C# control Servo Motor over com port problem
Posted on 2012-03-22
Last Modified: 2012-07-18
I have a C# window application that needs to talk to a stepper motor assembly over a serial port. When i run hyperterminal and pass commands they are accepted and returned with no issues.
In my application i open the port, send the first command and it returns no problem. The trouble is on any subsequent command issues nothing is sent or received. Same code, different result.
Load Form
 serialPort1.PortName = "COM6";
            serialPort1.BaudRate = 38400;
code to fire command, where e is a single char (just for testing)
// If the port is closed, don't try to send a character.
            if (!serialPort1.IsOpen) return;
            byte[] data = StrToByteArray(e.KeyChar + "\r\n");
            // Send the user's text straight out the port
            serialPort1.Write(data, 0, data.Length);
code to listen for receipt of data
 private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
            string RxString = serialPort1.ReadExisting();
            this.Invoke(new EventHandler(DisplayText));
private void DisplayText(object sender, EventArgs e)
What could be the difference between what hyperterminal sends/receives and how I am doing it?
Thanks for any help, sorry if vague but i am new to serial program flow.
Question by:Winston Smith
  • 3
Author Comment
by:Winston Smith
I have found these articles myself through a Google search, way too many googles.
The problem is not in setting up and making the calls, I know it works the first time it runs, its the subsequent calls. I need to know if I have to clear a buffer or reset the connection or something? However the hyperterminal does it works fine so if someone has links to how it works or the right direction it would be great.
LVL 21
Accepted Solution
viki2000 earned 2000 total points
I have done it in other languages few years ago for different instruments: starting with satellite receiver, programmable power supplies, digital oscilloscopes...and I have to do it in the next months for an embedded system. I do not program daily, only seldom when I need, few times per year...
OK, so my suggestions:
1) try to use other terminal than hyperterminal - just google it, try any trial version 30 days. If you need I can suggest some. Try for instance putty...
2) try to record, log the serial port activity using dedicated software to sniff, record the data. Analise the data and compare - the you see what is wrong.
3) If is necessary create virtual serial ports where the data is sent.
I am sure that is a simple answer, a direct solution to your question if somebody has in mind and works now with the protocol, but I suggest the above approach because you will learn more and you can control later all the situations.
I just remember that I controlled the serial port even from Excel in VBA.
LVL 21
Expert Comment
Just log/record the 2 situations and compare - you can find what is different.
I expect that is something related with the end character or they way how the port is open/close.
For your second set of commands, I think the port is not ready to receive info. ou have to look at the control lines, not only at the data.
We Need Your Input!
WatchGuard is currently running a beta program for our new macOS Host Sensor for our Threat Detection and Response service. We're looking for more macOS users to help provide insight and feedback to help us make the product even better. Please sign up for our beta program today!
Join & Write a Comment
Real-time is more about the business, not the technology. In day-to-day life, to make real-time decisions like buying or investing, business needs the latest information(e.g. Gold Rate/Stock Rate). Unlike traditional days, you need not wait for a fe…
Arrow Electronics was searching for a KVM  (Keyboard/Video/Mouse) switch that could display on one single monitor the current status of all units being tested on the rack.
From store locators to asset tracking and route optimization, learn how leading companies are using Google Maps APIs throughout the customer journey to increase checkout conversions, boost user engagement, and optimize order fulfillment. Powered …
624 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
