I'm preparing a drawing issue register. I've been doing this for years but utilising formal issues in a separate table. I need VIRTUAL issues to be produced from the data. A virtual issue, the column (I
n) in my pivot table, is a unique set of recipients (R
n) for a date. As you can see some drawings (not shown) will have been issued on the same date (D
n) but to a different unique set of recipients, or on a different date to the same set:
eg
![Pivot arrangement]()
This should be simple but I can't get my head round it. Maybe this is the onset of middle age...
I want to take (simplified)
tblRevIssues
fldIssuedDate
fldIssuedTo
fldDrawingRevision
and create 3 derived tables with the magic virtual IssueNo:
tblIssues
fldIssueNo
fldIssuedDate
tblIssueRecipients
fldIssueNo
fldIssuedTo
tblIssueDrawings
fldIssueNo
fldDrawingRevision
I'm comfortable with cursors, table variables etc. Less so with the pivot command and ranking but happy to look at these methods. Just need a steer in the right direction!
Then I can generate the register.
I'm familiar with this process.
The best way of helping us to help you is to provide sample data and an expected result.
I guess that means some records from tblRevIssues and from those records what result you expect.
"the magic virtual IssueNo:"
so issue numbers don't have to be unique?
i.e. if one runs the report today you get an Issue-1
, and if you run it next month for different data you also get an Issue-1
Is ordering this IssueNo by fldIssuedDate expected?
