Avatar of egoselfaxis
egoselfaxis
Jascript issue: Need help replacing spaces with %20 in get parameters
I'm having a very difficult time getting my javascript function to preserve (or convert) spaces when concatenating query string parameters for a search form:
Here is the form:
http://www.homerep.com/
And here is a link to the JS file:
http://www.homerep.com/wp-content/themes/twentyten/js/home_search.js
The problem that I'm having is that spaces are NOT being preserved when choosing a City from the select dropdown that's labeled "Search Any South Florida City".  For whatever reason, . the spaces are being completely stripped out.
So when you choose - say - "Fort Lauderdale" from the dropdown, .. it results in the following incorrect query string parameter:
&Cities=FortLauderdale
... when it should be either "&Cities=Fort Lauderdale" or "&Cities=Fort%20Lauderdale"
I've tried using encodeURI(), .. encodeURIComponent(), and replace() javascript functions .. but none of them are working.  Seriously .. I've been tinkering with these functions for nearly 2 hours already, and I can't for the life of my figure out what's going on.
What do I need to do/change in my javascript to ensure that the spaces in the selected City Names are preserves with assembling the query string parameters?
- Yvan
Avatar of Michel Plungjan
Michel Plungjan
Flag of Denmark image
Change
+ queryString
to
+ encodeURIComponent(queryString)
So
FinalUrl = "/" + this.URL_Root + "&PerformSearch" + encodeURIComponent(queryString);
Also no need to navigate:
  window.location = FinalUrl;
can replace
if(typeof window.navigate != "undefined"){
  window.navigate(FinalUrl);
} else {
  location.href = FinalUrl;
OOps. I re-read your code.
you need to change all
xxx.value to
encodeURIComponent(xxx.value)
so
(city == null || city.value == "" ? "" : "&Cities=" +  encodeURIComponent(city.value)  ) +
egoselfaxis
I've tried all of these suggestions already, and none of them are working for me.
Try it for yourself and you will see.
- yg
in 30 minutes
Before I test try
FinalUrl = "/" + this.URL_Root + "&PerformSearch" + queryString.replace(/ /g,"%20");
Nope .. that didn't work.
I left your code modification in place so you can test it for yourself:
- yg
Michel Plungjan
See the redirect:
What makes you think that the server configuration is the culprit?  I ask because I am able to manually add in the spaces in the url after generating a search result, and no redirection occurs:
http://www.homerep.com/search/?PerformSearch&PropertyTypes=2678&Cities=Bal%20Harbour%20Islands
Did I mention that this is a Wordpress based site?  Would that have anything to do with it, perhaps?
 - yg
Possibly. Perhaps there is some process that strips out spaces,
It is 100% surely something on the server because the spaced URL gets a 301 so a hard redirect
