[Webinar] Learn how to a build a cloud-first strategyRegister Now
Solved
jquery paging/searching script seems to be hiding(all/parts) of my edit rows (.net listview)
Posted on 2012-09-07
13
Last Modified: 2012-09-21
hi all
script here
$(document).ready(function () {
    $('#txtUserSearch').keyup(function () {
        searchTable($(this).val(), '#MainContent_lvUsers_tblUserList');
    $('#txtUserItemSearch').keyup(function () {
        searchTable($(this).val(), '#tblUserItems');
    $('#txtMicrosoftSearch').keyup(function () {
        searchTable($(this).val(), '#MainContent_ListView1_tblMicrosoft');
    $('#txtEquipmentSearch').keyup(function () {
        searchTable($(this).val(), '#tblEquipment');
    paginate();
function paginate() {
    $('table.gridview').each(function () {
        var currentPage = 0;
        var numPerPage = 20;
        var $table = $(this);
        $table.bind('repaginate', function () {
            $table.find('tbody tr:not(.exclude)').hide().slice(currentPage * numPerPage, (currentPage + 1) * numPerPage).show();
        $table.trigger('repaginate');
        var numRows = $table.find('tbody tr:not(.exclude)').length;
        var numPages = Math.ceil(numRows / numPerPage);
        var $pager = $('<div id="pager" class="pager"></div>');
        for (var page = 0; page < numPages; page++) {
            $('<span class="page-number"></span>').text(page + 1).bind('click', {
                newPage: page
            }, function (event) {
                currentPage = event.data['newPage'];
                $(this).addClass('active').siblings().removeClass('active');
            }).appendTo($pager).addClass('clickable');
        // Clear the old pager first
        $('#pager').remove();
        $pager.insertBefore($table).find('span.page-number:first').addClass('active');
function searchTable(inputVal, tablename) {
    var table = $(tablename);
        table.find('tr:not(.header)').each(function (index, row) {
        var allCells = $(row).find('td');
        if (allCells.length > 0) {
            var found = false;
            allCells.each(function (index, td) {
                var regExp = new RegExp(inputVal, 'i');
                if (regExp.test($(td).text())) {
                    found = true;
                    return false;
            if (found == true) $(row).show().removeClass('exclude'); else $(row).hide().addClass('exclude');
    paginate();
problems here
his jquery is used on a asp.net listview and when i press edit another row is added with a large table for editing inside, now if the table is towards the bottom of the pager, not all, infact barley any of the edit row form is displayed
see pics
top edit  - the full form is visible
Top Edit
bottom edit - two or three lines visisble
bottom edit
if i try and edit the the record at the very bottom, i get no visible form...
i think whats happening is the jquery is being added to the subtable inside my row.
below is the code in edit mode (snippet anyway)
can we make the script ignore that row, or will it work if we ignore class details and beyond? im thinking that row has to be ignored?
<tr>
                <td class="edit" colspan="8">
                    <div class="details">
                        <asp:HiddenField ID="hidID" runat="server" Value='<%# Bind("ID") %>' />
                        <asp:HiddenField ID="hidUserID" runat="server" Value='<%# Bind("UserID") %>' ClientIDMode="Static" />
                        <table class="detailsview" cellpadding="0" cellspacing="0">
                            <tr>
                                <td class="td_title_align">Name:</td>
                                <td>
                                    <asp:TextBox ID="txtName" runat="server" Text='<%# Bind("Name") %>' CssClass="edit_box"></asp:TextBox>
Question by:awilderbeast
  • 7
  • 6
13 Comments
LVL 60
Expert Comment
by:Julian Hansen
If I understand the problem correctly then all you need to do is modify your JQuery to work on tables / rows that do not have a particular class and then give the table / row you want to ignore that class.
Other than that without seeing the app it is difficult to envisage the problem. For instance why is the container not expanding to incorporate the expanded row or showing scrollbars.
Maybe a solution is to make sure the container does not have overflow: hidden.
LVL 1
Author Comment
by:awilderbeast
yeah thats what i though, how do i do that, if i add a class of say "no_page" to the row
what do you mean the container not expading or showing scroll bars?
id show you the app but its an hosted only on my laptop
there is no overflow:hidden in any of my code
LVL 1
Author Comment
by:awilderbeast
hi there,
any update on this?
We value your feedback.
LVL 1
Author Comment
by:awilderbeast
hello,
could you tell me how to exlude a row from the pagination and have it be displayed?
i think its something in these lines that needs adding but i dont know what...
thanks
LVL 60
Expert Comment
by:Julian Hansen
Sorry missed your earlier posts. Trying to reload the problem.
Basically give the rows you want to exclude the class exclude - that should do it.
i.e.
<tr class="exclude">
LVL 1
Author Comment
by:awilderbeast
it didnt work
Heres a sample, ive put  a table in a row with BIG TABLE all over it
iv added my styles to it too so you can see it properly
what ive just found is happening, is the other half of the "BIG TABLE" is getting pushed to page 2 of the paging, you can see in the demo, the other half of the BIG TABLE is on paging 2
<head>
    <title></title>
    <style type="text/css">
        .gridview {
    width: 100%;
    display: table;
    padding: 5px;
    margin: 0;
.gridview tr.header,.gridview thead tr {
    font-weight: bold;
    color: #fff;
    background-color: #1296bc;
    /*background-image: url('/content/images/table_header_bg.png');*/
    background-repeat: repeat-x;
    text-align: left;
    height: 21px;
    padding: 0;
    padding-bottom: 4px;
.calendar, .calendar .ajax__calendar_container {
    border:1px solid #646464;
    background-color: white;
    color: black;
.detailsview .calendar tr td, .detailsview .calendar tr {
    margin:0;
    padding:0;
    height:auto;
    width:auto
.head_link, .head_link a, .head_link img {
text-decoration: none;
color: #fff;
border: none;
vertical-align: middle;
.even, .odd {
border-bottom:1px solid #CCC;
.even{
   background-color: #FFF;
.odd {
    background-color: #E2E4FF;
.edit {
    padding: 0;
    margin: 0;
.details {
    background-color:#f8f8f8;
    padding: 5px;
.detailsview {
    display: table;
    margin: 0;
.detailsview tr {
        height: 38px;
.detailsview tr td {
        padding: 0 5px;
.td_title_align {
    text-align: right;
.footer_command {
    padding: 5px;
    display: block;
    text-align: right;
.search_button {
    margin-left:-107px;
.search_box {
    width: 250px;
    padding:6px 95px 6px 6px;
.edit_box {
input, select {
    vertical-align:middle;
    -moz-border-radius:4px;
    -webkit-border-radius:4px;}
input[type="text"], select {
    background:#FFF;
    border:1px solid #bbb;
input[type="submit"] {
    width:100px;
    font-weight: bold;
    padding:2px; border:none;
    color:#fff;
    background: #1296bc;
    text-shadow:0px -1px 2px rgba(0,0,0,.7);
    cursor:pointer;-moz-border-radius:2px;
    -webkit-border-radius:2px;
input[type="submit"]::-moz-focus-inner {
    border:0;
input[type="submit"]:focus {
    background:#333;
.search {
    float:right;
    font-weight: bold;
    height: 25px;
.search input {
        width: 200px;
/* PAGING*/
div.pager {
float: left;
margin-bottom: 10px;
div.pager span {
    display: inline-block;
    padding: 5px;
    text-align: center;
    cursor: pointer;
    background: #E2E4FF;
    color: #000;
    margin-right: 0.5em;
div.pager span.active {
    color: #FFF
.insert_button {
    padding: 5px;
    cursor: pointer;
    color: #000;
/* COLOR SCALES*/
.green {
    background-color:#61c644;
    color:#335534;
.orange {
    background-color:#e69625;
    color:#cf1616;
.red {
    background-color:#c12121;
    color:#FFF;
    </style>
    <script type="text/javascript" src="Scripts/jquery-1.6.2.js"></script>
