Running MSDE 2000 side-by-side with SQL Express 2008 on same machine
I would like to install SQL Express 2008 on a machine to host a database.
However, I have discovered that the customer's machine already has MSSQL 8.00.760 (MSDE) installed and running. It hosts a DB for an application, but nobody knows the security details / sa login, etc.
Is it possible to install SQL Express 2008 on the same machine and run it side-by-side with the existing MSDE instance?  If so, is there anything special that needs to be done or considered?
Thanks for your help.
mikealsweiler
mikealsweiler
  • 2
DBAduck - Ben MillerPrincipal ConsultantCommented:
They should run side-by-side because it will be another instance name which would make it unique to the machine.
mikealsweilerAuthor Commented:
Thanks, so installing MS SQL Server 2008 Express won't end up fighting over ports or anything due to it being a unique instance name?
No it will pick its own port
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
  • 2
