Need macro to import parts of Purchase Order in custom csv format into excel (Part 1)
I have sample csv format Order-34865510V-MincomCSV-edited.txt that is used for purchase order to our company.
The problem is that file contains too many information that we don't need.
As you can see, there's no header information, the format (from our buyer) is:
- PO Header (with 94 fields <fields started with 0> separated by , (comma))
- PO Item 1 (with 42 fields separate by ,)
- PO Item 2 etc
Note:
Asterisk (*) is used to separate each item.
Comma (,) is used for data separation
" for encapsulation and escape character.
From that csv files, I just need
- PO Order Number (field 1 just after PO Header) in this case 34865510V
- Store number (field 27) in this case 0524
- GTIN number for each products (field 18 after *POITEM),  for PO Product 1 : 2885730000005
- Weight of each products (field 6 after *POITEM), for Product 1 : 6
And considering I have so many purchase order, I'm thinking to put all csv files into the same folder and let the macro run through all csv files in that folder and after finished with it, move it to "processed" folder.
So in short,
- Need a macro to process all csv files in some directory (need user input for the directory name)
- Input the data into corresponding spreadsheets in the same workbook (Part 2)
- Move the processed csv files into a subfolder called "Processed on "today date""
Continue to part 2.
Book1.xlsx
m888Asked:
aikimarkConnect With a Mentor Commented:
Open up your book1.xlsx workbook and open a new workbook.  Insert a module into the new workbook and add the following code.  Change the path in the string literal for the cVendorFilename constant to one of your vendor files.  Run the routine and inspect the results.
Option Explicit
Public Sub Q_27867545()
    'Merges data from single vendor file into worksheet(s), based on G1 data = store number
    Dim intFN As Integer
    Dim strVendorData As String
    Dim strHeaderDetail() As String
    Dim lngLine As Long
    Dim strLineParsed() As String
    Dim wks As Worksheet
    Dim rng As Range
    Const cVendorFilename As String = "C:\Users\AikiMark\Downloads\Imported CSV\Order_34865513V_MincomCSV_edited.txt"
    Dim strPO As String
    Dim strStore As String
    Dim dicItems As Object
    Const cWeight As Long = 1
    Const cGTIN As Long = 2
    Set dicItems = CreateObject("scripting.dictionary")
    intFN = FreeFile
    Open cVendorFilename For Input As #intFN
    strVendorData = Input(LOF(intFN), #intFN)
    Close #intFN
    strHeaderDetail = Split(strVendorData, "*POITEM,")
    strLineParsed = Split(strHeaderDetail(lngLine), ",")
    strPO = strLineParsed(1)
    strStore = strLineParsed(39)
    ReDim vPOItems(1 To UBound(strHeaderDetail), cWeight To cGTIN)
    For lngLine = 1 To UBound(strHeaderDetail)
        dicItems.Add strLineParsed(17), strLineParsed(5)
    Next
    For Each wks In Workbooks("book1.xlsx").Worksheets
        If wks.Range("G1").Value = Val(strStore) Then
            wks.Range("C3").Value = strPO
            For Each rng In wks.Range(wks.Range("A6"), wks.Range("A6").End(xlDown)).Cells
                If dicItems.exists(rng.Text) Then
                    rng.Offset(0, 4).Value = dicItems(rng.Text)
                Else
                    Debug.Print "GTIN not found: " & rng.Value
                End If
            Next
            Exit For
        End If
    Next
    dicItems.RemoveAll
End Sub
Note: there can only be one Option Explicit statement
Having the code in a separate workbook allows you to close/open the book1.xlsx file between tests and to rerun the tests independently of any code changes you make.
aikimarkCommented:
I didn't find an acceptable regexp pattern for this, so I'll suggest the following.
    'Note: strPO contains the CSV text you posted
    Dim strPO As String
    Dim lngLine As Long
    strHeaderDetail = Split(strPO, "*POITEM,")
    Debug.Print "PO Order Number:", strLineParsed(1)
    Debug.Print "Store number:", strLineParsed(39)
        Debug.Print "Weight:", strLineParsed(5)
        Debug.Print "GTIN number:", strLineParsed(17)
    Next
m888Author Commented:
And how do I import all the csv files in a directory ?
I tried macro recording and ended up with this code
Sub Macro1()
' Macro1 Macro
    With ActiveSheet.QueryTables.Add(Connection:= _
        "TEXT;G:\Download\IDM\Order_34865510V_MincomCSV_edited.txt", Destination:=Range( _
        "$A$1"))
        .Name = "Order_34865510V_MincomCSV_edited.txt"
        .FieldNames = True
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .TextFilePromptOnRefresh = False
        .TextFilePlatform = 850
        .TextFileStartRow = 1
        .TextFileParseType = xlDelimited
        .TextFileTextQualifier = xlTextQualifierDoubleQuote
        .TextFileConsecutiveDelimiter = False
        .TextFileTabDelimiter = False
        .TextFileSemicolonDelimiter = False
        .TextFileCommaDelimiter = False
        .TextFileSpaceDelimiter = False
        .TextFileOtherDelimiter = "*"
        .TextFileColumnDataTypes = Array(1, 1, 1, 1, 1)
        .TextFileTrailingMinusNumbers = True
        .Refresh BackgroundQuery:=False
    End With
End Sub
Cloud Class® Course: SQL Server Core 2016
This course will introduce you to SQL Server Core 2016, as well as teach you about SSMS, data tools, installation, server configuration, using Management Studio, and writing and executing queries.
aikimarkCommented:
although you posted a workbook, it does not contain the data in your vendor file. I think there are some missing mappings in your problem description.
