How to control/validate the creation of AD users with same lastname and same first initial on firstname ?
Let say in AD, I have the following scenarios:
Scenario 1: (Easier to be controlled)
User in AD:
DaSilva, Neymar, dasilvan
New User to be created:
DaSilva, Nancy, dasilvan1
Scenario 2:
Users in AD
New User to be created: (Tricky)
DaSilva, Noreen, dasilvan2
Question, how do i know that the new user to be created I had to add a 2, 3, 4, 5 etc, etc as a suffix ?
Do i have split the user and find out the last digit or last two digits ?
Thanks for your help,
namerg
namerg
  • 9
  • 7
2 Solutions
SubsunCommented:
You can try something like..
$Name = "Subsun"
$SName = $Name
$Count = 0
While ((Get-ADUser -Identity $Name -ea SilentlyContinue) -ne $null)
  $Count++
  $Name  = $SName + $Count
$Name
namergSystems AdministratorAuthor Commented:
Hmm, not working...it worked the fist run but afterwards did not.
In Master File:
Morgan,Alex,Seattle Sounders,3044
Morgan,Anna, Seattle Sounders,3052
Morgan,Anna, Seattle Sounders,3053
In AD, i have:
Morgan, Alex, morgana,3044
Morgan, Anna, morgana1 (First run creation)
CODE:
 Import-Csv $MasterFile | ForEach-Object {
 $LastName = $_."Last Name" -replace "\s"
 $sam = $LastName.ToLower() + $_."First Name".substring(0,1).ToLower()
 $ClockNumber = $_."Clock Number"
 Try   {
      $existsCOMPANY = Get-ADUser -LDAPFilter "(employeeNumber=$ClockNumber)" -SearchScope Subtree -SearchBase "OU=upi,DC=upicolo,DC=pvt"
 #     $existsCOMPANY_OU = existsCOMPANY_OU
      $existsNewUsers = Get-ADUser -LDAPFilter "(employeeNumber=$ClockNumber)" -SearchScope Subtree -SearchBase "OU=COMPANY - New Users,DC=upicolo,DC=pvt"
  Catch { }
If (!($existsCOMPANY) -and !($existsNewUsers)) {
    	$i++
    	$password = Get-RandomPassword
	   	$domain = "@COMPANY.COM"
       	$setpass = ConvertTo-SecureString -AsPlainText $password -force
		Try {
       		$existsSAM = ((Get-ADUser -Identity $sam -ea SilentlyContinue) -ne $null)
       		if (!($existsSAM)) {
       			New-ADUser $sam -AccountPassword $setpass -OtherAttributes @{userPrincipalName=$sam + $domain; givenName=$_."First Name";sn=$LastName; displayName=$LastName + ", " + $_."First Name"; title=$_."Job Title"; employeeNumber=$_."Clock Number"}
			Else {
       			$Count++
       			$sam =  $sam + $Count
       	Catch { }
	#MORE ABOUT AD USER CREATION
The problem is that it wants to create one more time morgana user and add the suffix, it should not.
SubsunCommented:
You have not even used my logic in this script which you posted... So how can you say it's not working.. :-)..
I am in a middle of work.. Give me sometime, I will try to modify the code for you..
Creating Active Directory Users from a Text File
If your organization has a need to mass-create AD user accounts, watch this video to see how its done without the need for scripting or other unnecessary complexities.
Hmm, isn't it this one ?
SubsunCommented:
Try..
	$SName = $sam
        $Count = 0
	While ((Get-ADUser -Identity $sam -ea SilentlyContinue) -ne $null)
	  $Count++
	  $sam  = $SName + $Count
 Try   {
 Catch { }
    	$i++
		Try {
 	Catch { }
SubsunCommented:
In your code it check the samaccountname only once..
The code which I posted has a while loop which does the trick..
Hmm, got the following error:
ERROR: Get-ADUser : Cannot find an object with identity: 'hughesa' under: 'DC=domain,DC=com'.
ERROR: At C:\scripts\ceridian\Ceridian_Create_AD_Users.ps1:27 char:22
While ((Get-ADUser <<<<  -Identity $sam -ea SilentlyContinue) -ne $null) {
ERROR:     + CategoryInfo          : ObjectNotFound: (hughesa:ADUser) [Get-ADUser], ADIdentityNotFoundException
ERROR:     + FullyQualifiedErrorId : Cannot find an object with identity: 'hughesa' under: 'DC=domain,DC=com'.,Microsoft.ActiveDirectory.Management.Commands.GetADUs
ERROR:    er
SubsunCommented:
Hmm.. try changing line 7 to..
While ($(try {Get-ADUser -Identity $sam}catch{}) -ne $null)
Almost, almost...it broke the renaming
I got this:
Rename-ADObject : An attempt was made to add an object to the directory with a name that is already in use
ERROR: At C:\scripts\ceridian\Ceridian_Create_AD_Users.ps1:59 char:23
ERROR: +           Rename-ADObject <<<<  -Identity $newdn -NewName $CN
ERROR:     + CategoryInfo          : NotSpecified: (CN=morgana2,OU=...=DOMAIN,DC=COM:ADObject) [Rename-ADObject], ADException
ERROR:     + FullyQualifiedErrorId : An attempt was made to add an object to the directory with a name that is already in use,Microsoft.ActiveDirectory.Management.Co
ERROR:    mmands.RenameADObject
ERROR:
CODE:
$dn  = (Get-ADUser $sam).DistinguishedName
       	Move-ADObject -Identity $dn -TargetPath $location
       	$newdn = (Get-ADUser $sam).DistinguishedName
       	$CN = $LastName + ", " + $_."First Name"
      	Rename-ADObject -Identity $newdn -NewName $CN
SubsunCommented:
As of now the code modify the samaccountname.. The error says the object name already exist in the OU.. If you want to add a numeric to the object name then try changing line 5 to..
$CN = $LastName + ", " + $_."First Name"+$Count
hmm, I see.
I cannot have two people with the same full name but different sAMAccountName, right ?
i have to add the number next to the LastName ?
You da man....Namaste.
SubsunCommented:
Add following line just before creating the user and see if it work as expected...
       $LastName = $LastName+$Count
	$SName = $sam
        $Count = 0
	  $Count++
 Try   {
 Catch { }
    	$i++
		Try {
 	Catch { }
Yep. I did this       $CN = $LastName+$Count + ", " + $_."First Name"
SubsunCommented:
If you add it in the end then it will not reflect in your accounts displayname, sn , UPN etc.. if it is ok with you then you can add it in the end as you mentioned in your last comment...
SubsunCommented:
Also If you want you can replace
With
While ((Get-ADUser -Filter 'sAMAccountName -eq $sam') -ne $null)
This will specifically look for the sAMAccountName in AD..
Join & Write a Comment
Worried about phishing attacks?
90% of attacks start with a phish. It’s critical that IT admins and MSSPs have the right security in place to protect their end users from these phishing attacks. Check out our latest feature brief for tips and tricks to keep your employees off a hackers line!
  • 9
  • 7
