Python function with while loop and raw_input not breaking
Hello there!
I am preparing a small function the gets feed with csv data in a list and db data in other list.
Those lists look like (for a single record):
['Name', 'Surname', 'Other']
I would like to allow the user to compare two values and decide which value to keep.
My while loop goes on forever even if I have break in it...
What am I doing wrong?
def check_fields(fields_csv, fields_db):
        for field_csv in fields_csv:
            for field_db in fields_db:
                if field_csv == field_db:
                    while True:
                        print ""
                        print "1) Dato nel file csv: " + field_csv
                        print "2) Dato nel database: " + field_db
                        print ""
                        answer = str(raw_input("Which field you want to keep? [1 or 2]: "))
                        print ""
                        if answer == "1":
                            print "You choose 1"
                            global field_import
                            field_import = field_csv
                        elif answer == 2:
                            print "You choose"
                            global field_import
                            field_import = field_db
Dan CraciunIT ConsultantCommented:
elif answer == "2" ?
answer is a string, so it's should not be equal to a number...
Join & Write a Comment
Train for your Pen Testing Engineer Certification
Enroll today in this bundle of courses to gain experience in the logistics of pen testing, Linux fundamentals, vulnerability assessments, detecting live systems, and more! This series, valued at $3,000, is free for Premium members, Team Accounts, and Qualified Experts.
