Avatar of Kamalasekar Parthasarathy
Flag for India asked on
Power script a Beginner need help
Hi All,
Am a beginner to Powershell..
Can some one please explain whats wrong with the below powershell script
$strcom = read-host "Enter the name"
if ($strcom = 2)
      Write-host "You are the best"
Elseif ($strcom = 1)
        Write-host "You ugly hell"
Else
  Write-host "You have entered the wrong number we got only 1 & 2 choices"
Powershell
SubSun
SubSun
Dan Craciun
In powershell type:
help about_comparison_operators
This will get you a very long and thorough description of comparison operators.
PS: unlike batch, PS has a very well done help system that's available in command line.
Run update-help first to download a copy of help files on your computer.
HTH,
Dan
SubSun
@sekar_raj32, Could you please explain, why you have selected DanCraciun's comment as the sole answer?
@subsun am really sorry..it was my mistake..i have wrongly given it ..
Am extramely sorry..Actually you helped me but my bad..Am sorry again..
rwheeler23
Dan Craciun
@sekar_raj32: then contact a moderator and ask him to correct the situation.
I actually thought you preferred to read the help file and get a thorough understanding, instead of a "do this" solution :)
Thanks All
SubSun
Thank you sekar_raj32 for accepting the solution. Any specific reason for 'B' grade?
Please see the EE guidelines on grading..
Http://support.experts-exchange.com/customer/portal/articles/481419
