Victor Charles
Help with changing order of data element using VB.NET
How do you loop through an xml file and change the order of a data element? For example if my xml file contains
<Root>
<Table1>
<ID>1</ID>
<Item1><Item1>
<Item3><Item3>
<Item4><Item4>
<Item2><Item2>
</Table1>
</Root>
I would like to move the last data element (Item2) below the Item1 data element.
<Root>
<Table1>
<ID>1</ID>
<Item1><Item1>
<Item2><Item2>
<Item3><Item3>
<Item4><Item4>
</Table1>
</Root>
Victor
<Root>
<Table1>
<ID>1</ID>
<Item1><Item1>
<Item3><Item3>
<Item4><Item4>
<Item2><Item2>
</Table1>
</Root>
<Root>
<Table1>
<ID>1</ID>
<Item1><Item1>
<Item2><Item2>
<Item3><Item3>
<Item4><Item4>
</Table1>
</Root>
Victor
Hi Fernando,
The names I gave was in example, in my project they are different.
<Root>
<Table1>
<ID>1</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
</Root>
Would like to move AGD under NSC.
Victor
<Root>
<Table1>
<ID>1</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
</Root>
Victor
Hi Victor;
Working with XML documents or fragments is very dependent on the XML schema/structure and so asking questions really requires the actual names of node and the structure of the document and if multiple nodes are involved.
Is it possible for the XML to have more then one Table1 node with multiple AGD node that have to move within their own parents node beneath NSC node?
Hi Fernando,
Yes, the xml file contains multiple records for <table1>. For example
<Root>
<Table1>
<ID>1</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>2</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>3</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>4</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
</Root>
Victor
<Root>
<Table1>
<ID>1</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>2</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>3</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
<Table1>
<ID>4</ID>
<NSC><NSC>
<NSN><NSN>
<FIF><FIF>
<AGD><AGD>
</Table1>
</Root>
Victor
Thanks.
Thank You!
This should do it.
