Split macro into four parts
Below is a macro which fills out formula based on the number of entries a user enters. We know that one user will enter 40,000. This is too much for excel to handle and causes it to time out.
When you enter 10,000 it copes down fine.
Is it possible to split the macro, so it does 10,000 then does another 10,000 etc etc to 40,000
Many thanks
Sub PrepTool()
' Macro expands sheet for use with required number of records
' Be aware that many aspects of this macro are hard coded (e.g. the lengths of the lines to be copied down)
' and, as such, can be easily broken if the tool is amended
Dim Records As Long
Dim Selection As Integer
Dim x As Integer ' counter
On Error GoTo Finish
Selection = MsgBox("You are about to be asked how many records you will need in the tool. Be aware that choosing a large number of records will inflate the size of the tool markedly. You should save a new version of the tool before choosing to expand for your records as this cannot be undone.  Choose 'Cancel' to go back and save", vbOKCancel)
If Selection = vbCancel Then Exit Sub
Records = InputBox("How many records are you planning to input?", "Sample", 2)
Application.ScreenUpdating = False
'Turns off auto-calculate
Application.Calculation = xlCalculationManual
For x = 1 To 2
    With Sheets("Input - D" & x)
        .Activate
        .Unprotect
    End With
        Range("B8:DW8").AutoFill Range("B8:DW" & (Records + 7))
    ActiveSheet.Protect
    With Sheets("Calculation - D" & x)
        .Activate
        .Unprotect
    End With
        Range("A14:BJ14").AutoFill Range("A14:BJ" & (Records + 13))
    ActiveSheet.Protect
Next x
    With Sheets("Calculation - variation - D2")
        .Activate
        .Unprotect
    End With
        Range("A12:FD12").AutoFill Range("A12:FD" & (Records + 11))
    ActiveSheet.Protect
    With Sheets("Input - D3")
        .Activate
        .Unprotect
    End With
        Range("B8:DW8").AutoFill Range("B8:DW107")
    ActiveSheet.Protect
    With Sheets("Calculation - D3")
        .Activate
        .Unprotect
    End With
        Range("A14:BJ14").AutoFill Range("A14:BJ113")
    ActiveSheet.Protect
    With Sheets("Calculation - variation - D3")
        .Activate
        .Unprotect
    End With
        Range("A12:FD12").AutoFill Range("A12:FD111")
    ActiveSheet.Protect
Finish:
Sheets("Instructions for use").Activate
Application.ScreenUpdating = True
MsgBox "Your Tool is now ready for use", vbOKOnly, "Ready"
End Sub
Seamus2626Asked:
mvidasCommented:
Sorry for not getting back sooner, I had a 13 hour day yesterday and just couldn't make the time.
When i use the second version (splitting into 10k) and use the autofill function, it works for calculation - variation - d3 but it doesnt do anything with sheets
Calculation - D1
Calculation - D2
Do you know why that is so?
I'm not sure, the code looks like it should be working fine. It looks like its starting in A14:BJ14.
Actually, I do see a problem in my code, but it wouldn't cause the macro to skip any sheets. Here is a new version for you, give it a shot when you get a minute:
Sub PrepTool()
 Dim Records As Long, vRecords As Long, x As Long, xr As Long
 If MsgBox("You are about to be asked how many records you will need in the tool. Be aware that choosing a " & _
  "large number of records will inflate the size of the tool markedly. You should save a new version of the " & _
  "tool before choosing to expand for your records as this cannot be undone.  Choose 'Cancel' to go back and " & _
  "save", vbOKCancel) = vbCancel Then Exit Sub
 Call fPrepSheets(Sheets("Input - D3").Range("B8:DW107"))
 Call fPrepSheets(Sheets("Calculation - D3").Range("A14:BJ113"))
 Call fPrepSheets(Sheets("Calculation - variation - D2").Range("A12:FD" & (Records + 11)))
 Call fPrepSheets(Sheets("Calculation - variation - D3").Range("A12:FD111"))
 xr = CLng(Records / 10000)
 For x = 0 To xr
  If x = xr Then
   vRecords = Records - 1
  Else
   vRecords = (x + 1) * 10000
  End If
  Call fPrepSheets(Sheets("Input - D1").Range("B" & (8 + x * 10000) & ":DW" & (vRecords + 8)))
  Call fPrepSheets(Sheets("Input - D2").Range("B" & (8 + x * 10000) & ":DW" & (vRecords + 8)))
  Call fPrepSheets(Sheets("Calculation - D1").Range("A" & (14 + x * 10000) & ":BJ" & (vRecords + 14)))
  Call fPrepSheets(Sheets("Calculation - D2").Range("A" & (14 + x * 10000) & ":BJ" & (vRecords + 14)))
 Next
Finish:
 Application.Calculation = xlCalculationAutomatic
End Sub
Private Function fPrepSheets(vRange As Range) As Boolean
 vRange.Worksheet.Unprotect
 vRange.Rows(1).AutoFill vRange
 vRange.Worksheet.Protect
End Function
mvidasCommented:
Hi Seamus,
Instead of using the AutoFill function, why not just copy the cells?
