Split ascii file into parts using vbscript
I have an ascii text file that I am trying to split out text in the file based on a Header. The header is the "GROUP", so a new file would be created for each "GROUP" i.e. GROUP A, GROUP B, GROUP C.....
The new file would just contain the rows below each GROUP section.
An example file looks like this:
"GROUP","A"
"DATA","ID01","X","X","X","X","X"
"DATA","ID02","X","X","X","X","X"
"DATA","ID03","X","X","X","X","X"
"GROUP","B"
"DATA","ID20","X","X","X","X","X"
"DATA","ID21","X","X","X","X","X"
"DATA","ID22","X","X","X","X","X"
"GROUP","C"
"DATA","ID30","X","X","X","X","X"
"DATA","ID31","X","X","X","X","X"
"DATA","ID32","X","X","X","X","X"
"GROUP","D"
"DATA","ID40","X","X","X","X","X"
"DATA","ID41","X","X","X","X","X"
"DATA","ID42","X","X","X","X","X"
Using the example code below will split the first group, how do I write the headingPattern and modify the code to read each header, currently the script just wants to overwrite the first file created?
textFile = "C:\temp\04test.txt"
saveTo = "C:\temp\"
writeTo = ""
headingPattern = "(GROUP*)"
dim fso,fileFrom,regex
set fso = CreateObject("Scripting.FileSystemObject")
set fileFrom = fso.OpenTextFile(textFile)
set regex = new RegExp
with regex
  .Pattern = headingPattern
  .IgnoreCase = false
  .Global = True
end with
while fileFrom.AtEndOfStream <> true
  line = fileFrom.ReadLine
  set matches = regex.Execute(line)
  if matches.Count > 0 then
    writeTo = saveTo & matches(0).SubMatches(0) & ".txt"
    set fileTo = fso.CreateTextFile(writeTo)
  else
    fileTo.WriteLine(line)
  end if
wend
set fileFrom = nothing
set fso = nothing
set regex = nothing
Thank you
Examplefile.txt
crompnkData Management SpecialistAsked:
Bill PrewConnect With a Mentor Commented:
This seems to work for me:
saveTo = "C:\temp\"
writeTo = ""
headingPattern = """(GROUP)"",""(.*)"""
set fileTo = nothing
with regex
  .IgnoreCase = False
  .Global = True
end with
    writeTo = saveTo & matches(0).SubMatches(0) & " " & matches(0).SubMatches(1) & ".txt"
    if not (fileTo is nothing) then fileTo.Close()
  else
  end if
wend
fileFrom.Close()
set fso = nothing
set regex = nothing
~bp
aikimarkCommented:
Use this regex pattern to capture the letter/name of the group:
.*?"GROUP".*?"([^"])"
crompnkData Management SpecialistAuthor Commented:
Hi, thanks for the reply, is this scripted as:
headingPattern = ".*?"GROUP".*?"([^"])"
This gave an 'expected end of statement error' in the vbscript.
Cloud Class® Course: Microsoft Azure 2017
Azure has a changed a lot since it was originally introduce by adding new services and features. Do you know everything you need to about Azure? This course will teach you about the Azure App Service, monitoring and application insights, DevOps, and Team Services.
aikimarkCommented:
When a string literal contains a quote character, you need to either double up the interior quote characters or concatenate chr(34) characters.
headingPattern = ".*?""GROUP".*?""([^""])"
or
headingPattern = ".*?" & Chr(34) & "GROUP".*?" & Chr(34) & "([^" & Chr(34) & "])"
Using the above script with the headingPattern changed I get an 'Expected identifier' error. I tried taking out the '*' as this is the position of the error:
Script:    C:\temp\VBScript.vbs
Line:      4
Char:      31
Error:     Expected identifier
Code:     800A03F2
Source   Microsoft VBScript compilation error
Attached is the VBScript file and the text file being called.
VBScript.vbs
04test.txt
aikimarkConnect With a Mentor Commented:
I missed one of the interior quotes.  My earlier snippets should have been
headingPattern = ".*?""GROUP"".*?""([^""])"
and
headingPattern = ".*?" & Chr(34) & "GROUP" & Chr(34) & ".*?" & Chr(34) & "([^" & Chr(34) & "])"
Bill PrewCommented:
Looks like you are in good hands here, but I would also recommend doing a fileTo.Close before you start the next group (only if fileTo is not Nothing) just to ensure the prior group file is written and closed properly.
~bp
