Start Free TrialLog in
Avatar of tommy777
tommy777
Need help with Visual Basic Script
I have a script that replaces characters in file names for a folder and its sub-folders.  I have attached the file.
where I have:
set rootFolder = objFSO.GetFolder("C:\Copy\temp\New Folder")
I would like the path ("C:\Copy\temp\New Folder") to be the "current directory" that the script is located in, rather than having an absolute folder path there as it is now.
If that isn't possible, then I would like the user to be able to input that path using a dialog box.
Avatar of WebDevEM
WebDevEM
Avatar of Bill Prew
Bill Prew
Be careful with that, it may be what you want, but I prefer the following.  The difference is, the first solution will return the path to the location of the script itself, not the current directory.  The below approach gets the current directory.  I often have the script in a common scripts folder, not the current directory I'm working in, so prefer this approach.
Set objFSO = CreateObject("Scripting.FileSystemObject")
strCurDir = objFSO.GetAbsolutePathName(".")
Wscript.Echo strCurDir
~bp
Avatar of tommy777
Thanks that works.  The other problem I am having is that the last two functions don't seem to work together.  The last function works (the " " is replaced with "_".  The previous function where the "#" is to be replaced with "_" seems to be skipped over.
Hmmm, did you mean to split points?
~bp
