Connection issue between SQL Servers (using Public IP)
I want to configure replication between my office and hosting company, where we hosted our application with its databases.
We are able to replicate from my office to hosting company server, by allowing hosting company IP address in our firewall.
When we want to do the same, from hosting company server to my office, it is not able to connect to my server. Note that we have a public IP address, through which connection should be established. But this IP address is not a server / machine, just an IP. Also inside our office there are many SQL Server instances and we want to connect to one of them.
Independent of replication, I am able to connect to hosting company SQL Server using SSMS in my Office Server. But when I do the same using remote desktop connection of hosting company server to connect to SQL Server in my office, I failed.
Please suggest.
LVL 4
batchakamalAsked:
Zaheer IqbalTechnical Assurance & ImplementationCommented:
Have the hosting company opened there firewall etc to access your server?
Standard Security
Server=myServerAddress;Database=myDataBase;User Id=myUsername; Password=myPassword;
Trusted Connection
Server=myServerAddress;Database=myDataBase;Trusted_Connection=True;
Connect via an IP address
Data Source=190.190.200.100,1433;Network Library=DBMSSOCN; Initial Catalog=myDataBase;User ID=myUsername;Password=myPassword;
DBMSSOCN=TCP/IP is how to use TCP/IP instead of Named Pipes. At the end of the Data Source is the port to use. 1433 is the default port for SQL Server
batchakamalAuthor Commented:
Dear 1stITMAN, Thanks for your immediate reply.
We have our own network inside our office, and there are many servers inside LAN. We have a public IP through which hosting company can enter into our network. Hosting company can also access this IP. But how can I connect to one of the SQL Server inside my LAN from hosting company.
Problems using Powershell and Active Directory?
Managing Active Directory does not always have to be complicated.  If you are spending more time trying instead of doing, then it's time to look at something else. For nearly 20 years, AD admins around the world have used one tool for day-to-day AD management: Hyena. Discover why
Do you have TMG ?
YES
OK setup a rule to redirect from your TMG to the SQL Server then
Ok I will tell network team to do this.
Once they complete that step, can I mention the SQL instance name in my network directly?
OR
I have to connect using public IP, which will redirect to SQL Server. In this case I may have more than one instance to connect to.
you will need to connect via IP unless you setup an A record on your domain. Say SQL.domainname.com or something like that...
Microsoft SQL Server 2008
