vss, system state and system volume infomation
I am looking for information related to all these , i will appreciate if any one post some articles .
sara2000
sara2000
Pradeep DubeyConsultantCommented:
VSS => It is used for the backup. Check below link for the detailed information about the VSS.
http://documentation.commvault.com/hds/release_8_0_0/books_online_1/english_us/features/snapshots/vss/vss_wfs.htm
System State => Check below link for the System State information
http://documentation.commvault.com/hds/release_7_0_0/books_online_1/english_us/features/system_state/system_state.htm
system volume=> See below blogs for the same.
http://blogs.msdn.com/b/oldnewthing/archive/2003/11/20/55764.aspx
Simplify Active Directory Administration
Administration of Active Directory does not have to be hard.  Too often what should be a simple task is made more difficult than it needs to be.The solution?  Hyena from SystemTools Software.  With ease-of-use as well as powerful importing and bulk updating capabilities.
