Solved
Right Click Problem
Posted on 2014-04-04
Last Modified: 2014-04-10
I have a vb 2008 application that has uses several context menu on right click.  When I exit the program, then whenever I right click on anything, I usually get an error message that Windows Explorer is restarting.  This happens everytime when exiting the program and is only solved by restarting the computer.  The application is shutting down properly or at least it disappears from the Task Manager.  I am convinced it has something to do with the context menu code.  Anyone with ideas?
Question by:GCCal
  • 3
4 Comments
LVL 75
Expert Comment
by:käµfm³d 👽
Did you add context menus using the packaged ContextMenu control, or did you use the Win API to register your own? If you used the former, then it would be odd that those controls would cause such an issue.
Author Comment
by:GCCal
Yes, kaufmed......I used the control that comes in the vb.net toolbox.  I agree it seems odd but since the problem is with right click I assumed that was the case.  Is there some chance that the code I am using is somehow, someway causing the problem?
Going to lunch right now so will be away for awhile.  Tks,
Accepted Solution
by:
GCCal earned 0 total points
I finally wound up creating my own context menus using a groupbox.  Seems the problem of right click causing Windows Explorer to restart has disappeared.  Some problem with either how I was using the context menus or the code was being created.  Thanks....this question is now closed.
Author Closing Comment
by:GCCal
No solutions were offered.  The question probably covered a very broad spectrum which made it difficult for anyone to respond.
Get your Conversational Ransomware Defense e‑book
This e-book gives you an insight into the ransomware threat and reviews the fundamentals of top-notch ransomware preparedness and recovery. To help you protect yourself and your organization. The initial infection may be inevitable, so the best protection is to be fully prepared.
If you haven’t already, I encourage you to read the first article (http://www.experts-exchange.com/articles/18680/An-Introduction-to-R-Programming-and-R-Studio.html) in my series to gain a basic foundation of R and R Studio.  You will also find the …
Simulator games are perfect for generating sample realistic data streams, especially for learning data analysis. It is even useful for demoing offerings such as Azure stream analytics, PowerBI etc.
The viewer will learn how to implement Singleton Design Pattern in Java.
This video teaches viewers about errors in exception handling.
Suggested Courses
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