            paginate();
                        newPage: page
                    var found = false;
                            found = true;
                            return false;
            paginate();
    </script>
</head>
<body>
<div class="search" >Search: <input type="text" id="txtEquipmentSearch"/></div>
<table cellpadding="0" cellspacing="0" class="gridview" ID="tblEquipment">
                <thead>
                    <tr class="header">
                        <th>Name</th>
                        <th>Email</th>
                        <th>City</th>
                        <th>Country</th>
                    </tr>
                </thead>
    <tbody>
        <tr>
            <td>Wade</td>
            <td>vitae.orci.Phasellus@Morbisit.org</td>
            <td>Kemmerer</td>
            <td>Benin</td>
        </tr>
        <tr>
            <td>Leroy</td>
            <td>enim.Suspendisse@Maecenas.com</td>
            <td>Alamogordo</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Magee</td>
            <td>ultricies.adipiscing.enim@nullaCras.org</td>
            <td>Palmdale</td>
            <td>Burkina Faso</td>
        </tr>
        <tr>
            <td>Quamar</td>
            <td>parturient@Fuscedolor.ca</td>
            <td>South Portland</td>
            <td>Yemen</td>
        </tr>
        <tr>
            <td>Sebastian</td>
            <td>velit.Quisque.varius@Suspendisse.ca</td>
            <td>Durant</td>
            <td>Ethiopia</td>
        </tr>
        <tr>
            <td>Gary</td>
            <td>Curabitur.egestas@Nulla.org</td>
            <td>Mesquite</td>
            <td>Greenland</td>
        </tr>
        <tr>
            <td>Macon</td>
            <td>Aenean@etmalesuadafames.edu</td>
            <td>Paramount</td>
            <td>Tuvalu</td>
        </tr>
        <tr>
            <td>Axel</td>
            <td>magna@commodoatlibero.com</td>
            <td>Albany</td>
            <td>Faroe Islands</td>
        </tr>
        <tr>
            <td>Neville</td>
            <td>Donec.non@dictumProin.edu</td>
            <td>Richmond</td>
            <td>Guinea</td>
        </tr>
        <tr>
            <td>Lamar</td>
            <td>netus.et@Phasellusataugue.ca</td>
            <td>Placentia</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Barrett</td>
            <td>magnis@auctor.edu</td>
            <td>Bellflower</td>
            <td>Ethiopia</td>
        </tr>
        <tr>
            <td>Daquan</td>
            <td>arcu@sed.edu</td>
            <td>Keene</td>
            <td>China</td>
        </tr>
        <tr>
            <td>Kennan</td>
            <td>magna@nonduinec.com</td>
            <td>Barre</td>
            <td>South Georgia and The South Sandwich Islands</td>
        </tr>
        <tr>
            <td>Wing</td>
            <td>eu@metus.com</td>
            <td>White Plains</td>
            <td>Bouvet Island</td>
        </tr>
        <tr>
            <td>Elijah</td>
            <td>tincidunt.tempus@commodoauctor.com</td>
            <td>Sandy</td>
            <td>Uruguay</td>
        </tr>
        <tr>
            <td>Jackson</td>
            <td>dui.Cras.pellentesque@InloremDonec.org</td>
            <td>Centennial</td>
            <td>Indonesia</td>
        </tr>
        <tr>
            <td>Lane</td>
            <td>nunc.est.mollis@nequeNullamut.edu</td>
            <td>Ogdensburg</td>
            <td>Argentina</td>
        </tr>
        <tr>
            <td>Devin</td>
            <td>dictum@enim.edu</td>
            <td>Kearns</td>
            <td>Switzerland</td>
        </tr>
            <td colspan="4">
                <table>
                    <tr>
                        <td>TEST BIG TABLE inside row</td>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                </table>
            </td>
        </tr>
        <tr>
            <td>Logan</td>
            <td>dignissim.Maecenas.ornare@egestas.edu</td>
            <td>Eureka</td>
            <td>Mayotte</td>
        </tr>
        <tr>
            <td>Zane</td>
            <td>Sed.eu@Suspendissenonleo.org</td>
            <td>Duarte</td>
            <td>Martinique</td>
        </tr>
        <tr>
            <td>Gregory</td>
            <td>Maecenas.ornare@risusDonec.edu</td>
            <td>Manassas</td>
            <td>Sierra Leone</td>
        </tr>
        <tr>
            <td>Dennis</td>
            <td>odio.Aliquam.vulputate@turpisegestasAliquam.org</td>
            <td>Palos Verdes Estates</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Dennis</td>
            <td>eu@ametdiam.edu</td>
            <td>Vail</td>
            <td>Czech Republic</td>
        </tr>
        <tr>
            <td>Isaac</td>
            <td>facilisis.vitae@metussit.com</td>
            <td>Winooski</td>
            <td>Mali</td>
        </tr>
        <tr>
            <td>Lucius</td>
            <td>Cras.convallis@aliquet.org</td>
            <td>Webster Groves</td>
            <td>Palau</td>
        </tr>
        <tr>
            <td>Damon</td>
            <td>ac@dui.edu</td>
            <td>Nampa</td>
            <td>Trinidad and Tobago</td>
        </tr>
        <tr>
            <td>Colorado</td>
            <td>luctus.ut@dapibusid.edu</td>
            <td>Philadelphia</td>
            <td>Zimbabwe</td>
        </tr>
        <tr>
            <td>Lawrence</td>
            <td>sed.est.Nunc@mollisPhaselluslibero.com</td>
            <td>Evansville</td>
            <td>Peru</td>
        </tr>
        <tr>
            <td>Philip</td>
            <td>turpis@Nullam.ca</td>
            <td>Signal Hill</td>
            <td>Bosnia and Herzegovina</td>
        </tr>
        <tr>
            <td>Solomon</td>
            <td>urna@felispurus.ca</td>
            <td>Highland Park</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Craig</td>
            <td>felis.Nulla@lacusQuisqueimperdiet.ca</td>
            <td>Richmond</td>
            <td>Iran, Islamic Republic of</td>
        </tr>
        <tr>
            <td>Lucas</td>
            <td>vitae@nonhendreritid.com</td>
            <td>Holyoke</td>
            <td>Greenland</td>
        </tr>
        <tr>
            <td>Orlando</td>
            <td>sit@Nuncpulvinar.com</td>
            <td>Ponce</td>
            <td>Turkey</td>
        </tr>
        <tr>
            <td>Martin</td>
            <td>Nulla.aliquet.Proin@erat.ca</td>
            <td>Toledo</td>
            <td>Zambia</td>
        </tr>
        <tr>
            <td>Hakeem</td>
            <td>elit@auctor.com</td>
            <td>North Platte</td>
            <td>Nepal</td>
        </tr>
        <tr>
            <td>Mason</td>
            <td>ultrices.a.auctor@diam.org</td>
            <td>Nampa</td>
            <td>Wallis and Futuna</td>
        </tr>
        <tr>
            <td>Vladimir</td>
            <td>ante@Craseutellus.com</td>
            <td>Trenton</td>
            <td>Brazil</td>
        </tr>
        <tr>
            <td>Colin</td>
            <td>auctor@mollisIntegertincidunt.edu</td>
            <td>Williamsburg</td>
            <td>Liechtenstein</td>
        </tr>
        <tr>
            <td>Dean</td>
            <td>arcu.Vestibulum.ante@dui.com</td>
            <td>Starkville</td>
            <td>Tonga</td>
        </tr>
        <tr>
            <td>Calvin</td>
            <td>luctus@metusAliquam.org</td>
            <td>Hilo</td>
            <td>South Africa</td>
        </tr>
        <tr>
            <td>Silas</td>
            <td>elit.fermentum.risus@litora.org</td>
            <td>Johnson City</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Abdul</td>
            <td>Fusce.aliquam.enim@neque.com</td>
            <td>Moreno Valley</td>
            <td>China</td>
        </tr>
        <tr>
            <td>Callum</td>
            <td>risus@penatibuset.com</td>
            <td>Evanston</td>
            <td>Svalbard and Jan Mayen</td>
        </tr>
        <tr>
            <td>Howard</td>
            <td>placerat.augue@ataugue.org</td>
            <td>Chelsea</td>
            <td>Antigua and Barbuda</td>
        </tr>
        <tr>
            <td>Lawrence</td>
            <td>Nullam.velit.dui@Curabiturvellectus.ca</td>
