I need help using a CASE statement in my SQL query
Hi Experts,
I created the following query in order to apply a 50% buffer to my company's On-hand inventory.  The formula for the buffer was applied to our entire inventory, using
the following query:
SELECT S.ItemNo, S.ALTItemNo,S.DESCRIPTION
ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .50), 0) AS OnHandInventory
FROM dbo.Inventory AS R
INNER JOIN ItemSKU AS S ON R.ItemNo = S.ItemNo
LEFT OUTER JOIN LOT AS L ON S.ItemNo = L.ItemNo
GROUP BY S.ItemNo, S.ALTItemNo, S.DESCRIPTION
ORDER BY S.ItemNo
Now I have been tasked with separating our inventory into 3 categorys (women's wear, men's wear, and kids wear), and apply a separate formula to each of the categories.
How can I do this?  Do I use a single query with CASE statements?  Please provide a syntax sample.  Thanks in advance.
Here are the formulas for each category:
women's wear:  ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .75), 0) AS OnHandInventory
NOTE: if OnHandInventory is less than 15 then OnHandInventory = 0
men's wear: ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .50), 0) AS OnHandInventory
NOTE: if OnHandInventory is less than 50 then OnHandInventory = 0
kids wear: ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .70), 0) AS OnHandInventory
NOTE: if OnHandInventory is less than 30 then OnHandInventory = 0
thanks in advance,
mrotor
mainrotorAsked:
Vikas GargBusiness Intelligence DeveloperCommented:
You can apply CASE in single statement
SELECT S.ItemNo, S.ALTItemNo,S.DESCRIPTION,
CASE CATEGORY
WHEN 'womens wear'
THEN
CASE WHEN (ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .75), 0)) < 15 THEN 0 ELSE
ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .75), 0) END
WHEN 'mens wear'
THEN
CASE WHEN (ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .50), 0)) < 50 THEN 0 ELSE
ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .50), 0) END
WHEN 'KIDS wear'
THEN
CASE WHEN (ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .70), 0)) < 30 THEN 0 ELSE
ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * .70), 0) END
END
AS OnHandInventory
ORDER BY S.ItemNo
Harish VargheseProject LeaderCommented:
You can make it simpler using a Common Table Expression (CTE). Here we can split various components of your update into different columns in the defining SELECT and then use them as required in the final SELECT/UPDATE statement. Following query assumes that you have a column named ItemCategory in some table. You may convert the final SELECT into an UPDATE statement:
;WITH base AS
(SELECT S.ItemNo, S.ALTItemNo,S.DESCRIPTION,
		ItemCategory,
		CASE ItemCategory When 'Women' Then 0.75
			When 'Men' Then 0.50
			When 'Kids' Then 0.70
		End AS BufferPercentage,
		SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) as BalanceQty,
		CASE ItemCategory When 'Women' Then 15
			When 'Men' Then 50
			When 'Kids' Then 30
		End AS MinQtyOnHand
	WHERE ItemCategory in ('Women', 'Men', 'Kids')
	GROUP BY S.ItemNo, S.ALTItemNo, S.DESCRIPTION, ItemCategory
	ORDER BY S.ItemNo
Select B.ItemNo, B.ItemNo, B.ALTItemNo, B.DESCRIPTION, B.ItemCategory,
		B.BufferPercentage, B.BalanceQty, B.MinQtyOnHand,
		Case When FLOOR (B.BalanceQty * B.BufferPercentage) >= B.MinQtyOnHand
			Then FLOOR (B.BalanceQty * B.BufferPercentage)
			Else 0 End As OnHandInventory
from base B
ste5anSenior DeveloperCommented:
Or
SELECT  S.ItemNo ,
        S.ALTItemNo ,
        S.[DESCRIPTION] ,
        ISNULL(FLOOR(SUM(L.QTY - L.QTYALLOCATED - L.QTYONHOLD) * CASE ItemCategory
        WHEN 'Women' THEN 0.75
        WHEN 'Men' THEN 0.50
        WHEN 'Kids' THEN 0.70
        ELSE 1.0
        END), 0) AS OnHandInventory
GROUP BY S.ItemNo ,
        S.ALTItemNo ,
        S.[DESCRIPTION]
ORDER BY S.ItemNo;
p.s. always use a fallback.
mainrotorAuthor Commented:
Quick question for all of you.  Can i use a temp table in a view?
mrotor
No, temp tables are not allowed in views. You can use permanent tables in tempdb if required. There may be alternatives if you can state your requirement.
btw, are the ItemCategory values hard-coded or are they retrieved from a table? In the second case: Use a table to store the factors and JOIN the factor table.
awking00Commented:
Can you describe the three tables? What attribute defines what is women, men, or kids?
awking00Commented:
>>What attribute defines what is women, men, or kids?<<
Does an attribute such as category or itemcategory even exist?
Microsoft SQL Server 2008
