fhandley
6 pin power cable 8 pin motherboard
Hi, I have just purchased a new MB and CPU.
My power supply only has the usual ATX power and a 6 pin cable for the CPU.
It's an 8 core AMD and an asrock 980 MB.
any advice would be appreciated
You need an adapter, such as this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200459
Or a new PSU.
HTH,
Dan
Or a new PSU.
HTH,
Dan
So I've tried with just the 4 pin connector which most blogs agree wont create any smoke.
I'm getting no post beeps or display on my monitor, I'll head down to the shop an get a molex adapter tomorrow and see how I go.
http://www.playtool.com/pages/psuconnectors/connectors.html
Hope it helps. Regards.
