Power small fans with USB
I wanted to check with the hardware gurus here if it would be possible to power old, small CPU cooling fans using the power from a USB 2.0 port.
I have a AIO system that I would like to throw some more air in thru the bottom. I  have several small old CPU fans ((80286, 80386, etc.) that I could mount to bottom of the system, but would prefer not to have to open the system to get power to them.
Therefore, I was wondering if I could wire the fans to a USB connection & plug it into one of its ports. I have more than enough USB ports.
Thanks!
LVL 1
BlinkrAsked:
Dave BaldwinFixer of ProblemsCommented:
Most of those fans require 12VDC and USB only supplies 5VDC at either 200mA or 500mA per port.
nobusCommented:
as said - usb does not have the correct voltage; but i would not use it for that, even if it had the correct voltage - since you can overload the USB easyly - and then you need a new mobo
you could - if you still want to fan the system, look for 5V fans, with low amperage
CallandorCommented:
I recommend that you bite the bullet and use case fans for they were designed for - connected to the power supply and moving air in the most efficient way.
Big Business Goals? Which KPIs Will Help You
The most successful MSPs rely on metrics – known as key performance indicators (KPIs) – for making informed decisions that help their businesses thrive, rather than just survive. This eBook provides an overview of the most important KPIs used by top MSPs.
nobusCommented:
that may be difficult on an AIO
BlinkrAuthor Commented:
What about chipset fans??
They are usually 12VDC.
Thanks for the help!! I am unable to find a 12VDC fan, so I tapped into the power of the system fan to power another small fan mounted on the outside.
PC
