ptsolutionsinc
Extend rack mount UPS to power wall mounted devices
we recently installed a rack mounted UPS at a customer site. we would like to feed UPS power to the wall mounted devices. we have two choices, either buy a wall mountable UPS or use an extension cord from the rack UPS to the wall. I would prefer the latter as the current UPS is only at a 15% load but don't want it to look tacky with an extension cord running to the wall. what is the standard in these cases. is there a professional looking power strip that we can use?
Let's hope there's sufficient bits of bent metal to mount it on the wall, if it says 0U that's generally a clue to it having several brackets included.
According to website ---- "Multi-outlet power distribution unit is the ideal means of powering multiple loads in 19 inch rackmount, wallmount and under-counter
applications"
it states wallmount and under-counter applications so it has to have some sort of brackets.
applications"
