bubaibhatta
Problem installing Citrix Web Interface with Secure Gateway
Hi Experts,
I am installing Citrix Web Interface 5.4 with Secure Gateway 3.3 on Windows 2008 R2. I have already installed SSL certificate on the server. I have already installed WI and then Secure Gateway. I connected Citrix Farms on the server. Everything gone fine. I configured https on default web site on IIS at port 444. My secure gateway is configured to port 443.
Now if I open the link, with local host (https://localhost:444/Citrix/XenApp/auth/login.aspx) its opening however its not opening when I do it using proper url(https://ctxgw.com/Citrix/XenApp/auth/login.aspx). its says bad gateway.
What should I do?
By the way, I have created two DNS entry on DNS server. one of ip to server name and one for ip to ctxgw.com.
SecureGateway-Report.txt
What should I do?
Hi Mutawadi,
1. This installation is going to be a production server and this domain is a registered one.
2. I already created DNS record for the same.
3. I have installed both Intermediate and SSL certificate. However how do I ensure the private key of the Certificate is installed on my server?
4. You said, you would not enable 443 on the WI IIS default website. Here is what I did:
Please help and guide me to resolve the case.......
1. .Com is one of the high level domains on the root domain in public and shouldn't be used for private networks.
2. You DNS should have an A record to map the name into IP
3. Ensure that the private key of the certificate is installed on your server
If I were you, I wouldn't enable 443 on the WI IIS default website.
