky things if left off.
For your other question, what are 'SummaryR3', 'SummaryR4', and 'SummaryC3' values?
HTH
Regards,
Zack Barresse
The Public is outside the sub routine. The 'SummaryR3', 'SummaryR4', and 'SummaryC3' values are Row and column counts.
        SummaryR4 = Summary.Cells(Rows.Count, 1).End(xlUp).Row
        SummaryC3 = Summary.Cells.Find(What:="*", SearchDirection:=xlPrevious, SearchOrder:=xlByColumns).Column
With Freight
        Vendor.Copy Summary.Cells(6, 1)
        With Paid_Day_Calc
            .Value = VBA.Day(.Offset(, -1))
            .NumberFormat = "General"
        End With
    End With
The error I get now is Type mismatch once changed
Can you tell us where the error is debugging at?  And can you post all of your code instead of snippets?
Zack
This is where it is buggin out:
Public Summary As Worksheet, Freight As Worksheet
Public SummaryR1 As Long, SummaryR2 As Long, SummaryR3 As Long, SummaryR4 As Long
Public SummaryC1 As Long, SummaryC2 As Long, SummaryC3 As Long
Public FreightR1 As Long, FreightR2 As Long, FreightR3 As Long
Public FreightC1 As Long, FreightC2 As Long, FreightC3 As Long
Public Freight_Ttl As Long
Public MinPost As Date, MaxPost As Date
Public Raw_Data As Range, Raw_Data_Filter As Range
Public Freight_Cost As Range, Freight_Credit As Range, Vendor As Range, Source_Doc As Range
Public Sum_Vendor As Range, Sum_Vendor_Data As Range, Sum_Freight_Calc As Range, Sum_Sum_Credit_Calc As Range
Public Paid_Day As Range, Paid_Day_Calc As Range, Sum_Paid_Day As Range, Sum_Paid_Day_Copy As Range
Sub Set_Tabs()
    Set Summary = Sheets("Summary")
    Set Freight = Sheets("Freight Raw Data")
  Call Set_Ranges
End Sub
Sub Set_Ranges()
    With Freight
        FreightC1 = .Cells.Find(What:="*", SearchDirection:=xlPrevious, SearchOrder:=xlByColumns).Column
        Set Raw_Data = .Range(.Cells(1, 1), .Cells(FreightR1, FreightC1))
        Set Raw_Data_Filter = .Range(.Cells(2, 1), .Cells(FreightR1, FreightC1))
        Set Freight_Cost = .Range(.Cells(1, 7), .Cells(FreightR1, 7))
        Set Freight_Credit = .Range(.Cells(1, 8), .Cells(FreightR1, 8))
        Set Source_Doc = .Range(.Cells(1, 9), .Cells(FreightR1, 9))
        Set Vendor = .Range(.Cells(1, 11), .Cells(FreightR1, 11))
    End With
End Sub
Sub Run_Freight_Report2()
    Application.ScreenUpdating = False
    Call Set_Tabs
' Delete Named Ranges
    On Error Resume Next
        For Each NameX In ActiveWorkbook.Names
            NameX.Delete
        Next
    On Error GoTo 0
    Summary.Cells.Clear
    With Freight
        With Paid_Day_Calc
            .Value = Day(.Offset(, -1))
        End With
    End With
    With Summary
        SummaryR1 = .Cells(Rows.Count, 1).End(xlUp).Row
      Set Sum_Vendor = .Range(.Cells(6, 1), .Cells(SummaryR1, 1))
            With Sum_Vendor
                .Activate
                .RemoveDuplicates Columns:=1, Header:=xlYes
                .Sort Key1:=.Cells(6, 1), Order1:=xlAscending, Header:=xlYes
            End With
        If .Cells(7, 1) = "" Then: .Rows(7).Delete
        .Cells(6, 1).Value = "Vendor"
        .Cells(6, 2).Value = "Freight"
        .Cells(6, 3).Value = "Credit"
        SummaryC1 = .Cells.Find(What:="*", SearchDirection:=xlPrevious, SearchOrder:=xlByColumns).Column
        Set Sum_Vendor_Data = .Range(.Cells(6, 1), .Cells(SummaryR1, SummaryC1))
        Set Sum_Freight_Calc = .Range(.Cells(7, 2), .Cells(SummaryR1, 2))
        Set Sum_Credit_Calc = .Range(.Cells(7, 3), .Cells(SummaryR1, 3))
        With Sum_Freight_Calc
            .Value = Application.SumIf(Vendor, .Offset(, -1), Freight_Cost)
            .ColumnWidth = 11
            .NumberFormat = "$#,##0_);[Red]($#,##0)"
        End With
        With Sum_Credit_Calc
            .Value = Application.SumIf(Vendor, .Offset(, -2), Freight_Credit)
            .ColumnWidth = 11
        End With
        With Sum_Vendor_Data
            .Borders.Weight = xlMedium
            .Borders(xlInsideHorizontal).Weight = xlThin
        End With
