[Last Call] Learn how to a build a cloud-first strategyRegister Now
Solved
Need a free tool to work with oracle
Posted on 2012-08-20
12
Last Modified: 2012-08-21
I installed oracle 11g , now i need a tool to work with the database like creating table,function,storeprocedure , querying,database etc etc (USING GUI) and connect these with my asp.net application .
where can i find a tool to work with oracle 11g am not sure how to start with these things . I have exp in  pl/sql tool is it possible to use the same for oracle 11g and should be free ?
Am looking for some thing like sql express edition which is the GUI for ms sql server database .
Windows7,64bit
Meeran03
Question by:Rajar Ahmed
12 Comments
LVL 143
Assisted Solution
by:Guy Hengel [angelIII / a3]
Guy Hengel [angelIII / a3] earned 400 total points
you can install the SQL Developer tool. it should be included in the 11G installation wizard as option, if I remember correctly, I use that one every day extensively
LVL 23
Assisted Solution
by:OP_Zaharin
OP_Zaharin earned 400 total points
sql developer is a free tool from Oracle and can be download in the following link:
http://www.oracle.com/technetwork/developer-tools/sql-developer/downloads/index.html
LVL 78
Expert Comment
by:slightwv (䄆 Netminder)
You did NOT install Oracle 11g.  You installed the Oracle Data Access Components.  This is the connection piece for .Net to connect to Oracle.
You still need to install an actual database product.
Restore individual SQL databases with ease
Veeam Explorer for Microsoft SQL Server delivers an easy-to-use, wizard-driven interface for restoring your databases from a backup. No expert SQL background required. Web interface provides a complete view of all available SQL databases to simplify the recovery of lost database
LVL 18
Author Comment
by:Rajar Ahmed
Can i install this?
Windows 64-bit - Installation Notes       Download 171 M
does it look like pl/sql tool  because am currently working on this tool only ?
LVL 18
Author Comment
by:Rajar Ahmed
slightwv,
  ho i c , i was in a hurry to close that previous post considering database installation was successfull. so these tool never going to work isnt ?
LVL 78
Assisted Solution
slightwv (䄆 Netminder) earned 1200 total points
>>Can i install this?
Yes.  That is the tool people are suggesting in this question and your previous one.
Again though:  This is just a GUI to access an existing database.  You still don't have one of those nor the software to create one.
LVL 78
Assisted Solution
Again:  You did NOT install a database in that previous question.  Only the ODAC.
LVL 18
Author Comment
by:Rajar Ahmed
i successfully  installed the oracle sql developer & database.
I found that db on soln explorer left side
when i connect by right clk of that db ,  i receive this error .
how can i create a database connection in oracle sql developer? this is the first time am using oracle sql developer . pls suggest
Meeran03
LVL 78
Accepted Solution
by:
That is not createing a database.  That looks like an ODBC configuration screen.
Did you download and install Oracle XE?
From a command prompt issue the following commands:
C:\ sqlplus /nolog
If you get a SQL prompt:
SQL> conn / as sysdba
You should see 'Connected'.
If so:
SQL> create user myfirstuser identified by myfirstpassword;
SQL> grant create session, resource to myfirstuser;
Then use that username and password to connect with SQL Developer.
LVL 18
Author Comment
by:Rajar Ahmed
hi slightwv,
   yes i created database now.
  One last thing how can i connect this in asp.net application ?
I added this reference,
  	<assemblies>
				<add assembly="Oracle.DataAccess, Version=4.112.3.0, Culture=neutral, PublicKeyToken=89B483F429C47342"/></assemblies>
and in aspx page,
Imports Oracle.DataAccess
Partial Class firstOracle
    Inherits System.Web.UI.Page
    Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim s As New OracleConnection
    End Sub
End Class
am trying to fetch some basic data from a table
Meeran03
LVL 78
Expert Comment
Did you manually add the assemblies entry?  If so, remove it and try again.
Did you install the ODAC on this same machine?
From that error it cannot find what it is looking for.
If that doesn't work, please ask a new question in Oracle and the .Net zones.  This question was about the free tools.  I believe you now have everything you need.  You just need to focus on getting it to work.
LVL 18
Author Closing Comment
by:Rajar Ahmed
hi slightwv,
    You helped me to achieve something i want it for such a longtime on my pc. Thanks a lot.
Regards
Meeran03
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
In the first part of this tutorial we will cover the prerequisites for installing SQL Server vNext on Linux.
This month, Experts Exchange sat down with resident SQL expert, Jim Horn, for an in-depth look into the makings of a successful career in SQL.
This video shows how to Export data from an Oracle database using the Original Export Utility.  The corresponding Import utility, which works the same way is referenced, but not demonstrated.
Viewers will learn how the fundamental information of how to create a table.
Suggested Courses
831 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
