rgb192
creating a function from a regex and returning two parts
this question is about creating a function from question
https://www.experts-exchange.com/questions/27998518/want-only-the-email-address-from-email.html
i need to use $matches[0] and $matches[1]
$email = " Ray <ray.paseur@gmail.com>"
// A REGULAR EXPRESSION TO FIND THE FROM-EMAIL ADDRESS
$regex
= '#' //REGEX DELIMITER
. '.*?' // ANYTHING OR NOTHING
. '\<' // ESCAPED WICKET
. '(.*?)' // GROUP OF CHARACTERS WITH EMAIL ADDRESS
. '\>' // ESCAPED WICKET
. '#' // REGEX DELIMITER
// ISOLATE THE FROM EMAIL ADDRESS
preg_match($regex, $email, $matches);
$from = $matches[1];
function emailregex(){
$regex
preg_match($regex, " Ray <ray.paseur@gmail.com>" , $matches);
return $matches;
when I test
$matches[0] is the name 'ray'
and
$matches[1] is the email
and
if I do
return array($matches[0], $matches[1]);
I dont know how to call and echo
Are you referring to?
$result = emailregex();
echo $result[0];
echo $result[1];
echo $result[0];
echo $result[1];
echo $result[0];
echo $result[1];
Ray's code take the parameter. So it works for me.
I cant understand how to do an empty function() with this
thanks
thanks
Not sure I understand empty function() either, but thanks for the points. You might consider something like this...
function emailregex($str=FALSE)
if (!$str) return array();
/* etc */...
Well, I'm certainly glad that question was clear : \
@kaufmed: Me too.
