Help Designing Virtual environment solution for redundancy between two sites
Dear Experts,
I am given the task to design and implement a redundant solution for our company that currently has a point to point connection between our two main offices.
We want to back up the servers from one office to the other so in case an office is demolished some how and everything is lost the other office has perhaps until yesterdays information, emails, and all important data.
I am thinking of a virtual environment with either Hyper V or VMware.
I need conceptual reference to keep in mind while designing and implementing such solution.
Should I create a cluster of servers (hardware) in where to build the virtual server farm on top?
Am I talking of replication once both sites are build?
We are a DELL shop, what to use for the hardware to be tight together?  Clustering?
What does the Virtualization software needs in terms of licensing and features?
Recommendations and advice much appreciated. Thank you in advanced.
marceloNYCMiddle-Tier AdministratorAsked:
Andrew Hancock (VMware vExpert / EE MVE^2)Connect With a Mentor VMware and Virtualization ConsultantCommented:
This is easily achieveable using either Microsoft Hyper V or VMware vSphere, both support Replication of Virtual Machines from Host Server to Host Server.
This very much depends on how many virtual machines you will be hosting and how many Host Servers you require, and do you want.
A single server is a single point of failure, two or more servers resolves this issue , using shared storage to connect to ALL Host Servers.
We use Dell R620 or R720s, and Dell Equallogic SANs
either Microsoft Windows Server 2012 Datacenter Server or VMware vSphere (many different licenses available to suit your requirements)
marceloNYCMiddle-Tier AdministratorAuthor Commented:
Awesome! Just one more question on this part:
"A single server is a single point of failure, two or more servers resolves this issue , using shared storage to connect to ALL Host Servers."
That is when you daisy chain the servers with a network cable or some kind of cable that makes them as a cluster? Right?
Andrew Hancock (VMware vExpert / EE MVE^2)VMware and Virtualization ConsultantCommented:
You have two servers connected to the same storage, when a Host Server fails in your farm, it restarts the Virtual Machines, on other available servers in the cluster.
It's called HA.
VMware vSphere Availability Features
VMware vMotion - Migrate Virtual Machines with Zero Downtime
http://www.vmware.com/products/vmotion/overview.html
VMware vMotion Product Brief
http://www.vmware.com/files/pdf/VMware-VMotion-DS-EN.pdf
VMware High Availability - Decrease Downtime and Reduce Risk
http://www.vmware.com/products/high-availability/overview.html
VMware High Availability (HA) Product Briefs
http://www.vmware.com/pdf/ha_datasheet.pdf
http://www.vmware.com/files/pdf/VMware-High-Availability-DS-EN.pdf
VMware Distributed Resource Scheduler (DRS) - Dynamic Resource Balancing
http://www.vmware.com/products/drs/overview.html
VMware Distributed Resource Scheduler (DRS) Product Briefs
http://www.vmware.com/files/pdf/VMware-Distributed-Resource-Scheduler-DRS-DS-EN.pdf
http://www.vmware.com/pdf/vmware_drs_wp.pdf
VMware Fault Tolerance - Deliver 24 X 7 Availability
http://www.vmware.com/products/fault-tolerance/overview.html
VMware Fault Tolerance Product Brief
http://www.vmware.com/files/pdf/VMware-Fault-Tolerance-FT-DS-EN.pdf
VMware vSphere Availability Guide ESX 4.1vSphere
http://www.vmware.com/pdf/vsphere4/r41/vsp_41_availability.pdf
Whoohooo!! You helped me so much. I can take from here now. Thanks so much!!!