Also, you don't need to .Activate the sheets if you reference the sheet when selecting the range. Using that logic, since you're performing the same functions to different sheets/ranges, you can use a function to do the work for you and just send it the ranges to fill.
Sub PrepTool()
 Dim Records As Long
 Call fPrepSheets(Sheets("Input - D1").Range("B8:DW" & (Records + 7)))
 Call fPrepSheets(Sheets("Input - D2").Range("B8:DW" & (Records + 7)))
 Call fPrepSheets(Sheets("Calculation - D1").Range("A14:BJ" & (Records + 13)))
 Call fPrepSheets(Sheets("Calculation - D2").Range("A14:BJ" & (Records + 13)))
Finish:
End Sub
 vRange.Rows(1).Copy Destination:=vRange
End Function
Give it a try, let me know how it goes.
Matt
Seamus2626Author Commented:
Hi Matt,
I will try this first thing in the morning when im back in office, many thanks
Cloud Class® Course: CompTIA Healthcare IT Tech
This course will help prep you to earn the CompTIA Healthcare IT Technician certification showing that you have the knowledge and skills needed to succeed in installing, managing, and troubleshooting IT systems in medical and clinical settings.
mvidasCommented:
It should work fine. If you're still running into the 'too big' problem, here is the same thing but broken up every 10,000 lines
Sub PrepTool()
 For x = 0 To xr
  If x = xr Then
   vRecords = Records - 8
  Else
  End If
  Call fPrepSheets(Sheets("Input - D1").Range("B" & (8 + x * 10000) & ":DW" & (Records + 8)))
  Call fPrepSheets(Sheets("Input - D2").Range("B" & (8 + x * 10000) & ":DW" & (Records + 8)))
 Next
 For x = 0 To xr
  If x = xr Then
   vRecords = Records - 14
  Else
  End If
  Call fPrepSheets(Sheets("Calculation - D1").Range("A" & (14 + x * 10000) & ":BJ" & (Records + 14)))
  Call fPrepSheets(Sheets("Calculation - D2").Range("A" & (14 + x * 10000) & ":BJ" & (Records + 14)))
 Next
Finish:
End Sub
End Function
And if for some reason the .copy isn't working the same as .autofill, replace the function with this to use autofill (in either version of the code):
End Function
I may not be around in the morning, so hopefully that covers any issues that may arise :)
Thanks again Matt,
Calculation - D1
Calculation - D2
Many thanks
Seamus
PS i put the autofill function on your first block of code and it went as far as 24k rows in calculation - variation D2, so close!!
Hi Matt,
Your code is working fine. The problem here is the the macro is trying to expand 160 columns * 40k rows in one sheet. In another two sheets, its 40k rows by 60 columns of formula.
I think the ss is just crashing from the amount of formula
Would yo uhave any suggestions on this?
mvidasCommented:
Why do you have to have 40000x160 records (and more)?
Its a legacy workbook ive inherited and it needs to rolled out next week so no time for redevelopment
The formulas feed a load of graphs/ tables etc
mvidasCommented:
Do you actually need the formulas themselves, or just the underlying values? If just the end values, maybe you could have the macro leave only the values to speed up the use a little bit? Otherwise if you can't really change it then you're stuck. Sounds like it might be better to keep the data in a database, in a perfect world :)
Ya i need the formulas. It would be great to have it in access but its too late now. Will have to think of some workaround!
mvidasCommented:
What are the formulas? Maybe they can be improved? Do you need every column?