            <td>Hammond</td>
            <td>Palestinian Territory, Occupied</td>
        </tr>
        <tr>
            <td>Jacob</td>
            <td>interdum.feugiat.Sed@Donecegestas.com</td>
            <td>Murrieta</td>
            <td>Japan</td>
        </tr>
        <tr>
            <td>Malik</td>
            <td>porta@sociisnatoque.edu</td>
            <td>College Station</td>
        </tr>
        <tr>
            <td>Jonas</td>
            <td>sagittis.semper@aliquamarcuAliquam.com</td>
            <td>Revere</td>
            <td>Paraguay</td>
        </tr>
        <tr>
            <td>Damian</td>
            <td>non@magnamalesuadavel.ca</td>
            <td>Nenana</td>
            <td>Guatemala</td>
        </tr>
        <tr>
            <td>Phillip</td>
            <td>fermentum.convallis@arcu.com</td>
            <td>Lawton</td>
            <td>Heard Island and Mcdonald Islands</td>
        </tr>
        <tr>
            <td>George</td>
            <td>arcu@lectusquismassa.ca</td>
            <td>Lubbock</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Ezra</td>
            <td>lectus.Cum@vulputateposuere.com</td>
            <td>Butler</td>
            <td>Cocos (Keeling) Islands</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>Nam.consequat.dolor@malesuadavel.org</td>
            <td>Rancho Palos Verdes</td>
            <td>Hong Kong</td>
        </tr>
        <tr>
            <td>Berk</td>
            <td>Donec.felis@eratvolutpatNulla.ca</td>
            <td>Cypress</td>
            <td>Estonia</td>
        </tr>
        <tr>
            <td>Damon</td>
            <td>laoreet.posuere.enim@Pellentesquehabitantmorbi.org</td>
            <td>Northampton</td>
        </tr>
        <tr>
            <td>Cain</td>
            <td>tellus@metus.org</td>
            <td>Fajardo</td>
            <td>Egypt</td>
        </tr>
        <tr>
            <td>Hashim</td>
            <td>venenatis.vel@dictum.com</td>
            <td>La Palma</td>
            <td>Djibouti</td>
        </tr>
        <tr>
            <td>Stewart</td>
            <td>et.netus.et@nequenonquam.com</td>
            <td>Alpharetta</td>
            <td>Bermuda</td>
        </tr>
        <tr>
            <td>Clinton</td>
            <td>Lorem@parturient.com</td>
            <td>Eau Claire</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>luctus.aliquet.odio@venenatisvel.edu</td>
            <td>Reno</td>
            <td>Bahrain</td>
        </tr>
        <tr>
            <td>Howard</td>
            <td>massa.Integer@pedeblandit.org</td>
            <td>Sioux Falls</td>
            <td>Namibia</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>risus.Morbi.metus@eueleifend.com</td>
            <td>Kingston</td>
            <td>Hungary</td>
        </tr>
        <tr>
            <td>Gannon</td>
            <td>accumsan@anteblanditviverra.org</td>
            <td>Montpelier</td>
            <td>India</td>
        </tr>
        <tr>
            <td>Knox</td>
            <td>ipsum.Curabitur@vehicula.org</td>
            <td>Flagstaff</td>
            <td>Thailand</td>
        </tr>
        <tr>
            <td>Adrian</td>
            <td>lobortis.mauris@egetmetuseu.com</td>
            <td>Half Moon Bay</td>
            <td>Malta</td>
        </tr>
        <tr>
            <td>Cole</td>
            <td>sit.amet.luctus@nisiAenean.com</td>
            <td>Santa Cruz</td>
            <td>Korea, Republic of</td>
        </tr>
        <tr>
            <td>Kibo</td>
            <td>nisi@Fusce.ca</td>
            <td>Opelousas</td>
            <td>Monaco</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>risus.at@Inmipede.edu</td>
            <td>Nashville</td>
            <td>Cuba</td>
        </tr>
        <tr>
            <td>Joseph</td>
            <td>nec@faucibuslectus.com</td>
            <td>Burbank</td>
            <td>New Caledonia</td>
        </tr>
        <tr>
            <td>Aquila</td>
            <td>rutrum@erat.ca</td>
            <td>New Bedford</td>
            <td>Viet Nam</td>
        </tr>
        <tr>
            <td>Blaze</td>
            <td>Fusce.fermentum.fermentum@vulputate.ca</td>
            <td>Paramount</td>
            <td>Dominican Republic</td>
        </tr>
        <tr>
            <td>Hector</td>
            <td>ut.mi@Uttincidunt.org</td>
            <td>Sunbury</td>
            <td>Brunei Darussalam</td>
        </tr>
        <tr>
            <td>Mannix</td>
            <td>ac.orci.Ut@Nulla.ca</td>
            <td>Pine Bluff</td>
            <td>Dominica</td>
        </tr>
        <tr>
            <td>Sean</td>
            <td>varius.Nam.porttitor@mauris.ca</td>
            <td>Corinth</td>
            <td>Paraguay</td>
        </tr>
        <tr>
            <td>Yoshio</td>
            <td>tristique.pellentesque@nectellusNunc.com</td>
            <td>Chino Hills</td>
            <td>Saint Lucia</td>
        </tr>
        <tr>
            <td>Warren</td>
            <td>urna@urnaNunc.com</td>
            <td>Pass Christian</td>
            <td>Guyana</td>
        </tr>
        <tr>
            <td>Brenden</td>
            <td>felis.orci@urna.edu</td>
            <td>Mesquite</td>
            <td>Bahrain</td>
        </tr>
        <tr>
            <td>Tanek</td>
            <td>justo.eu.arcu@ipsumSuspendisse.com</td>
            <td>Cheyenne</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Tucker</td>
            <td>non.quam.Pellentesque@Integer.edu</td>
            <td>Williston</td>
            <td>Guyana</td>
        </tr>
        <tr>
            <td>Burke</td>
            <td>ornare.lectus@fermentummetusAenean.org</td>
            <td>Dodge City</td>
            <td>Serbia and Montenegro</td>
        </tr>
        <tr>
            <td>Abbot</td>
            <td>amet.risus.Donec@felis.org</td>
            <td>Fitchburg</td>
            <td>Pitcairn</td>
        </tr>
        <tr>
            <td>Kuame</td>
            <td>aliquet.vel@necorci.com</td>
            <td>La Puente</td>
            <td>Albania</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>et@adipiscingligulaAenean.edu</td>
            <td>Bellflower</td>
        </tr>
        <tr>
            <td>Kermit</td>
            <td>penatibus.et.magnis@non.org</td>
            <td>Ardmore</td>
            <td>Nauru</td>
        </tr>
        <tr>
            <td>Cruz</td>
            <td>lorem@dolor.edu</td>
            <td>Saint Cloud</td>
            <td>Haiti</td>
        </tr>
        <tr>
            <td>Nolan</td>
            <td>gravida.Aliquam.tincidunt@egestasDuisac.com</td>
            <td>Seward</td>
            <td>Mauritius</td>
        </tr>
        <tr>
            <td>Myles</td>
            <td>Class@taciti.com</td>
            <td>Lawndale</td>
            <td>Swaziland</td>
        </tr>
        <tr>
            <td>Emerson</td>
            <td>nibh.Quisque.nonummy@ligulaAliquamerat.edu</td>
            <td>Meriden</td>
            <td>Netherlands</td>
        </tr>
        <tr>
            <td>Dalton</td>
            <td>a.tortor@dis.com</td>
            <td>International Falls</td>
        </tr>
        <tr>
            <td>Graiden</td>
            <td>habitant.morbi@atarcuVestibulum.ca</td>
            <td>Durango</td>
            <td>Iraq</td>
        </tr>
        <tr>
            <td>Vincent</td>
            <td>tempor.bibendum@augue.ca</td>
            <td>Bandera</td>
            <td>Central African Republic</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>Proin@ut.org</td>
            <td>Reedsport</td>
            <td>Macedonia</td>
        </tr>
        <tr>
            <td>Anthony</td>
            <td>nec.mauris@pedeet.ca</td>
            <td>Seattle</td>
            <td>Finland</td>
        </tr>
        <tr>
            <td>Driscoll</td>
            <td>vestibulum.nec.euismod@luctus.edu</td>
            <td>Kettering</td>
            <td>Puerto Rico</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>dapibus.gravida.Aliquam@egetvarius.ca</td>
            <td>Richmond</td>
            <td>Mexico</td>
        </tr>
        <tr>
            <td>Branden</td>
            <td>massa.lobortis.ultrices@Sedeu.com</td>