I'm sorry, but I don't understand what you meant by "missing mappings"
I'm new with this excel macro script, so if possible I need a complete macro script to solve Part1 and Part2 of my problem together.
The problem is:
aikimarkCommented:
iterating files is not a problem, so I tackled the difficult part of the task first (parsing the data)
At this point, I'm looking at the second part of the problem in detail.
In order to move data from the vendor file into worksheets, there needs to be a well defined 'mapping' of data in the vendor file and where it is to be placed in any particular worksheet. Since you use the word "corresponding", consider the details of that to be what I call "mapping"
aikimarkCommented:
I've looked at your sample vendor files and the workbook you posted in the second part to this question.
Will your worksheets contain the same GTIN values that are found in the POITEM segments?
Will there always be ten POITEM segments? (I've noticed the same GTIN values appearing in the four worksheets)
yes. there will be same GTIN values for all stores.
But not all store will order the same item (unlike in the sample workbook) each time.
I did change the quantity ordered for each csv though.
And no, there won't be always ten POItem.
There will be a lot more, I just use ten because that's the smallest order we got (so easier to test?)
aikimarkCommented:
>>so easier to test?
While it might be easier to test, the solution you get is likely to not be flexible.  When you post sample data, it should be representative of the problem, not cherry picked to be 'easy'.
I uploaded another csv file containing 30 POItems with store id that matched with store 2.
Order-34898704V-MincomCSV-edited.txt
aikimarkCommented:
How is the import process supposed to treat a 30 item list against the 10 item GTIN list in the worksheet?
Since we are in part 1, I think it is time to suggest there may be a different way to think about importing the data.  Rather than doing a matching update, based on cell values, the import process might create worksheets from scratch.
Actually in the actual workbook / sheets there will be enough GTIN data to compare it with.
We have 93 items in the actual workbook.
This is just a sample workbook similar with the actual one.
You will get more confused when you see actual workbook :)
As long as the macro works with the zip file. I'm happy to accept that as solution.
Should be able to change it to match the actual workbook (given time)
I am not keen on creating new worksheets because that's the format our employees & factory used to work with.
Please ignore the csv file that contains 30 items :)
aikimark, any news re this ?
just wondering since there's no reply from you since 3 days ago.
thank you if you are!
Inspecting it now.
That's great. Thank you so much.
Managed to get it to work with my current workbook!
Need some update though.
- If there's a row between GTIN, the script stop working.
Is there any way to check for this ? It's not important though, can edit the worksheets to delete empty GTIN row (used for product category name)
- By "Note: there can only be one Option Explicit statement", do you mean I can't execute the same macro again after the first use? (basically closing and reopening the workbook before i use the macro?)
I don't think so, because based on google search that statement is used to make sure that all the variables are declared?
But just wanted to make sure.
- Need that multiple file import function if possible :)
- And also, after particular csv files have been done, they will be moved to subfolder called "Processed" and add current date in front of the file name. Example :
From G:\Puchase Order\Imported CSV\Order_35008850V_MincomCSV.txt
to G:\Puchase Order\Imported CSV\Processed\2012_09_todaydate_Order_35008850V_MincomCSV.txt
Other than that, it works beautifully!
Thanks again!
aikimarkCommented:
When you posted a workbook, you did not include a worksheet with empty GTIN numbers.  Please post another workbook with representative examples of such missing/empty cells.
Depending on your VB project options, all new modules and forms may require variable declaration and include an Option Explicit statement.  Since my code includes that statement, I included the note that only one such statement was allowed.  It only affects variable declaration and not the number of times you can execute the routine.
What about the Quantity column?  Doesn't the vendor file include that data?
>>multiple files and post-processed handling
Since you created a second question, I'm going to address that part of your problem in the other question thread. It was more important to get the single file processing correct first.
Don't worry about the missing cells.  But Basically it's the same worksheets with a row inserted between 2 items to put category label, but i will change it to the side so there won't be any missing row.
The weight is actually going to quantity column and then the weight column will be entered manually with actual weight. I've already modified the macro so it will go into the weight column.
So i think i will close this question and accepted your previous to last comment as the answer.
Awaiting the solution for part 2!
Thanks!
aikimarkCommented:
Since you've changed the code, please post it in this thread.
I just change this line
To
rng.Offset(0, 3).Value = dicItems(rng.Text)
