Wired LAN to Wired LAN connection via WIRELESS
I am trying to figure out how to connect a NAS and a PC to each other. The PC is on one side of the house and the NAS unit is on the other in a secured room. In the secured room I have no LAN jacks or drops, I can get wireless in there, but the NAS unit does not natively support Wireless. Also, my wireless router in the house seems to randomly drop packets and connections so I don’t want to use it for transferring files.
What I want to do is connect some sort of device to the NAS via the Ethernet port that will then connect to another identical device on the other side of the house that is also connected to the PC via Ethernet port. These two devices will then create a secure  wireless connection – almost like a cross over cable would do if I ran one between the two devices.
Any thoughts – please see my drawing.
Robert AdvancedideaAsked:
Gary CaseConnect With a Mentor RetiredCommented:
Buy a set of these:  http://www.newegg.com/Product/Product.aspx?Item=N82E16833122504
There are less expensive versions, but they operate at lower speeds.   These work very well and will easily outperform any wireless solution in both speed and reliability.
InfamusConnect With a Mentor Commented:
This is one of the options you may have.
PC----------------------Wireless router--------(Bridge Mode)--------Wireless router--------------------NAS
           Wired                                                    Wireless                                               Wired
This will require two wireless routers.
In that case, you need to make sure they are on the same electrical circuit.
WEBINAR: GDPR Implemented - Tips & Lessons Learned
Join the WatchGuard team on Thursday, March 29th as we recount some valuable lessons learned in weighing the needs of a business against the new regulatory environment, look ahead at the two months left before implementation, and help you understand the steps you can take today!
Gary CaseRetiredCommented:
They don't need to be on the same circuit -- only on the same primary transformer.    As long as they're in the same house, and the house doesn't have two main panels, it'll work fine.
... and in fact there's a simple adapter you can get to take care of the case where there are two main panels.
I'm not so savvy on electrical stuff so "YES", you are right.
I was just thinking out loud thinking it should be on the same network (circuit in this case).
Thanks for clarifying.
Have a good weekend, guys!!!
Darr247Connect With a Mentor Commented:
If you want to stick with wireless as the original post said, I recommend one of these
EA-N66 (refurbished)... they come setup to work as client bridges, so all you need to do is plug into it with your computer to configure+save the wireless passphrase, then connect its ethernet port to the NAS and it should be good to go.
Robert AdvancedideaAuthor Commented:
Thank you! I will research these solutions, I appreciate the multiple options