        With .Range(.Cells(6, 1), .Cells(6, SummaryC1))
            .Borders(xlEdgeBottom).Weight = xlMedium
            .Font.Bold = True
            .HorizontalAlignment = xlCenter
            .VerticalAlignment = xlCenter
            .Interior.ColorIndex = 34
        End With
        Sum_Vendor_Data.Sort Key1:=.Cells(6, 2), Order1:=xlDescending, Header:=xlYes
        .Cells(4, 2).Value = Application.Sum(Sum_Freight_Calc)
        .Cells(4, 3).Value = Application.Sum(Sum_Credit_Calc)
        With .Range(.Cells(4, 2), .Cells(4, SummaryC1))
            .Font.Bold = True
        End With
        .Range(.Cells(6, 2), .Cells(6, SummaryC1)).Copy (.Cells(6, 7))
        .Cells(7, 6).Value = "Accrue"
        .Cells(8, 6).Value = "UseTax"
        With .Range(.Cells(7, 6), .Cells(8, 6))
            .Font.Bold = True
            .ColumnWidth = 13
        End With
        With .Range(.Cells(7, 7), .Cells(8, 7))
            .Value = Application.SumIf(Source_Doc, .Offset(, -1), Freight_Cost)
        End With
        With .Range(.Cells(7, 8), .Cells(8, 8))
            .Value = Application.SumIf(Source_Doc, .Offset(, -2), Freight_Credit)
        End With
        With .Range(.Cells(7, 7), .Cells(8, 8))
            .Font.Bold = True
            .ColumnWidth = 13
        End With
        Paid_Day.Copy (.Cells(15, 6))
        SummaryR2 = .Cells(Rows.Count, 6).End(xlUp).Row
        .Range(.Cells(15, 6), .Cells(SummaryR2, 6)) _
      Set Sum_Paid_Day = .Range(.Cells(15, 6), .Cells(SummaryR2, 6))
      Set Sum_Paid_Day_Copy = .Range(.Cells(16, 6), .Cells(SummaryR2, 6))
        Sum_Paid_Day.Sort Key1:=.Cells(15, 6), Order1:=xlAscending, Header:=xlYes
        .Range(.Cells(6, 1), .Cells(6, SummaryC1)).Copy
        .Cells(15, 6).PasteSpecial (xlPasteFormats)
        .Cells(15, 7).Value = "Freight"
        .Cells(15, 8).Value = "Credit"
        SummaryC2 = .Cells.Find(What:="*", SearchDirection:=xlPrevious, SearchOrder:=xlByColumns).Column
        With .Range(.Cells(16, 7), .Cells(SummaryR2, 7))
            .Value = Application.SumIf(Paid_Day, .Offset(, -1), Freight_Cost)
        End With
        With .Range(.Cells(16, 8), .Cells(SummaryR2, 8))
            .Value = Application.SumIf(Paid_Day, .Offset(, -2), Freight_Credit)
        End With
        With .Range(.Cells(16, 6), .Cells(SummaryR2, 8))
            .Font.Bold = True
            .ColumnWidth = 13
        End With
        .Range(.Cells(16, 6), .Cells(SummaryR2, 6)).NumberFormat = "General"
        .Range(.Cells(4, 2), .Cells(4, 3)).Copy
            .Cells(13, 7).PasteSpecial (xlPasteFormats)
        .Cells(13, 7).Value = Application.Sum(.Range(.Cells(16, 7), .Cells(SummaryR2, 7)))
        .Cells(13, 8).Value = Application.Sum(.Range(.Cells(16, 8), .Cells(SummaryR2, 8)))
        Sum_Vendor.Copy (.Cells(SummaryR1 + 6, 1))
        Sum_Paid_Day_Copy.Copy
        SummaryR3 = SummaryR1 + 6
        .Cells(SummaryR3, 2) _
            .PasteSpecial Paste:=xlPasteFormulasAndNumberFormats, Transpose:=True
        SummaryR4 = .Cells(Rows.Count, 1).End(xlUp).Row
        SummaryC3 = .Cells.Find(What:="*", SearchDirection:=xlPrevious, SearchOrder:=xlByColumns).Column
            With .Range(.Cells(SummaryR3, 2), .Cells(SummaryR3, SummaryC3))
                .Font.Bold = True
                .Borders(xlInsideVertical).Weight = xlThin
            End With
            With .Range(.Cells(SummaryR3 + 1, 2), .Cells(SummaryR4, SummaryC3))
                .Copy
                .PasteSpecial (xlPasteValues)
            End With
        Paid_Day.Delete
    End With
    ActiveWorkbook.Save
    Summary.Copy
    Application.ScreenUpdating = True
End Sub
I see, you're trying to use a formula on an entire range.  It won't work like that.  Instead you could use something like this, which uses a formula then sets the value to static...
            .FormulaR1C1 = "=DAY(RC[-1])"
            .Value = .Value
HTH
Regards,
Zack Barresse
Explore More ContentExplore courses, solutions, and other research materials related to this topic.
