Best way to respond to specific parts of a formal outline in MS Word
This question relates only in part to the technical use of MS Word. However, based on the assumption that those who have developed an expertise in MS Word software also have much knowledge and experience using it, I'm hopeful that someone can suggest a good solution.
Suppose you have been asked to respond to a formal hard-copy document (for which you have a corresponding Word doc file) which has been prepared with the structure of a typical outline. For example:
A. This is a 1st level paragraph.
        1. This is a 2nd level paragraph.
                a. This is a 3rd level paragraph.
                b. This is a 3rd level paragraph.
                        i. This is a 4th level paragraph.
        2. This is a 2nd level paragraph.
B. This is a 1st level paragraph.
In other words, all paragraphs and subparagraphs at various levels, each have a unique numbering reference.
What is the best way to format the response? For example, when the same thing occurs in e-mails, I notice that respondors commonly reply by interserting comments of a different font color directly following the clause to which they relate. However, that seems a bit less than ideal for hard copies since subsequent photocopies, etc., may not reproduce the differences in color.
Another option is to reply with a separate document which includes only paragraph references but not the specific text found in the initial document. That of course, eliminates the convenience of having the initial clause immediately accessible as it is with the previous approach.
Is there a standard or commonly-used method for responding to formal documents (i.e. a method that is simple and straightforward to prepare and that clearly identifies responses vs. original content? If so, is functionality built into MS Word to make it easily doable.
Thanks.
Steve_Brady
Steve_Brady
  • 2
2 Solutions
tvedtemCommented:
Try the comments feature. Select the text then choose Review -> New Comment
Steve_BradyAuthor Commented:
Thanks for the response.
I am familiar with using comments. However, as far as I know, they can only be displayed in in balloons or a separate panel. Is there another way to display them, for example, inserted among the existing text? If so, I think that would do the trick.
Chris BottomleyCommented:
I would agree that comments is potentially the way to go.  Visibility depends on your version for example in 2010 on the tracking pane of the review tab you can:
1. Select display for review option to for example final showing markup AND
2. Show markup - ensure comments are selected
You also have the option to select the reviewing pane but I would imagine the inline display will do the job.
Chris
Comments are much appreciated.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
  • 2
