Avatar of Anjeneya Murthy
Anjeneya MurthyFlag for India
Need help in using System.Configuration collections
I am trying to parse the application configuration file. I am required to use the System.Configuration in the code to access the sections.
The configuration goes as below
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
  <configSections>
    <section name="CopyFiles" type="ConfigManagerTest.Config.CopyFilesSection, ConfigManagerTest"/>
  </configSections>
  <CopyFiles><!--Section-->
    <CopyFile><!--CopyFileCollection : ConfigElementCollection-->
      <Destination path="Location1"/><!--DestinationPath: ConfigElement-->
      <Files><!-- FilesCollection: ConfigElementCollection-->
        <clear/>
        <add FileName=""/>
        <add FileName=""/>
      </Files>
    </CopyFile>
    <CopyFile>
      <Destination path="Location2"/>
      <Files>
        <clear/>
        <add FileName=""/>
        <add FileName=""/>
      </Files>
    </CopyFile>
    <CopyFile>
      <Destination path="Location3"/>
      <Files>
        <clear/>
        <add FileName=""/>
        <add FileName=""/>
      </Files>
    </CopyFile>
  </CopyFiles>
</configuration>
Q1. Is it possible to use configuration classes to achive the purpose shown above?
I have created separate classes for this. Please review and let me know where I am going wrong!
I am not good at using Configuration classes. My guess is "probably we cannot use the properties like Destination and Files collection in CopyFilesCollection"
Please help. I have done my best and now turned for help.
I dont know how I can use "add" for CopyFile in the app config file.
The complete code is attached in the .zip file
To-ExpertsExchange.zip
Avatar of Easwaran Paramasivam
Flag of India image
Yes it is possible. You could achieve using the code looks like given below.
Please do refer the links
http://www.codeproject.com/Articles/32490/Custom-Configuration-Sections-for-Lazy-Coders
http://msdn.microsoft.com/en-us/library/2tw134k3(v=vs.100).aspx
http://blogs.msdn.com/b/aspnetue/archive/2008/10/02/system-configuration-configurationmanager-source-c.aspx
http://www.codeproject.com/Articles/163081/Custom-Configuration-Sections-in-NET
//Read config file
Configuration config =
                ConfigurationManager.OpenExeConfiguration(path);
//Add custom section
config.Sections.Add("MySection", instance);
//Save the modified file.
config.Save(ConfigurationSaveMode.Modified);
Anjeneya Murthy
Flag of India image
Found the answer myself. Will update here as soon as possible
