SharePoint Multiple Calendars and JQuery tabbed web parts
The link below is a solution for a tabbed web part solution that works great. But when I add two SharePoint calendars to the web part zones, the second calendar does not display correctly.
http://sharepointjournals.wordpress.com/2011/06/30/arranging-web-parts-in-jquery-tab-tabs/
Does anyone have any ideal what might cause the conflick.
LVL 1
Tec-FuturesAsked:
Rainer JeschorConnect With a Mentor Commented:
the issue is that the calendar uses a lot of client side Javascript events and dynamic positioning.
It works as soon as you select the calendar web part, changing the view through the calendar ribbon to e.g. week/day and then back.
But just by knowing where the issue is, doesn't make it easier to solve - as this will take a lot of client side debugging.
HTH
Rainer
Tec-FuturesAuthor Commented:
The response doesn't solve the problem.
I've requested that this question be deleted for the following reason:
The answer doesn't solve the problem.
