I'm looking for the solution to a practical maths problem that is way beyond my level of competence
Graeme_Sm
Graeme_Sm used Ask the Experts™
on
I'm not sure if this is the appropriate site to pose this, and if not I'm open to suggestions of sites where I might more appropriately directed it (if that is not against the EE terms-of-use).
The problem below I thought at first this would be a fairly simple, but it turns out to be a lot more complicated than I first anticipated.  I was good at maths at school, but that was 20 years ago and after attempting this I've realized it is beyond my scope..
I have 3 known inputs, LongStdDev, ShortStdev and MarketStdev.  And I have two targeted inputs, PortfolioBeta and PortfolioStdev.
I only have two variables, LongWeight and ShortWeight.
PortfolioBeta = LongWeight - ShortWeight
PortfolioStdev = Sqrt((LongWeight*LongStdev)^2 + (ShortWeight*ShortStdev)^2 + (abs(LongWeight-ShortWeight)*MarketStdev)^2)
From these two formulas and five inputs is it possible to calculate the LongWeight (and by Inference the ShortWeight)?  Trying to use what I remember from high school maths I hit a wall when I try to substitute {PortfolioBeta-LongWeight} for {ShortWeight} and then square it.
Watch Question
Do more with
Expert Office
Dave BaldwinFixer of Problems
Most Valuable Expert 2014
Since your first equation has two unknowns in it, the only way to solve the system of equations is by substitution.  A spreadsheet could make the calculations go quickly.  I'm not sure that there is only a single answer though.
It is easy enough to get it down to one unknown since LongWeight = ShortWeight + PortfolioBeta.  However I'm not sure how to move that one variable to the left hand side of the equation because it ends up in a quadratic formula (a + bX + cX^2)
No, LongWeight = ShortWeight + PortfolioBeta is still 2 unknowns.  Actually, it's 3 because you don't have a value for any of them.  There is simply not enough info for a numerical solution.
Learn Ruby Fundamentals
This course will introduce you to Ruby, as well as teach you about classes, methods, variables, data structures, loops, enumerable methods, and finishing touches.
PortfolioBeta is a known, the five inputs are all known.  So once either the Long or Short Weight is calculated the other is known.
The formula can be substituted to :
PortfolioStdev^2 = (LongWeight*LongStdev)^2 + ((LongWeight-PortfolioBeta)*ShortStdev)^2 + (abs(PortfolioBeta)*MarketStdev)^2
so that LongWeight is the only unknown variable.  However this expands into a quadratic equation so I don't know how to move LongWeight to the left hand side.
I can't help you then.  Click on "Request Attention" above to get others to look at your question.  Since it is Friday evening, it may take a while.
A quadratic
aX²  + bX + c = 0
has solutions
x = ( -b ± sqrt( b² - 4ac) )/2a
This has 2 solutions. My guess for your problem one of them won't make physical sense and as such can be discarded.
Thanks Gwyn,
That was exactly what I was looking for.
Do more with
Expert Office
Start 7-Day Free Trial
