Help with creating Setup project
When creating a setup project with VS2010 for my windows application, is there a way when install the application, not to overwrite existing files found in the installation folder?
Victor
vcharlesAsked:
CodeCruiserCommented:
One guy here
http://stackoverflow.com/questions/6779778/visual-studio-2010-setup-project-minor-update-to-an-existing-installation
claims that patching is not supported in VS setup projects
What you describe is patching. Visual Studio doesn't support patches, so you will need to create them manually. If you want an easier solution, there are commercial setup authoring tools which offer direct support for both an updater and patches.
vcharlesAuthor Commented:
Thank You!