            <td>Tyler</td>
            <td>Mongolia</td>
        </tr>
        <tr>
            <td>Steel</td>
            <td>eu.nulla@nequeseddictum.ca</td>
            <td>Azusa</td>
            <td>Russian Federation</td>
        </tr>
        <tr>
            <td>Steven</td>
            <td>feugiat@tacitisociosqu.edu</td>
            <td>Guthrie</td>
            <td>Zimbabwe</td>
        </tr>
        <tr>
            <td>Blaze</td>
            <td>pretium@idrisusquis.com</td>
            <td>Longview</td>
            <td>Haiti</td>
        </tr>
        <tr>
            <td>Chaney</td>
            <td>tristique@iaculisquispede.org</td>
            <td>Fredericksburg</td>
            <td>Lithuania</td>
        </tr>
        <tr>
            <td>Bruno</td>
            <td>Class.aptent@elementumdui.com</td>
            <td>Fountain Valley</td>
            <td>Germany</td>
        </tr>
        <tr>
            <td>Erich</td>
            <td>vitae@nibhAliquam.com</td>
            <td>Naperville</td>
            <td>Hungary</td>
        </tr>
        <tr>
            <td>Lee</td>
            <td>libero@ametrisusDonec.ca</td>
            <td>East Hartford</td>
            <td>Philippines</td>
        </tr>
        <tr>
            <td>Amos</td>
            <td>lectus@DonecestNunc.org</td>
            <td>Corinth</td>
            <td>Suriname</td>
        </tr>
        <tr>
            <td>Clayton</td>
            <td>Suspendisse.eleifend@metusfacilisislorem.org</td>
            <td>Agat</td>
            <td>Bolivia</td>
        </tr>
        <tr>
            <td>Raja</td>
            <td>quis.urna.Nunc@non.com</td>
            <td>Las Cruces</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Jackson</td>
            <td>a.mi.fringilla@lorem.edu</td>
            <td>Plano</td>
        </tr>
        <tr>
            <td>Arthur</td>
            <td>Suspendisse@sitametmetus.org</td>
            <td>Natchez</td>
            <td>Belgium</td>
        </tr>
        <tr>
            <td>Arsenio</td>
            <td>Nullam@pedeblanditcongue.ca</td>
            <td>Waterloo</td>
            <td>Malaysia</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>non.ante@mi.edu</td>
            <td>Korea</td>
        </tr>
        <tr>
            <td>Tucker</td>
            <td>aliquam.enim.nec@eleifendegestas.edu</td>
            <td>Fort Worth</td>
            <td>Tokelau</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>fermentum.metus.Aenean@penatibus.com</td>
            <td>Elizabeth City</td>
            <td>Honduras</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>primis@consectetuer.edu</td>
            <td>Merced</td>
            <td>Madagascar</td>
        </tr>
        <tr>
            <td>Rooney</td>
            <td>eros@lobortisClassaptent.org</td>
            <td>El Cerrito</td>
            <td>Chad</td>
        </tr>
        <tr>
            <td>Eaton</td>
            <td>nunc.interdum.feugiat@Curabitur.edu</td>
            <td>Ardmore</td>
            <td>Croatia</td>
        </tr>
        <tr>
            <td>Rahim</td>
            <td>ut.lacus.Nulla@Fusce.org</td>
            <td>Los Angeles</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Mohammad</td>
            <td>augue.Sed.molestie@enimCurabitur.ca</td>
            <td>Ypsilanti</td>
        </tr>
        <tr>
            <td>Xander</td>
            <td>vulputate.mauris@a.ca</td>
            <td>Idaho Falls</td>
            <td>Ireland</td>
        </tr>
        <tr>
            <td>Joel</td>
            <td>magna@necmollis.org</td>
            <td>Omaha</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>sem@ante.org</td>
            <td>Laconia</td>
        </tr>
        <tr>
            <td>Grady</td>
            <td>libero.lacus.varius@enim.ca</td>
            <td>Austin</td>
            <td>Libyan Arab Jamahiriya</td>
        </tr>
        <tr>
            <td>Herrod</td>
            <td>faucibus.orci@Aliquamerat.edu</td>
            <td>Yazoo City</td>
            <td>Turkey</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>sodales.at@luctusipsum.edu</td>
            <td>Morrison</td>
            <td>Israel</td>
        </tr>
        <tr>
            <td>Armando</td>
            <td>lorem.fringilla.ornare@nequevitaesemper.edu</td>
            <td>Covina</td>
            <td>Slovenia</td>
        </tr>
        <tr>
            <td>Shad</td>
            <td>magna@Fuscefeugiat.edu</td>
            <td>Taylorsville</td>
            <td>Jamaica</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>adipiscing.elit@elit.ca</td>
            <td>Artesia</td>
            <td>Austria</td>
        </tr>
        <tr>
            <td>Justin</td>
            <td>non.massa@placeratvelitQuisque.edu</td>
            <td>Camden</td>
            <td>Kazakhstan</td>
        </tr>
        <tr>
            <td>Vernon</td>
            <td>diam.eu.dolor@acmattis.com</td>
            <td>Champaign</td>
            <td>Senegal</td>
        </tr>
        <tr>
            <td>Joseph</td>
            <td>blandit@dictumeleifend.edu</td>
            <td>Westminster</td>
            <td>Chile</td>
        </tr>
        <tr>
            <td>Malcolm</td>
            <td>Quisque.porttitor.eros@aarcu.com</td>
            <td>La Mirada</td>
            <td>Macao</td>
        </tr>
        <tr>
            <td>Nicholas</td>
            <td>Nulla@vehicula.com</td>
            <td>Mequon</td>
            <td>Costa Rica</td>
        </tr>
        <tr>
            <td>Bruce</td>
            <td>malesuada.malesuada.Integer@Phasellus.org</td>
            <td>Spokane</td>
            <td>Sao Tome and Principe</td>
        </tr>
        <tr>
            <td>Xanthus</td>
            <td>arcu@malesuadafames.com</td>
            <td>Moraga</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Conan</td>
            <td>tempor.diam.dictum@Vestibulum.org</td>
            <td>Port Huron</td>
            <td>United States</td>
        </tr>
        <tr>
            <td>Marvin</td>
            <td>a.scelerisque.sed@sapienimperdietornare.org</td>
            <td>Chico</td>
            <td>Indonesia</td>
        </tr>
        <tr>
            <td>Gareth</td>
            <td>Ut.sagittis.lobortis@nequesed.com</td>
            <td>Hollywood</td>
            <td>Iceland</td>
        </tr>
        <tr>
            <td>Felix</td>
            <td>at.fringilla.purus@acfermentum.com</td>
            <td>Cedarburg</td>
        </tr>
        <tr>
            <td>Devin</td>
            <td>Nullam@tinciduntnibh.edu</td>
            <td>Ketchikan</td>
            <td>Marshall Islands</td>
        </tr>
        <tr>
            <td>Alec</td>
            <td>purus.ac@nisi.org</td>
            <td>Port Huron</td>
            <td>Kuwait</td>
        </tr>
        <tr>
            <td>Garrett</td>
            <td>non@velnislQuisque.com</td>
            <td>Davenport</td>
            <td>Thailand</td>
        </tr>
        <tr>
            <td>Camden</td>
            <td>sit@lectus.com</td>
            <td>Fullerton</td>
            <td>Poland</td>
        </tr>
        <tr>
            <td>Noah</td>
            <td>urna.suscipit.nonummy@risusat.org</td>
            <td>Chandler</td>
            <td>Suriname</td>
        </tr>
        <tr>
            <td>Callum</td>
            <td>id.mollis@feugiat.ca</td>
            <td>Providence</td>
            <td>Peru</td>
        </tr>
        <tr>
            <td>Amir</td>
            <td>gravida.sit.amet@ornarelibero.org</td>
            <td>Ketchikan</td>
            <td>Kiribati</td>
        </tr>
        <tr>
            <td>Phelan</td>
            <td>consectetuer.cursus.et@felis.ca</td>
            <td>Truth or Consequences</td>
            <td>Turkmenistan</td>
        </tr>
        <tr>
            <td>Lane</td>
            <td>dapibus@eratvitae.org</td>
            <td>Edina</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Dylan</td>
            <td>Sed.eget@Sedid.ca</td>
            <td>Gadsden</td>
            <td>French Guiana</td>
        </tr>
        <tr>
            <td>Palmer</td>
            <td>nibh.Phasellus.nulla@cursus.com</td>
