Solved
Problem while running python script
Posted on 2013-01-19
9
Last Modified: 2013-02-10
I have written a program in python, while i am executing it gives a error.here is the last lines of program where i am getting error.
if__name__  == "__main__"
    main()
root#./abc.py
File "./abc.py", line 23
   main()
IdentationError: unexpected ident
Question by:pawanopensource
  • 5
  • 4
9 Comments
Author Comment
by:pawanopensource
i think its a problem replated to spacing in program, i am not able to figure out though.
LVL 25
Accepted Solution
by:
clockwatcher earned 2000 total points
You're missing a colon at the end of your if statement.
    main()
should be:
if__name__  == "__main__":
    main()
Author Comment
by:pawanopensource
here is the script and error screen short. plz let me know what mistake i have made.
LVL 25
Expert Comment
by:clockwatcher
Ok... that's not the same error that you posted previously, but the error is pretty self explanatory.  It can't open the file passwords.txt which means either the file doesn't exist in your current directory or if it does, the user account that you're running as doesn't have permissions to it.
Author Comment
by:pawanopensource
Yes you are right. passwords.txt dosent exist.
1 How to make password.txt in current directory
    vi /etc/passwd
     abc:x:1000:1000:UBUNTU,,,:/home/abc:/bin/bash
2 How to give permission to the user abc.
Thx
LVL 25
Expert Comment
by:clockwatcher
You can copy it there:
  cp /etc/password ./passwords.txt
To give read permission to it:
  chmod o+r ./passwords.txt
And I'm going to guess at your next question and tell you that you'll need a dictionary file in the same directory called dictionary.txt that contains a password guess per line.
LVL 25
Expert Comment
by:clockwatcher
And lastly... you're using a system that is using shadow passwords.  Your /etc/passwd file doesn't contain the hashed passwords in it.  You'd probably want to run it against /etc/shadow.
Author Comment
by:pawanopensource
i have created passwords.txt in the python 2.7 directory. when i am running this program there is no error. but it should prompt password found for user, which it is not doing so.
Author Comment
by:pawanopensource
bro plz guide me, i know i am asking very basic things but plz consider it, as i am not a
python guy or a programmer,i am kid in python or any programming language.
path where python is stored
root# cd /usr/lib/python2.7/passwdcrack.py
Plz guide me according to this path,
how to run /etc/passwd against /etc/shadow
how to copy passwords.txt
how to make dictionary.txt
Thx a ton
We value your feedback.
Dictionaries contain key:value pairs. Which means a collection of tuples with an attribute name and an assigned value to it. The semicolon present in between each key and values and attribute with values are delimited with a comma.  In python we can…
Windows Script Host (WSH) has been part of Windows since Windows NT4. Windows Script Host provides architecture for building dynamic scripts that consist of a core object model, scripting hosts, and scripting engines. The key components of Window…
The viewer will learn how to implement Singleton Design Pattern in Java.
This video teaches viewers about errors in exception handling.
Suggested Courses
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
