m888
Need macro to import parts of Purchase Order in custom csv format into excel (part 2)
Continuing from part 1 (https://www.experts-exchange.com/questions/27867545/Need-macro-to-import-parts-of-Purchase-Order-in-custom-csv-format-into-excel-Part-1.html)
After importing each csv file, macro will need to enter the data into a correct spreadsheet after comparing the "store number" value. (sample excel file included) Book1.xlsx
So for example, if a csv file contains store number 0524, it will match with spreadsheet called "Store 1" based on the G1 value in that spreadsheet.
The macro will then continue entering the weight of each product into a specific product after comparing the GTIN value.
What do you want to call the sheets?
The sheets will be store 1, store 2, store 3 etc.. (as in the Book1.xlsx sample workbook)
Where do those values come from?
The workbook already exist as well as the sheets name.
Obviously it won't be named store1, store2 etc but the correct store name <abbreviated> and without the store id.
That's why I need to check the value at G1 (or might be place anywhere else) against the store id from the csv file to make sure the imported data stored in the right sheet.
Are you saying that the store id will not be in G1? If so, I'm more confused.
What if there isn't a corresponding store value in any of the worksheets at G1?
I meant not specifically in G1, maybe F1 etc..
Although unlikely but if there's no corresponding store value then that specific csv file will not be moved to "processed" folder.
Thank you for taking the time on this problem.
Appreciate it!
Appreciate it!
Here's an idea. upload a zip file containing 3-5 different vendor files and a workbook that contains a mixture of matching and not matching (or missing) store numbers.
Ok. Did that.
Made a zip including directory structure that I use.
I modified the workbook so it contains 4 stores.
And include 5 csv files with 4 matching store number and 1 non-matching store.
Btw, when moving the data to the matched sheet, can you also include the PO No on field C3?
Thanks again.
Puchase-Order.zip
Thanks again.
Puchase-Order.zip
Thanks. Comments in the prior thread (part 1).
Working great!
The only problem is that if it's processed, it will be moved to
C:\Users\AikiMark\Download s\Imported CSV\Processed\YYYY MM DD\ --> (today date)
if the directory doesn't exist it will create, but if it's exist just move the file.
No where in your problem description, part1 or part 2, do you state this. Is this a new requirement?
I did mention it in part 1
"- Move the processed csv files into a subfolder called "Processed on "today date""
But i thought instead of "processed on today date" folder, it would be better to move it to directory imported csv >> processed >> today date.
But i think i should post this as new question? Let me know.
Yes. You did. And you supplied a similarly named folder in your zip file.
But there was nothing to the effect that the program needs to create a folder with such a name if it doesn't exist. I assumed that you were creating the folder by some other process, manual or otherwise.
This version of the driver routine should come close to what you need.
Public Sub Q_27868780()
'processes vendor files
Const cVendorFilePath As String = "C:\Users\AikiMark\Downloads\Imported CSV\"
Const cProcessedPath As String = "C:\Users\AikiMark\Downloads\Imported CSV\Processed on "
Dim strProcessedPath As String
Dim strFilename As String
strProcessedPath = cProcessedPath & Format(Now, "yyyy_mm_dd")
If Len(Dir(strProcessedPath, vbDirectory)) = 0 Then
MkDir strProcessedPath
End If
strProcessedPath = strProcessedPath & "\"
strFilename = Dir(cVendorFilePath & "*.txt")
Do Until Len(strFilename) = 0
If Q_27867545(cVendorFilePath & strFilename) = True Then
'move to processed directory
FileCopy cVendorFilePath & strFilename, strProcessedPath & strFilename
Kill cVendorFilePath & strFilename
End If
strFilename = Dir
Loop
End Sub
Thanks a lot for your help aikimark!
It's all works perfectly!