            <td>Lodi</td>
            <td>Georgia</td>
        </tr>
        <tr>
            <td>Austin</td>
            <td>Cum@nisl.com</td>
            <td>Coatesville</td>
            <td>Myanmar</td>
        </tr>
        <tr>
            <td>Joshua</td>
            <td>massa.rutrum.magna@urnaNullam.com</td>
            <td>Fond du Lac</td>
            <td>Oman</td>
        </tr>
        <tr>
            <td>Merritt</td>
            <td>libero.at@auctorodioa.org</td>
            <td>Duncan</td>
            <td>Cook Islands</td>
        </tr>
        <tr>
            <td>Hashim</td>
            <td>molestie@eu.ca</td>
            <td>Gastonia</td>
            <td>Malaysia</td>
        </tr>
        <tr>
            <td>Sebastian</td>
            <td>a.mi.fringilla@litoratorquentper.ca</td>
            <td>Kettering</td>
            <td>Slovenia</td>
        </tr>
        <tr>
            <td>Marvin</td>
            <td>rhoncus.id@diam.com</td>
            <td>Pine Bluff</td>
            <td>Japan</td>
        </tr>
        <tr>
            <td>Wang</td>
            <td>feugiat.placerat.velit@magnatellus.org</td>
            <td>New Rochelle</td>
            <td>Argentina</td>
        </tr>
        <tr>
            <td>Paki</td>
            <td>sapien.Nunc.pulvinar@non.com</td>
            <td>Rancho Santa Margarita</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Cody</td>
            <td>pharetra.Quisque@idblandit.ca</td>
            <td>Fargo</td>
            <td>Christmas Island</td>
        </tr>
        <tr>
            <td>Daquan</td>
            <td>Mauris.non@metus.ca</td>
            <td>Laconia</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Todd</td>
            <td>amet.diam.eu@sagittislobortis.ca</td>
            <td>Meridian</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>arcu.Curabitur@odioauctor.edu</td>
            <td>Staunton</td>
        </tr>
        <tr>
            <td>Nehru</td>
            <td>penatibus@adipiscing.ca</td>
            <td>Independence</td>
            <td>Ecuador</td>
        </tr>
        <tr>
            <td>Giacomo</td>
            <td>tempus.risus@egestas.org</td>
            <td>Boston</td>
            <td>Kiribati</td>
        </tr>
        <tr>
            <td>Kirk</td>
            <td>mauris.ut@Phasellus.org</td>
            <td>Frankfort</td>
            <td>Ukraine</td>
        </tr>
        <tr>
            <td>Brandon</td>
            <td>nec.tellus.Nunc@Aliquam.edu</td>
            <td>Fargo</td>
        </tr>
        <tr>
            <td>Fuller</td>
            <td>turpis.egestas.Aliquam@porttitorvulputate.com</td>
            <td>New Britain</td>
            <td>Gibraltar</td>
        </tr>
        <tr>
            <td>Thaddeus</td>
            <td>tellus.justo.sit@Crasdolor.org</td>
            <td>Torrington</td>
        </tr>
        <tr>
            <td>Allen</td>
            <td>Nunc.lectus.pede@est.org</td>
            <td>Chicopee</td>
            <td>Macao</td>
        </tr>
        <tr>
            <td>Forrest</td>
            <td>non.massa@iaculis.ca</td>
            <td>Valdez</td>
            <td>Algeria</td>
        </tr>
        <tr>
            <td>Steven</td>
            <td>eleifend.vitae.erat@vehicularisusNulla.ca</td>
            <td>Cary</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Stone</td>
            <td>lorem.auctor.quis@faucibusut.com</td>
            <td>Redding</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Brian</td>
            <td>congue@Donectempus.ca</td>
            <td>Attleboro</td>
            <td>Anguilla</td>
        </tr>
        <tr>
            <td>Ferris</td>
            <td>Duis.mi@mattisCraseget.edu</td>
            <td>Agat</td>
            <td>Ireland</td>
        </tr>
        <tr>
            <td>Aaron</td>
            <td>faucibus.orci@Vivamus.com</td>
            <td>West Sacramento</td>
        </tr>
        <tr>
            <td>Bradley</td>
            <td>In@euenim.com</td>
            <td>Baltimore</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Jesse</td>
            <td>pellentesque.eget.dictum@metus.com</td>
            <td>Dana Point</td>
            <td>Algeria</td>
        </tr>
        <tr>
            <td>Wade</td>
            <td>sed.tortor@Proindolor.edu</td>
            <td>Vicksburg</td>
            <td>Saint Vincent and The Grenadines</td>
        </tr>
        <tr>
            <td>Gareth</td>
            <td>sodales@velnislQuisque.ca</td>
            <td>Wheeling</td>
            <td>Niger</td>
        </tr>
        <tr>
            <td>Avram</td>
            <td>pede.nonummy.ut@utsemNulla.com</td>
            <td>Honolulu</td>
            <td>Portugal</td>
        </tr>
        <tr>
            <td>Alec</td>
            <td>sit.amet@interdumNuncsollicitudin.edu</td>
            <td>Pittsburgh</td>
            <td>Togo</td>
        </tr>
        <tr>
            <td>Luke</td>
            <td>nisl.Maecenas.malesuada@pharetraNam.com</td>
            <td>Cicero</td>
            <td>Bermuda</td>
        </tr>
        <tr>
            <td>Hyatt</td>
            <td>ut.aliquam.iaculis@velquamdignissim.ca</td>
            <td>North Las Vegas</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>convallis.est.vitae@Sednuncest.ca</td>
            <td>Bulgaria</td>
        </tr>
        <tr>
            <td>Jameson</td>
            <td>felis@vestibulumneque.org</td>
            <td>Gilette</td>
            <td>Barbados</td>
        </tr>
        <tr>
            <td>Conan</td>
            <td>egestas.hendrerit.neque@sedsapienNunc.org</td>
            <td>Baldwin Park</td>
            <td>Macedonia</td>
        </tr>
        <tr>
            <td>Len</td>
            <td>Cum.sociis.natoque@Vivamus.edu</td>
            <td>Calabasas</td>
        </tr>
        <tr>
            <td>Abdul</td>
            <td>in.consectetuer@eu.com</td>
            <td>Duncan</td>
            <td>Uzbekistan</td>
        </tr>
        <tr>
            <td>Levi</td>
            <td>semper@orci.org</td>
            <td>Carbondale</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Hop</td>
            <td>magna.Lorem@tempusrisus.ca</td>
            <td>Ansonia</td>
            <td>Tonga</td>
        </tr>
        <tr>
            <td>Nissim</td>
            <td>primis.in@lobortisnisi.com</td>
            <td>Newburgh</td>
            <td>Pitcairn</td>
        </tr>
        <tr>
            <td>Wade</td>
            <td>In.at@tristiquesenectus.edu</td>
            <td>Guánica</td>
            <td>Kyrgyzstan</td>
        </tr>
        <tr>
            <td>Brennan</td>
            <td>mauris.sagittis.placerat@purusactellus.org</td>
            <td>Meridian</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Dolan</td>
            <td>tempus.scelerisque@blanditenim.com</td>
            <td>La Palma</td>
            <td>Togo</td>
        </tr>
        <tr>
            <td>Allistair</td>
            <td>nec.tellus.Nunc@etpedeNunc.ca</td>
            <td>Kennewick</td>
            <td>Zambia</td>
        </tr>
        <tr>
            <td>Holmes</td>
            <td>est@sollicitudin.org</td>
            <td>San Antonio</td>
            <td>Jordan</td>
        </tr>
        <tr>
            <td>Jarrod</td>
            <td>congue@elit.org</td>
            <td>Wichita</td>
            <td>Falkland Islands (Malvinas)</td>
        </tr>
        <tr>
            <td>Aristotle</td>
            <td>egestas.Aliquam@sollicitudin.com</td>
            <td>Brown Deer</td>
        </tr>
        <tr>o
            <td>Acton</td>
            <td>at.arcu@rutrum.edu</td>
            <td>Solomon Islands</td>
        </tr>
        <tr>
            <td>Harper</td>
            <td>consequat.dolor@acipsumPhasellus.ca</td>
            <td>Costa Mesa</td>
        </tr>
        <tr>
            <td>Cole</td>
            <td>neque.Morbi@Donec.org</td>
            <td>Lima</td>
            <td>Canada</td>
        </tr>
    </tbody>
            </table>
</body>
</html>
LVL 60
Expert Comment
by:Julian Hansen
ok - I see that but what are you expecting to see by putting exclude on BIG TABLE - I am trying to visualise what the problem is.
