dgswin
Exchange 2007 - Management power shell
Can you tell me what is the cmdlet for this result? See file Picture1
For each maibox display nam contains (DGATI), I want to replace by (DGARI)
What is the cmdlet for execute this?
1. Export all mailbox with matching condition to csv file.
Get-Mailbox -resultsize unlimited | where-object {$_.CustomAttribute1 -eq "<Value>" -and $_.DisplayName -Match 'DGATI' } | Select Alias, DisplayName | Export-Csv c:\output.csv
2. Not open CSV & replace all DGATI with DGARI
If csv contains " with all reocrds, replace them with null value. Remove first row as well.
3. Import the csv back to mailboxes.
$Temp = Import-Csv c:\output.csv
Foreach ($tmp in $temp) {Get-Mailbox $tmp.Alias | Set-Mailbox -DisplayName $tmp.DisplayName}
Always Try in lab first
