Solved
Exchange 2010 Power Shell script delete content issue
Posted on 2013-01-31
Last Modified: 2013-07-25
As a result of trying to do 15 things at once and not paying closer attention to my cmd line syntax, I made a little booboo.
Goal: To delete all of my messages in my Deleted Items on the 2010 Exchange server using Exchange Power Shell (PS). That's it! No more, no less.
Syntax used:  Search-Mailbox -Identity "Peter Mitchell" -TargetFolder "\DeletedItems" -LogLevel Full -DeleteContent
TargetMailbox: ITSupport
Issue: Being used to syntax in Exchange 2007, I had what I thought was the correct syntax for 2010. However as a result of assumption and not paying close, undivided attention I did not.
Result: My entire Inbox/subfolders and calendar wiped out clean. Not my intention for that to happen as the intention was to ONLY delete the items from my Deleted Items folder.
From there, and as I inadvertently instructed the PS to do, it moved all of my Inbox/subfolders to the ITSupport mailbox and created a new folder called "\DeletedItems" (which I know have learned I inadvertently instructed it to do!). The full path was actually "\DeletedItems\Peter Mitchell-1/31/2013 5:51:16 PM\Primary Mailbox\[Calendar, Contacts,Deleted Items,Drafts,Inbox,Recoverable Items,Sent ITems,Suggested Contacts,SyncIssues,Tasks]  (listed in folder tree under Primary Mailbox)
Magic question is....where did I go so wrong? (aside from excessively multi-tasking!)?  And what is the correct Exchange PS cmd line syntax to just delete messages from a given folder in a given mailbox?
Any help would be greatly appreciated for this valuable lesson learned!
Question by:goodwill1
3 Comments
LVL 5
Assisted Solution
by:coraxal
coraxal earned 750 total points
The cmdlet you're looking for is:  Export-Mailbox with the "-IncludeFolder" parameter
Export-Mailbox -Identity "Mailbox Name" -IncludeFolder "\Deleted Items" -DeleteContent
LVL 16
Accepted Solution
by:
Rajitha Chimmani earned 750 total points
The mistake that you did was "you did not specify any folders from which emails must be deleted and hence all emails were deleted"
With search-mailbox command you can only delete emails from entire mailbox.
You need to use Export-mailbox to delete items from specific folders.
Export-Mailbox "Peter Mitchell" -TargetMailbox "ITSupport" -TargetFolder "Mitchell" -IncludeFolders "\DeletedItems" -DeleteContent
Author Closing Comment
by:goodwill1
Hire Technology Freelancers with Gigs
Work with freelancers specializing in everything from database administration to programming, who have proven themselves as experts in their field. Hire the best, collaborate easily, pay securely, and get projects done right.
There can be many situations demanding the conversion of Outlook OST files to PST format and as such, there is no shortage of automated tools to perform this conversion. However, what makes Stellar OST to PST converter stand above the rest? Let us e…
Exchange administrators are always vigilant about Exchange crashes and disasters that are possible any time. It is quite essential to identify the symptoms of a possible Exchange issue and be prepared with a proper recovery plan. There are multiple…
In this video we show how to create an Address List in Exchange 2013. We show this process by using the Exchange Admin Center. Log into Exchange Admin Center.: First we need to log into the Exchange Admin Center. Navigate to the Organization >> Ad…
To add imagery to an HTML email signature, you have two options available to you. You can either add a logo/image by embedding it directly into the signature or hosting it externally and linking to it. The vast majority of email clients display l…
Suggested Courses
571 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
