Differentiating between a single click, a double click and a right click in Excel
Hi, I am trying to run three different macros when a user clicks on a cell, depending on whether the user has single clicked on the cell (using the left mouse button), double clicked on the cell (using the left mouse button), or right-clicked on the cell (using the right mouse button).
The problem is that all three mouse actions trigger the SelectionChange event, and this event is triggered first, before the BeforeDoubleClick event and before the BeforeRightClick event. I can trap for a right click inside the SelectionChange routine (see the code below). But I can't detect the difference between a left click and a double click.
Does anyone know how to do this? Perhaps with Windows API calls?
(I'm amazed that this exact problem hasn't been posted anywhere before, but I have searched and cannot find an answer. So apologies if I missed it).
Private Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
    MsgBox "Double click"
    Cancel = True
End Sub
Private Sub Worksheet_BeforeRightClick(ByVal Target As Range, Cancel As Boolean)
    MsgBox "Right click"
    Cancel = True
End Sub
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
    If KeyPressed(vbKeyRButton) = True Then Exit Sub
    MsgBox "Left click"
    Cancel = True
End Sub
Public Function KeyPressed(ByVal Key As Long) As Boolean
    'The function returns true if a key is pressed,false if not
    KeyPressed = CBool((GetAsyncKeyState(Key) And &H8000) = &H8000)
End Function
jwshome
jwshome
  • 4
  • 3
  • 3
  • +2
Martin LissRetired ProgrammerCommented:
Why is the fact that SelectionChange comes first a problem?
Ken ButtersCommented:
Agree with MartinLiss... why is this causing you an issue?
It seems like you should just be able to put your "doubleClick" code in the "BeforeDoubleClick" event, and your right click code in the BeforeRightClick event.
Is there some reason you feel that the click type has to be determined in selectionChange Event?
If you expand on what you are trying to do, might be able to help you use the existing events so that you can get the functionality you are working towards.
Rgonzo1971Commented:
I suppose your problem comes because when you double-click or right-click a cell that was not previously selected the Selection_Change takes precedence and then if you left click a selected cell, no event is being fired.
Regards
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
@RGonzo1971 - Still not seeing how the order that the events are fired is an issue.
Selection_Change will fire first... but still not understanding why that is a problem.
The fact that Selection_Change fires, does not stop the other events from firing as well.
If you put the necessary code in the other events, you should be able to do whatever you need to do.
for the right-click in a new cell no problem, First event Selection_change then Rightclick
for the double click in a new cell, It only recognize a left click, that means a Selection_Change
Regards
ok... I see what you are saying.  Sorry to be slow in understanding.
There is no dedicated Mouse click for the a single mouse click.
Let suppose you wanted to take the following actions as an example
Single Click - Color the cell green
Double Click - Color the cell yellow
Right Click - color the cell red
Only work-around I see is to take advantage of the events that already exist.
For example if you double click, you would have to go through the SelectionChange Event and treat it as though it were a single click and process the code accordingly... then when you hit the doubleclick event, you would have to redo anything special that you wanted to do with the doubleclick event... even if that meant "undoing" something that had been accomplished in the SelectionChange Event.
so a double click would first color the cell green (Selection change), then recolor the cell yellow when the double click event kicks in.
jwshomeAuthor Commented:
Thanks for all the comments. The example of the red/yellow/green is exactly right. The solution to have the doubleclick routine undo the selection change routine is clever, but in my case the actions are difficult to undo, and they are also time consuming (they involve the physical movement of machinery controlled over a serial port).
Windows can recognize a right click, so there must be a way for Excel to get access to the Windows API, isn't there?
Again let me ask, why is the fact that SelectionChange comes first a problem?
byundtCommented:
You might try using Application.OnTime to schedule a response to a leftclick after say a 1 second delay. If a doubleclick or rightclick occurs in the meantime, then the leftclick event in the OnTime sub will not occur.
The following code goes in the code pane for the worksheet being watched. Note that it uses the code name for that worksheet, not the tab name.
As written, the code watches A1:A10 for either a leftclick, rightclick or doubleclick on a single cell. It then displays a message box naming the cell that was clicked and the type of click.
Dim bTrapped As Boolean
Dim cel As Range, rgWatch As Range
If Not Intersect(cel, Target) Is Nothing Then
    MsgBox "Doubleclick at " & cel.Address
    bTrapped = True
    Cancel = True
End If
End Sub
    MsgBox "Rightclick at " & cel.Address
    bTrapped = True
    Cancel = True
End If
End Sub
Dim targ As Range
Set rgWatch = Range("A1:A10")
Set targ = Intersect(Target, rgWatch)
If Not targ Is Nothing Then
    If targ.Cells.Count = 1 Then
        bTrapped = False
        Set cel = targ.Cells(1, 1)
            'Allow 1 second for user to complete a rightclick or doubleclick before trapping leftclick
        Application.OnTime Now + 1 / 86400, "Sheet1.DelayedWatch"       'Note that Sheet1 is codename for worksheet (not tabname)
    End If
End If
End Sub
Private Sub DelayedWatch()
If bTrapped = False Then
    MsgBox "Leftclick at " & cel.Address
End If
End Sub
TrapLeftRightDoubleClickQ2827889.xlsm
For MartinLiss:
The reason that SelectChange coming first is a problem is that when I enter the SelectChange routine I don't know whether I got there because the user clicked once on the left button of their mouse, or twice. I want to execute two completely different sets of code depending on whether the user clicked or double clicked, and I specifically do not want to execute the single-click code if the user double clicked.
In other words, what happens when the user double clicks is that the first click triggers the SelectChange routine before the second click can get recognized. I'm trying to figure out, in effect, how to recognize the second click from inside the SelectChange routine, in the same way that I am able to recognize the right click (which also triggers the SelectChange routine) from within the SelectChange routine.
Maybe another way to put it is this: in Excel, whenever you click the mouse on a new cell, whether you single click, or double click, or right click, the SelectChange routine is triggered first. The question I am asking is how can I figure out, from within the SelectChange routine, how to tell which of the three types of clicking got me there, so I can process each of the three differently.
All of the explanations on the internet are answering a much simpler question: "how can I trap a doubleclick"? The answer is easy - use the "BeforeDoubleClick" routine. And this works perfectly, unless you are also trying to trap for a single click - in which case the SelectChange routine is triggered first.
I hope this is helpful.
To byundt,
I was preparing a condescending reply to explain how you fail to understand how events are processed in Excel when I took the time to understand your code. Brilliant solution. It works as described.
Would you know how to set up a delay of 500 milliseconds as opposed to a full second? It appears that the "Now" command is generating times that are rounded to the nearest second, so that even if I plug in a delay of 1/172800 the delay is sometimes shorter than half a second and sometimes longer due to rounding.
Thanks for your help.
(For anyone interested - I would still like to know how Windows determines if a click is single or double. They must use a similar logic to byundt's, but there must be a direct API call somewhere...)
Works exactly as indicated (and it is very clever by moving the single click execution out of the single click routine...)
Deleted due to byundt's more complete answer.
We value your feedback.
  • 4
  • 3
  • 3
  • +2
