glabossi
NEED HELP FAST! Need to add vlookup formula to IF statement
Please see attached. I have two tabs (DELETE CODE and UPDATE EXPENSE).
In column "D" in UPDATE EXPENSE, I have a formula looking in DELETE CODE tab which says "If column D in DELETE CODE tab = "Delete", then "Ignore" or else "Update Expense".
I need to add a vlookup to the IF statement in UPDATE EXPENSE tab to match Column C in (Program Code) so it provides the value for the correct program.
Please help!
Thanks!
sample-code-aug-24.xlsx
Please help!
Thanks!
This is perfect! How can I add a 4th condition if its not applicable?
If a program code is not in the the DELETE CODE sheet at all I would need "Update Expense" value to be populated in UPDATE EXPENSE sheet automatically?
PERFECT!!!! THANK YOU SO MUCH!!!!
=IF(VLOOKUP(C2,'DELETE CODES'!$C$1:$D$5,2,0)="Del
copy down.
Thomas
