display ER diagram and quickly find out problem schema design problem
Dear all,
start to learn on how to find out schema/ talbe design problem of MS SQL as from time to time developer will come and ask.
So please suggest what kind of tools you guys use to find out table design problem, dbforgo studio ? toad for MS SQL ?
LVL 1
marrowyungSenior Technical architecture (Data)Asked:
David ToddSenior DBACommented:
If a MS development shop, see if your MS Office licence includes Viso.
Viso can interrogate a database and suggest an ER diargram.
Regards
  David
marrowyungSenior Technical architecture (Data)Author Commented:
MS Viso can connect to MS SQL and generate the ER diagram?
Yes. Visio can suggest an ER diagram. Of course, splitting onto different pages is something you'll have to do. But Visio gives the tables and columns etc. It can give relationships based on Foreign Key constraints - if there are no constraints then there is nothing for it (or you or other tools) to really suggest that there is a relationship between tables.
But just double checking, it appears that you can't easily do this with Visio 2013.
Do you have (individually or the company) a MSDN Subscription? There used to be a specific version of Visio in Enterprise Architect.
HTH
  David
ste5anSenior DeveloperCommented:
Keep in mind: an entity-relationship model contains semantic desciptions. When they are not stored in a separate database or the extenend properties, then it's not possible to generate an ER from the database schema.
David,
"But just double checking, it appears that you can't easily do this with Visio 2013."
what version of Visio can do it?
What other tools  you can suggest ( free of charge perferrable ) , can Toad for MS SQL do this ?
"Do you have (individually or the company) a MSDN Subscription? There used to be a specific version of Visio in Enterprise Architect."
I don't have, so that one is called Visio for Enterprise architect ?
that one will give suggest on what is the problem it found out and what should we do ?
btw, I'd like RedGate SQL Dependency Tracker. It's a nice and simple tool to inspect database schemas.
ste5an,
so that one can tell Schema problem and give suggestion ?
No. This is only possible when you have a complete set of requirements. I don't know any tool which can do this.
But as a simple rule of thumb: Examine the schema and data for possible violations of the normal forms. And discuss this with the developers.
For Visio 2007
http://office.microsoft.com/en-nz/visio-help/create-a-database-model-also-known-as-entity-relationship-diagram-HA010115477.aspx
So you can see that I'd assumed this feature was still in existence, but seems to have been culled.
Regards
  David
david,
But that one don't give suggestion, right?
it just show that out !
Anthony PerkinsCommented:
So just so that I understand you are looking for a tool that not only displays the current ER diagram, but also shows any problems with the design as it stands?  if so, can you elaborate what you mean by problems?
"So just so that I understand you are looking for a tool that not only displays the current ER diagram, but also shows any problems with the design as it stands?"
yes, this is what I mean and that's why the vendor want us to buy their tools.!
I know dbforgo studio help developer on this area but I am not sure how far it goes .
learn from tools can learn fast !
Again what specific problems are you hoping this tool will show?  Since you have not told us what you are looking for it is difficult to know for sure.
As far as I know dbForge Studio and their Database Diagram Tool for SQL Server does not display any problems whatsoever.  I just looked at their website again and I see no indication of anything remotely like that.
"please suggest what kind of tools you guys use to find out table design problem, dbforgo studio ? "
so therefore, I am looking for a tools that can show schema/ER/table design problem.
Hi
As above, I've used Visio. It is a tool, not a magic wand. I helps me see issues; it doesn't show me issues.
Also I'm in need of a new tool as MS have removed this from Visio.
Others have suggested tools they use. See if there are trials and give them a test.
Regards
  David
"Also I'm in need of a new tool as MS have removed this from Visio."
WHY ????
ok, any good book for me to learn what is a good table design ?
or any URL for that learning is good !@
C.J.Date's books  are pretty good ones.
tks, I take a look but there are a lot of them, which one you recommend ?
it is sad that no tools on earth can help quickly pinpoint the problem of schema design.
As previously mentioned a magic wand has not been invented yet.  Or to put it another way, unless there are simple problems like a circular reference, it is non-trivial or impossible, depending on what specific problems you are trying to address.  And there again lies the problem, you have not stated what specific problems you are trying to address.  So until you can produce a coherent list of requirements or at the very least specifications of what you expect to get out of it, it is a tad difficult to even speculate.  Stating that you need a tool that "can help quickly pinpoint the problem of schema design" is telling us nothing.
Anthony Perkins,
they all understand what I am saying and they suggest books too !
I like them.
what I can see is the Toad data modeler can do sth on it.
Microsoft SQL Server
