lehi52
really need help with click not going to person clicked on, gozreh
I put a double click event so that when you click on a name, it takes the user to the form on which the name is located. Now I tried to use that same on in a different place and it is returning an error. It works elsewhere just not here. See code and attached database.
This code works on the copy of actions and opps subform. But it does not work on expiring in 7 days subform. WHen I double click the policy name in the expiring in 7 days subform is throwing an error.
See the contact form and go to actions tab and you can try it there.
1st.accdb
Private Sub Policy_Name_DblClick(Cancel As Integer)
DoCmd.SearchForRecord acDataForm, "Contact Form", acFirst, "[ContactID] = " & Nz(Me.ContactID, 0)
Me.Parent.TabCtl0 = 1
End Sub
1st.accdb
I think the reason is because the expiring in 7 days subform is pulling data from a query. So the question is how do I change the code.
Please help. This is the last thing for a while that I need.
Such a simple resolution. haha. You are awesome. Thanks for your help.