LVL 1
Author Comment
by:awilderbeast
Im not sure if exclude is the fix
what i want to be able to do is the BIG table stay on the page it was opened. so it pushes the rows down instead of moving them to page 2
LVL 60
Expert Comment
by:Julian Hansen
Ok so you want the pagination to igore the table and show say 36 rows when it would normally only show 20 i.e. not break the table?
If so then you are sort of breaking the rules of pagination - and things will become complex.
LVL 1
Author Comment
by:awilderbeast
well my big table is inside 1 row (table inside a row) i dont know how the pagination is calculated, my big table is only ever 1 row as far as pagination is concerned, but it takes the height of say 8 rows.
Is the row height taken into account with pagingation?
LVL 60
Accepted Solution
by:
Julian Hansen earned 2000 total points
Ah - ok now I see what you are saying. I see what the problem is - the table inside the row has <tr> elements which are children of the same parent as the <tr> that contains the table itself - so they are going to be included in the results. You need to change two of find's to children (the latter only considers immediate children). I think this should do it
<!doctype html>
<html>
<head>
    <title></title>
.gridview {
    width: 100%;
    display: table;
    padding: 5px;
    margin: 0;
    font-weight: bold;
    color: #fff;
    text-align: left;
    height: 21px;
    padding: 0;
    color: black;
    margin:0;
    padding:0;
    height:auto;
    width:auto
color: #fff;
border: none;
.even, .odd {
.even{
.odd {
.edit {
    padding: 0;
    margin: 0;
.details {
    padding: 5px;
.detailsview {
    display: table;
    margin: 0;
.detailsview tr {
        height: 38px;
        padding: 0 5px;
.td_title_align {
    text-align: right;
.footer_command {
    padding: 5px;
    display: block;
    text-align: right;
.search_button {
    margin-left:-107px;
.search_box {
    width: 250px;
.edit_box {
input, select {
    background:#FFF;
    width:100px;
    font-weight: bold;
    color:#fff;
    border:0;
    background:#333;
.search {
    float:right;
    font-weight: bold;
    height: 25px;
.search input {
        width: 200px;
/* PAGING*/
div.pager {
float: left;
div.pager span {
    padding: 5px;
    text-align: center;
    cursor: pointer;
    color: #000;
    color: #FFF
.insert_button {
    padding: 5px;
    cursor: pointer;
    color: #000;
/* COLOR SCALES*/
.green {
    color:#335534;
.orange {
    color:#cf1616;
.red {
    color:#FFF;
    </style>
	<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script>
            paginate();
                    $table.children('tbody').children('tr:not(.exclude)').hide().slice(currentPage * numPerPage, (currentPage + 1) * numPerPage).show();
                var numRows = $table.children('tbody').children('tr:not(.exclude)').length;
                        newPage: page
                    var found = false;
                            found = true;
                            return false;
            paginate();
    </script>
</head>
<body>
                <thead>
                    <tr class="header">
                        <th>Name</th>
                        <th>Email</th>
                        <th>City</th>
                        <th>Country</th>
                    </tr>
                </thead>
    <tbody>
        <tr>
            <td>Wade</td>
            <td>Kemmerer</td>
            <td>Benin</td>
        </tr>
        <tr>
            <td>Leroy</td>
            <td>Alamogordo</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Magee</td>
            <td>Palmdale</td>
        </tr>
        <tr>
            <td>Quamar</td>
            <td>Yemen</td>
        </tr>
        <tr>
            <td>Sebastian</td>
            <td>Durant</td>
            <td>Ethiopia</td>
        </tr>
        <tr>
            <td>Gary</td>
            <td>Mesquite</td>
            <td>Greenland</td>
        </tr>
        <tr>
            <td>Macon</td>
            <td>Paramount</td>
            <td>Tuvalu</td>
        </tr>
        <tr>
            <td>Axel</td>
            <td>Albany</td>
        </tr>
        <tr>
            <td>Neville</td>
            <td>Richmond</td>
            <td>Guinea</td>
        </tr>
        <tr>
            <td>Lamar</td>
            <td>Placentia</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Barrett</td>
            <td>Bellflower</td>
            <td>Ethiopia</td>
        </tr>
        <tr>
            <td>Daquan</td>
            <td>Keene</td>
            <td>China</td>
        </tr>
        <tr>
            <td>Kennan</td>
            <td>Barre</td>
        </tr>
        <tr>
            <td>Wing</td>
        </tr>
        <tr>
            <td>Elijah</td>
            <td>Sandy</td>
            <td>Uruguay</td>
        </tr>
        <tr>
            <td>Jackson</td>
            <td>Centennial</td>
            <td>Indonesia</td>
        </tr>
        <tr>
            <td>Lane</td>
            <td>Ogdensburg</td>
            <td>Argentina</td>
        </tr>
        <tr>
            <td>Devin</td>
            <td>Kearns</td>
        </tr>
        <tr>
            <td colspan="4">
                <table>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                </table>
            </td>
        </tr>
        <tr>
            <td>Logan</td>
            <td>Eureka</td>
            <td>Mayotte</td>
        </tr>
        <tr>
            <td>Zane</td>
            <td>Duarte</td>
            <td>Martinique</td>
        </tr>
        <tr>
            <td>Gregory</td>
            <td>Manassas</td>
        </tr>
        <tr>
            <td>Dennis</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Dennis</td>
            <td>Vail</td>
        </tr>
        <tr>
            <td>Isaac</td>
            <td>Winooski</td>
            <td>Mali</td>
        </tr>
        <tr>
            <td>Lucius</td>
            <td>Palau</td>
        </tr>
        <tr>
            <td>Damon</td>
            <td>ac@dui.edu</td>
            <td>Nampa</td>
        </tr>
        <tr>
            <td>Colorado</td>
            <td>Zimbabwe</td>
        </tr>
        <tr>
            <td>Lawrence</td>
            <td>Evansville</td>
            <td>Peru</td>
        </tr>
        <tr>
            <td>Philip</td>
        </tr>
        <tr>
            <td>Solomon</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Craig</td>
            <td>Richmond</td>
        </tr>
        <tr>
            <td>Lucas</td>
            <td>Holyoke</td>
            <td>Greenland</td>
        </tr>
        <tr>
            <td>Orlando</td>
            <td>Ponce</td>
            <td>Turkey</td>
        </tr>
        <tr>
            <td>Martin</td>
            <td>Toledo</td>
            <td>Zambia</td>
        </tr>
        <tr>
            <td>Hakeem</td>
            <td>Nepal</td>
        </tr>
        <tr>
            <td>Mason</td>
            <td>Nampa</td>
        </tr>
        <tr>
            <td>Vladimir</td>
            <td>Trenton</td>
            <td>Brazil</td>
        </tr>
        <tr>
            <td>Colin</td>
        </tr>
        <tr>
            <td>Dean</td>
            <td>Starkville</td>
            <td>Tonga</td>
        </tr>
        <tr>
            <td>Calvin</td>
            <td>Hilo</td>
        </tr>
        <tr>
            <td>Silas</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Abdul</td>
            <td>China</td>
        </tr>
        <tr>
            <td>Callum</td>
            <td>Evanston</td>
        </tr>
        <tr>
            <td>Howard</td>
            <td>Chelsea</td>
        </tr>
        <tr>
            <td>Lawrence</td>
            <td>Hammond</td>
        </tr>
        <tr>
            <td>Jacob</td>
            <td>Murrieta</td>
            <td>Japan</td>
        </tr>
        <tr>
            <td>Malik</td>
        </tr>
        <tr>
            <td>Jonas</td>
            <td>Revere</td>
