Frank Freese
Problem with Offset, Row and Column combo
Folks,
In the attached workbook I am using a combination of Offset, Row and Column to filter out every other row.
It works fine until I try to duplicate the formula to the Practice section of the worksheet.
I simply don't see why it is not working in the practice section.
FilterEveryOtherRow.xlsx
Saqib,
When I select B2:D8 and enter the following formula
=OFFSET($A$2,(ROW()-2)*COL UMN(),0) and the press <Ctrl+Enter> it works
My problem lies in the second section, name Practice. I select cells J2:L8 and enter the following formula
=OFFSET($I$2,(ROW()-2)*COL UMN()-8,0) and then press <Ctrl+Enter> only J2:L2 are filled
Maybe I can only do this once is a worksheet?
Did you try my formula?
I entered your formula but had to change $A$3 to $I$3 for the second section (range J3:L9), but it worked. It really doesn't make sense to me because in the first range of B3:D9 this worked for me:
Select cells B3:B9 and then entered the following formula:
The formula offered by: regmigrant
=OFFSET($I$3,(ROW()-2)*(CO LUMN()-8), 0) worked but only on J3:L3?
Why? I just don't know.
Allow me to split the points 200/300.
Thank you very much
Thank you very much
thank you both...
Select the formula cell and go to
Formulas > Evaluate formula
and step through the formula and you will see why a formula works or otherwise.
good tip...and thank you
interesting result and glad you got your answer but my original post worked fine - see attached
Copy-of-FilterEveryOtherRow.xlsx
Reg, that does not work if you create another table further ahead.
Ok, I missed that requirement in the question and it explains why your formula has the extra column() - to correct the offset as the table moves right, thanks!
Saqib,
I did have a slight problem with your code though. It worked ok on the first three items but later it returned the formula. Just an FYI
The range is probably formatted as text. Change it to general format.
thanks
