Issue trunking VLANs between AdTran Netvanta 1234 Layer 2 switch and Cisco Small Business SG300-52P switch
I have an existing, older layer 2 AdTran Netvanta 1234 switch that I am trying to trunk into a new Cisco Small Business SG300-52P switch.
It should be a standard operation as the setup is not very complicated:
DATA:  VLAN1
Voice: VLAN3
Edge:  VLAN4
The EDGE network is the ISP...we have it setup this way because a few devices need to be plugged into the edge with public IP addresses.
I am trying to trunk this setup to a Cisco Small Business SG300-52P switch.  No matter what I do, when I trunk, things will not work correctly between the switches.
The SG300-52P switch is setup in Layer-3 mode, and I am trying to get the switch to do routing between the VLAN's.  Anything plugged into the Cisco switch works exactly as expected, but anything in the AdTran does not work, and the trunks don't seem to line up.
- I've created the same VLAN's in the Cisco
- I've named them the same as well (although this shouldn't matter)
- I'm uplinking with a single GIG port setup as a trunk
- I've set the allowed VLAN's to ALL
On Cisco Catalyst switches, I usually have to specify the trunk protocol (802.1q) but on the SG300-52P switch, this command is not an option, and the GUI does not seem to have a corresponding option as well.  There is the standard PVID (Native VLAN), trunk vs access, and trunk membership...everything seems to be lined up correctly with the trunk port as a member of ALL VLAN's, and I've tried with and without a NATIVE VLAN set (native VLAN set to DATA when it was set).
Can anyone give any insight into this issue?
Note:  The AdTran later 2 DOES have a VLAN setup for each VLAN as well, and there is no VLAN setup that does not exist in both switches.
jkeegan123
jkeegan123
jkeegan123Author Commented:
Issue is that data vlan was vlan 1, which is the default VLAN.
- Created VLAN 200 (not used for anything)
- Set uplink port to TRUNK
- Set all VLAN's to TAG (switchport trunk allow vlan add all)
- Set native VLAN to 200
Default VLAN (native VLAN) will NOT tag, as that is the point of the native VLAN...it is the VLAN that all traffic defaults to if the traffic is NOT tagged.
I set the upstream switch to the same settings, and everything is resolved.
Join & Write a Comment
Improved Protection from Phishing Attacks
WatchGuard DNSWatch reduces malware infections by detecting and blocking malicious DNS requests, improving your ability to protect employees from phishing attacks. Learn more about our newest service included in Total Security Suite today!