            <td>Paraguay</td>
        </tr>
        <tr>
            <td>Damian</td>
            <td>Nenana</td>
            <td>Guatemala</td>
        </tr>
        <tr>
            <td>Phillip</td>
            <td>Lawton</td>
        </tr>
        <tr>
            <td>George</td>
            <td>Lubbock</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Ezra</td>
            <td>Butler</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>Hong Kong</td>
        </tr>
        <tr>
            <td>Berk</td>
            <td>Cypress</td>
            <td>Estonia</td>
        </tr>
        <tr>
            <td>Damon</td>
        </tr>
        <tr>
            <td>Cain</td>
            <td>Fajardo</td>
            <td>Egypt</td>
        </tr>
        <tr>
            <td>Hashim</td>
            <td>La Palma</td>
            <td>Djibouti</td>
        </tr>
        <tr>
            <td>Stewart</td>
            <td>Alpharetta</td>
            <td>Bermuda</td>
        </tr>
        <tr>
            <td>Clinton</td>
            <td>Eau Claire</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>Reno</td>
            <td>Bahrain</td>
        </tr>
        <tr>
            <td>Howard</td>
            <td>Namibia</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>Kingston</td>
            <td>Hungary</td>
        </tr>
        <tr>
            <td>Gannon</td>
            <td>Montpelier</td>
            <td>India</td>
        </tr>
        <tr>
            <td>Knox</td>
            <td>Flagstaff</td>
            <td>Thailand</td>
        </tr>
        <tr>
            <td>Adrian</td>
            <td>Malta</td>
        </tr>
        <tr>
            <td>Cole</td>
            <td>Santa Cruz</td>
        </tr>
        <tr>
            <td>Kibo</td>
            <td>Opelousas</td>
            <td>Monaco</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>Nashville</td>
            <td>Cuba</td>
        </tr>
        <tr>
            <td>Joseph</td>
            <td>Burbank</td>
        </tr>
        <tr>
            <td>Aquila</td>
            <td>Viet Nam</td>
        </tr>
        <tr>
            <td>Blaze</td>
            <td>Paramount</td>
        </tr>
        <tr>
            <td>Hector</td>
            <td>Sunbury</td>
        </tr>
        <tr>
            <td>Mannix</td>
            <td>Pine Bluff</td>
            <td>Dominica</td>
        </tr>
        <tr>
            <td>Sean</td>
            <td>Corinth</td>
            <td>Paraguay</td>
        </tr>
        <tr>
            <td>Yoshio</td>
        </tr>
        <tr>
            <td>Warren</td>
            <td>Guyana</td>
        </tr>
        <tr>
            <td>Brenden</td>
            <td>Mesquite</td>
            <td>Bahrain</td>
        </tr>
        <tr>
            <td>Tanek</td>
            <td>Cheyenne</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Tucker</td>
            <td>Williston</td>
            <td>Guyana</td>
        </tr>
        <tr>
            <td>Burke</td>
            <td>Dodge City</td>
        </tr>
        <tr>
            <td>Abbot</td>
            <td>Fitchburg</td>
            <td>Pitcairn</td>
        </tr>
        <tr>
            <td>Kuame</td>
            <td>La Puente</td>
            <td>Albania</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>Bellflower</td>
        </tr>
        <tr>
            <td>Kermit</td>
            <td>Ardmore</td>
            <td>Nauru</td>
        </tr>
        <tr>
            <td>Cruz</td>
            <td>Haiti</td>
        </tr>
        <tr>
            <td>Nolan</td>
            <td>Seward</td>
            <td>Mauritius</td>
        </tr>
        <tr>
            <td>Myles</td>
            <td>Lawndale</td>
            <td>Swaziland</td>
        </tr>
        <tr>
            <td>Emerson</td>
            <td>Meriden</td>
        </tr>
        <tr>
            <td>Dalton</td>
        </tr>
        <tr>
            <td>Graiden</td>
            <td>Durango</td>
            <td>Iraq</td>
        </tr>
        <tr>
            <td>Vincent</td>
            <td>Bandera</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>Reedsport</td>
            <td>Macedonia</td>
        </tr>
        <tr>
            <td>Anthony</td>
            <td>Seattle</td>
            <td>Finland</td>
        </tr>
        <tr>
            <td>Driscoll</td>
            <td>Kettering</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>Richmond</td>
            <td>Mexico</td>
        </tr>
        <tr>
            <td>Branden</td>
            <td>Tyler</td>
            <td>Mongolia</td>
        </tr>
        <tr>
            <td>Steel</td>
            <td>Azusa</td>
        </tr>
        <tr>
            <td>Steven</td>
            <td>Guthrie</td>
            <td>Zimbabwe</td>
        </tr>
        <tr>
            <td>Blaze</td>
            <td>Longview</td>
            <td>Haiti</td>
        </tr>
        <tr>
            <td>Chaney</td>
            <td>Lithuania</td>
        </tr>
        <tr>
            <td>Bruno</td>
            <td>Germany</td>
        </tr>
        <tr>
            <td>Erich</td>
            <td>Naperville</td>
            <td>Hungary</td>
        </tr>
        <tr>
            <td>Lee</td>
        </tr>
        <tr>
            <td>Amos</td>
            <td>Corinth</td>
            <td>Suriname</td>
        </tr>
        <tr>
            <td>Clayton</td>
            <td>Agat</td>
            <td>Bolivia</td>
        </tr>
        <tr>
            <td>Raja</td>
            <td>Las Cruces</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Jackson</td>
            <td>Plano</td>
        </tr>
        <tr>
            <td>Arthur</td>
            <td>Natchez</td>
            <td>Belgium</td>
        </tr>
        <tr>
            <td>Arsenio</td>
            <td>Waterloo</td>
            <td>Malaysia</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>Korea</td>
        </tr>
        <tr>
            <td>Tucker</td>
            <td>Fort Worth</td>
            <td>Tokelau</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>Honduras</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>Merced</td>
            <td>Madagascar</td>
        </tr>
        <tr>
            <td>Rooney</td>
            <td>El Cerrito</td>
            <td>Chad</td>
        </tr>
        <tr>
            <td>Eaton</td>
            <td>Ardmore</td>
            <td>Croatia</td>
        </tr>
        <tr>
            <td>Rahim</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Mohammad</td>
            <td>Ypsilanti</td>
        </tr>
        <tr>
            <td>Xander</td>
            <td>Ireland</td>
        </tr>
        <tr>
            <td>Joel</td>
            <td>Omaha</td>
        </tr>
        <tr>
            <td>Denton</td>
            <td>Laconia</td>
        </tr>
        <tr>
            <td>Grady</td>
            <td>Austin</td>
        </tr>
        <tr>
            <td>Herrod</td>
            <td>Yazoo City</td>
            <td>Turkey</td>
        </tr>
        <tr>
            <td>Dustin</td>
            <td>Morrison</td>
            <td>Israel</td>
        </tr>
        <tr>
            <td>Armando</td>
            <td>Covina</td>
            <td>Slovenia</td>
        </tr>
        <tr>
            <td>Shad</td>
            <td>Jamaica</td>
        </tr>
        <tr>
            <td>Oscar</td>
            <td>Artesia</td>
            <td>Austria</td>
        </tr>
        <tr>
            <td>Justin</td>
            <td>Camden</td>
            <td>Kazakhstan</td>
        </tr>
        <tr>
            <td>Vernon</td>
            <td>Champaign</td>
            <td>Senegal</td>
        </tr>
        <tr>
            <td>Joseph</td>
            <td>Chile</td>
        </tr>
        <tr>
            <td>Malcolm</td>
            <td>La Mirada</td>
            <td>Macao</td>
        </tr>
        <tr>
            <td>Nicholas</td>
            <td>Mequon</td>
