Please help with ColdFusion printing problem
Need help figuring out why my PDF print function works only on certain PDF's. I don't see any major differences in my PDF docs, there about the same size, yet if I place a working PDF in a non working PDF folder it works. (Each PDF has it's own folder that ColdFusion connects to)
CF error:
500 - Internal server error.
There is a problem with the resource you are looking for, and it cannot be displayed.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Could not print PDF document.
Null range specified
The error occurred in D:\www\scripts\DD\sendprint.cfm: line 44
42 : 	<CFDIRECTORY ACTION="LIST" DIRECTORY="\\DSS1\Shared_Data\www\dwgs\#myarray[i]#" NAME="dcndir" FILTER="*.pdf">
43 : 	<CFLOOP QUERY="dcndir">
44 :      <cfprint type="pdf" source="\\DSS1\Shared_Data\www\dwgs\#myarray[i]#\#name#" attributeStruct="#aset#">
46 : 		<CFSET ptotal=ptotal+1>
DJPr0Asked:
unknown_routineCommented:
Who developed cold fusion code for you?
The is clearly a bug here:
 "<cfprint type="pdf" source="\\DSS1\Shared_Data\www\dwgs\#myarray[i]#\#name#" attributeStruct="#aset#"> "
One possibility is "myarray(i)" is not set here
Also Error 500 - Internal server error is IIS Error (not cold fusion).
So the other  possibility can be permission issue. Do you have direct access to web server? If so can you browse to the webpage on the server?
DJPr0Author Commented:
Everything worked fine after I updated ColdFusion from 9.00 to 9.01.
ColdFusion had a problem with recognizing newer versions with out updating.
Web Development
