Finding parts of a string with regexp
I would like to return a string using a regular expression where anything with a dash and data either side is returned.
Example.
select
'test data 123-456 and more test data 6789-789b and more test data' as col1
from dual;
So, I would like the following returned with a comma seperating each find - is this possible and how?
'123-456, 6789-789b'
PHIL SawyerAsked:
Wasim Akram ShaikCommented:
try something like this
select
        regexp_replace(regexp_replace(
             'Test data 123-456 and More test data 6789-789b and more test data 1245-092',
             '[A-Za-z]+', ',') ,',', '')
      as Col1
 from dual;
http://www.sqlfiddle.com/#!4/d41d8/32928/0
PHIL SawyerAuthor Commented:
Can you explain how this works - Thanks
sdstuberCommented:
Actually, the first post doesn't work.
Note the "b" is stripped off the end of the second substring.  Also it doesn't do the comma delimiters, it leaves multiple characters of whitespace instead.
Try this, I made the counter go up to 10, if you might have more substrings than that, then simply make the 10 something bigger.
SELECT LISTAGG(
           REGEXP_SUBSTR(
               col1,
               1,
               n
       WITHIN GROUP (ORDER BY n)
  FROM (SELECT 'test data 123-456 and more test data 6789-789b and more test data' AS col1
          FROM DUAL),
       (    SELECT LEVEL n
              FROM DUAL
        CONNECT BY LEVEL < 10)
 WHERE REGEXP_SUBSTR(
           col1,
           1,
           n
           IS NOT NULL
The way this works is it generates a list of numbers N 1-10 (but you can change that).
Then for each N it looks for patterns of  '[^ ]+-[^ ]+'
which means one or more non-space characters followed by a "-" followed by  one or more non-space characters.
Since this example only has 2 substrings, N 3-10 will find nothing and hence return NULL, so the where clause exludes those.
LISTAGG pulls the 2 substrings together, ordered by the sequence found in the original string and puts a comma between them.
I completely agree with sdstuber.. though thats the best i could do with regex..
I think Sdstuber would be able to explain it in a better way.. lets wait for him..
mean while i would explain what i did..
regexp_replace(
              '[A-Za-z]+', ',')
the first regex_replace will find out the alphabetical characters in a given string and it will replace them with commas..
see the range A-Z and a-z.. this will leave the -(hyphen) and digits(numbers) as is..
and the second regex is replacing the , (comma) character with whitespace..
sdstuberCommented:
I'm not sure what you would like me to explain all the code above has been described adequately I think.  If there is something specific you'd like me to discuss let me know.
This isn't necessary but... here's another variation that might be a little easier to follow but does require creating a type and function.
SELECT LISTAGG(str, ',') WITHIN GROUP (ORDER BY rn)
  FROM (SELECT COLUMN_VALUE str, ROWNUM rn
          FROM TABLE(
                   str2tbl(
         WHERE COLUMN_VALUE LIKE '%_-_%');
Here again the idea is to use the spaces as delimiters.  str2tbl will take the string and split each word into its own row of one column called COLUMN_VALUE.   Then it's just a matter of looking for those strings that have a dash in them and then aggregate into a comma delimited string as shown in my previous post.
You can find the str2tbl and associated type definitions here:
http://www.e-e.com/Q_27233295.html
Brilliant - thanks
Oracle Database