            <td>Costa Rica</td>
        </tr>
        <tr>
            <td>Bruce</td>
            <td>Spokane</td>
        </tr>
        <tr>
            <td>Xanthus</td>
            <td>Moraga</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Conan</td>
            <td>Port Huron</td>
        </tr>
        <tr>
            <td>Marvin</td>
            <td>Chico</td>
            <td>Indonesia</td>
        </tr>
        <tr>
            <td>Gareth</td>
            <td>Hollywood</td>
            <td>Iceland</td>
        </tr>
        <tr>
            <td>Felix</td>
            <td>Cedarburg</td>
        </tr>
        <tr>
            <td>Devin</td>
            <td>Ketchikan</td>
        </tr>
        <tr>
            <td>Alec</td>
            <td>Port Huron</td>
            <td>Kuwait</td>
        </tr>
        <tr>
            <td>Garrett</td>
            <td>Davenport</td>
            <td>Thailand</td>
        </tr>
        <tr>
            <td>Camden</td>
            <td>Fullerton</td>
            <td>Poland</td>
        </tr>
        <tr>
            <td>Noah</td>
            <td>Chandler</td>
            <td>Suriname</td>
        </tr>
        <tr>
            <td>Callum</td>
            <td>Providence</td>
            <td>Peru</td>
        </tr>
        <tr>
            <td>Amir</td>
            <td>Ketchikan</td>
            <td>Kiribati</td>
        </tr>
        <tr>
            <td>Phelan</td>
        </tr>
        <tr>
            <td>Lane</td>
            <td>Edina</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Dylan</td>
            <td>Gadsden</td>
        </tr>
        <tr>
            <td>Palmer</td>
            <td>Lodi</td>
            <td>Georgia</td>
        </tr>
        <tr>
            <td>Austin</td>
            <td>Myanmar</td>
        </tr>
        <tr>
            <td>Joshua</td>
            <td>Oman</td>
        </tr>
        <tr>
            <td>Merritt</td>
            <td>Duncan</td>
        </tr>
        <tr>
            <td>Hashim</td>
            <td>Gastonia</td>
            <td>Malaysia</td>
        </tr>
        <tr>
            <td>Sebastian</td>
            <td>Kettering</td>
            <td>Slovenia</td>
        </tr>
        <tr>
            <td>Marvin</td>
            <td>Pine Bluff</td>
            <td>Japan</td>
        </tr>
        <tr>
            <td>Wang</td>
            <td>Argentina</td>
        </tr>
        <tr>
            <td>Paki</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Cody</td>
            <td>Fargo</td>
        </tr>
        <tr>
            <td>Daquan</td>
            <td>Laconia</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Todd</td>
            <td>Meridian</td>
            <td>Denmark</td>
        </tr>
        <tr>
            <td>Oliver</td>
            <td>Staunton</td>
        </tr>
        <tr>
            <td>Nehru</td>
            <td>Ecuador</td>
        </tr>
        <tr>
            <td>Giacomo</td>
            <td>Boston</td>
            <td>Kiribati</td>
        </tr>
        <tr>
            <td>Kirk</td>
            <td>Frankfort</td>
            <td>Ukraine</td>
        </tr>
        <tr>
            <td>Brandon</td>
            <td>Fargo</td>
        </tr>
        <tr>
            <td>Fuller</td>
            <td>Gibraltar</td>
        </tr>
        <tr>
            <td>Thaddeus</td>
            <td>Torrington</td>
        </tr>
        <tr>
            <td>Allen</td>
            <td>Chicopee</td>
            <td>Macao</td>
        </tr>
        <tr>
            <td>Forrest</td>
            <td>Valdez</td>
            <td>Algeria</td>
        </tr>
        <tr>
            <td>Steven</td>
            <td>Cary</td>
            <td>Uganda</td>
        </tr>
        <tr>
            <td>Stone</td>
            <td>Redding</td>
            <td>Lesotho</td>
        </tr>
        <tr>
            <td>Brian</td>
            <td>Attleboro</td>
            <td>Anguilla</td>
        </tr>
        <tr>
            <td>Ferris</td>
            <td>Agat</td>
            <td>Ireland</td>
        </tr>
        <tr>
            <td>Aaron</td>
        </tr>
        <tr>
            <td>Bradley</td>
            <td>Baltimore</td>
            <td>Reunion</td>
        </tr>
        <tr>
            <td>Jesse</td>
            <td>Dana Point</td>
            <td>Algeria</td>
        </tr>
        <tr>
            <td>Wade</td>
            <td>Vicksburg</td>
        </tr>
        <tr>
            <td>Gareth</td>
            <td>Wheeling</td>
            <td>Niger</td>
        </tr>
        <tr>
            <td>Avram</td>
            <td>Honolulu</td>
            <td>Portugal</td>
        </tr>
        <tr>
            <td>Alec</td>
            <td>Pittsburgh</td>
            <td>Togo</td>
        </tr>
        <tr>
            <td>Luke</td>
            <td>Cicero</td>
            <td>Bermuda</td>
        </tr>
        <tr>
            <td>Hyatt</td>
        </tr>
        <tr>
            <td>Jason</td>
            <td>Bulgaria</td>
        </tr>
        <tr>
            <td>Jameson</td>
            <td>Gilette</td>
            <td>Barbados</td>
        </tr>
        <tr>
            <td>Conan</td>
            <td>Macedonia</td>
        </tr>
        <tr>
            <td>Len</td>
            <td>Calabasas</td>
        </tr>
        <tr>
            <td>Abdul</td>
            <td>Duncan</td>
            <td>Uzbekistan</td>
        </tr>
        <tr>
            <td>Levi</td>
            <td>Carbondale</td>
            <td>Spain</td>
        </tr>
        <tr>
            <td>Hop</td>
            <td>Ansonia</td>
            <td>Tonga</td>
        </tr>
        <tr>
            <td>Nissim</td>
            <td>Newburgh</td>
            <td>Pitcairn</td>
        </tr>
        <tr>
            <td>Wade</td>
            <td>Guánica</td>
            <td>Kyrgyzstan</td>
        </tr>
        <tr>
            <td>Brennan</td>
            <td>Meridian</td>
            <td>Venezuela</td>
        </tr>
        <tr>
            <td>Dolan</td>
            <td>La Palma</td>
            <td>Togo</td>
        </tr>
        <tr>
            <td>Allistair</td>
            <td>Kennewick</td>
            <td>Zambia</td>
        </tr>
        <tr>
            <td>Holmes</td>
            <td>Jordan</td>
        </tr>
        <tr>
            <td>Jarrod</td>
            <td>Wichita</td>
        </tr>
        <tr>
            <td>Aristotle</td>
            <td>Brown Deer</td>
        </tr>
        <tr>o
            <td>Acton</td>
        </tr>
        <tr>
            <td>Harper</td>
            <td>Costa Mesa</td>
        </tr>
        <tr>
            <td>Cole</td>
            <td>Lima</td>
            <td>Canada</td>
        </tr>
    </tbody>
            </table>
</body>
</html>
LVL 1
Author Comment
by:awilderbeast
thats the trick!!!
thanks alot for all your help
LVL 60
Expert Comment
by:Julian Hansen
Awsome - thanks for the points and you are welcome
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
Requirements JQuery 1.6+ HTML CSS Introduction This article was inspired by an EE question (http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_28372511.html) on how to make a page show some balloons animate up a page…
How to build a simple, quick and effective accordion menu using just 15 lines of jQuery and 2 css classes
The viewer will learn the basics of jQuery, including how to invoke it on a web page. Reference your jQuery libraries: (CODE) Include your new external js/jQuery file: (CODE) Write your first lines of code to setup your site for jQuery.: (CODE)
The viewer will learn the basics of jQuery including how to code hide show and toggles. Reference your jQuery libraries: (CODE) Include your new external js/jQuery file: (CODE) Write your first lines of code to setup your site for jQuery…
Suggested Courses
Course of the Month20 days, 10 hours left to enroll
867 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
